Question about Craftsman Air Tools & Compressors
Craftsman model #919.165020 with GE motor SKCR49TN2312CX. starts fine with 0 air pressure but jumps up to over 80 amps trying to start with pressure in tank. tank check valve is working
  • mikem1805 Sep 10, 2010
    actually there was no additional pressure relief, it was a faulty design which has the start capacitor mounted on the back of the motor in a plastic frame that also included a presure contact that i assume brings in the start capacitor. this was broken away at the bottom screw which did not allow for it to kick in apparently. another one of the many uses for a rubber tarp strap. thanx for trying though. m
    President:
  • Craftsman Master
  • 1,388 Answers
The motor does not have enough power to overcome headpressure. Two areas to check for your problem. Valve plate in head (broken reed valves/gasket) or unloader not bleeding air out of system. Your compressor has a small valve under the pressure cut out switch that unloads the pump (bleeds air out of tube). It is actuated by a small arm that comes into contact with valve when cut out pressure is reached. Verify that air bleeds out of system when set pressure is reached. You will hear air escape for just a moment. You mentioned that the check valve is working (or holding pressure in tank, spray soapy water on valve with tube removed). If checkvalve is leaking, pump motor can not overcome pressure. If valve plate has leaking or broken valves, the motor will strain and the air will discharge at a very high temperature. Your pump can use sears parts or maybe even porter cable. Good luck.
Posted on Sep 11, 2010
  • 43,501 Answers
There should also be a relief between the check and the head...this should relieve the pressure and is what has failed...
Not sure where exactly it is on your particular model, but you should be able to find it by following the piping back from the check to the head or it is built right into the head...
heatman101
Posted on Sep 10, 2010
I have a Craftsman (919.176820) 2HP, 12 gal. compressor. I starts fine the first time, it reaches full pressure and cuts off. When the pressure drops and it tries to start again, the motor lugs and trips...
Your tank check valve is stuck/broke. It's on the tank end of the line from the pump to the tank. It is supposed to close when the pump stops to keep air in the tank and let the system bleed pressure out of the pump so the motor can start when there is pressure in the tank. The part you need is CAC-437-2 and is available through searspartsdirect.com.
Feb 22, 2012 | Craftsman 33 gal Air Compressor 6 hp...
My craftsman 3gal. compressor starts and run but no pressure is building up.it just keeps running and the gauge remains at 0 psi.
Is the petcock down below open or closed? If open, then screw it closed. Also, is the compressor portion connected to the motor working as it should? As the motor reciprocates, it should operate the compressor piston that pumps air pressure into the tank. Maybe something is broken there.
Nov 04, 2011 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Compressor starts innitially,then when pressure gets low it trips breaker when it tries to start back up.20 amp breaker to light switch to compressor is about 2o ft on12-2 wire. tried 30 amp breaker,does...
the start capacitor on the motor body is weak,the motor needs this component to over come the air pressure when cycling to re-build the low air pressure,change both the start and run capacitors when doing the start because the other run capacitor is just as old and it will soon fail
Mar 19, 2011 | Craftsman 33 gal Air Compressor 6 hp...
Sears/Craftsman air comp./paint sprayer mod# 106.154881 3 hp 30 gal. starts fine - pressure builds to 20# then motor boggs down then restarts over and over.
Your wire to the motor is too light a gauge wire or you are using too small of a gauge electric cord on it.
For a three HP motor you will need to use at least a 10 gauge wire or cord on a thirty amp. circuit...
heatman101
Feb 22, 2011 | Craftsman Air Tools & Compressors
I have a 20 gal 3 hp Craftsman air compressor. It will start up, come up to pressure & shut off. When air is used and it needs to start up again, the motor tries to start and quits ??
The motor should be a capacitor start type--if the capacitor is failing, the starting torque will be weak. Also, if the 'unloader' valve is not working (not sure if this compressor uses one), the compressor is trying to start against tank pressure which needs fairly high starting torque from the motor. Be sure to power the unit from adequately sized outlet and any extension cord. The thermal switch in the motor may be excessively sensitive to overloads. Go to: www.searspartsdirect.com and enter the model number minus the decimal point to get to a series of drawings of replaceable parts. Hope some of this helps!
Dec 12, 2010 | Garden
Need a new pressure switch for Craftsman model 919152920 compressor, but that part is no longer available. The switch doesn't function to even turn on the compressor.
You can purchase a generic/ universal pressure switch from www.grainger.com or ebay. Just look for the correct fittings and pressure cutout. Cost about $20. Before you order a new switch you should test that motor and pump are ok. Jump the wires on the pressure switch temporarily so line-in is connected to motor line. When you connect cord to wall plug the compessor should start and begin to fill. If function ok then order switch. If the motor does not start, may not be switch. Good luck
Nov 09, 2010 | Craftsman Air Tools & Compressors
IR 2475E Wont start up 220 everywhere No LOP switch
did you check for a motor reset button on the motor??
Feb 20, 2010 | Ingersoll Rand - Rand Type - 30...
Air compressor motor stalls under pressure
this sounds like a bad pressure switch.if the unit is not shutting off at the same pressure each time this would be the cause.2 if the pressure is not unloading the air pressure on the compressor side of the unit it will cause the unit to struggle when it starts a cycle because the piston is under a load .how this works is say the unit starts from 0 psi when it get to the desired pressure you have it set on the unit kicks off . the other adjustment most units have on them is what pressure to cycle back on.so when the unit reaches say 100 pounds ,it kicks off and bleeds the air off the compressor side so when it starts back up it wont start up with pressure on the piston.
Jun 18, 2009 | Air Tools & Compressors
I have a electric air compressor craftsman 3.5hp 15 gallon it wont start back up when air is low
The pressure switch controls the cut-in and cut-out points for the motor. Some switches have a differential adjustment besides the pressure adjustment. The differential controls the spread between cut-in & cut-out, (say in at 80 PSI, out at100 PSI)
Try looking for these if you didn't get a manual.
Good luck
Apr 26, 2009 | Craftsman Air Tools & Compressors
Air Tools & Compressors Logo
517 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
