Question about Miele 24 in. G638 Plus Free-standing Dishwasher
We have a Miele G 638 SC Plus, it was in the house that we bought. After 3 years of use, the salt light has come on. What do I do?
gwshaw71
  • 83 Answers
SOURCE: Miele G638 CS Plus - Salt PC light flashes and will not run
have you added salt to unit?If so then you have a water intake problem or unit is oversudsing.
Posted on Dec 08, 2007
bigg t
  • 640 Answers
SOURCE: miele G893
you should have a dispenser on the door to add salt,regardless get c.l.r. calcium lime rust remover from a supermarket,lowes,home depot.put a cup in the unit ,run for 15 minutes and then put a cup in again.let the unit complete its cycle.if you still smell the odor repeat until its gone.you could also use baking soda,flour or vinegar.
Posted on Jan 06, 2008
SOURCE: MY MIELE G856 SC DISHWASHER
press the start/stop and hold for 6 seconds that should clear it.
Posted on Jul 23, 2008
SOURCE: G892-SC Miele water intake/drain light blinks
The intake/drain light blinks. How do I fix this problem?
Posted on Sep 18, 2008
  • 177 Answers
SOURCE: dishwasher not cleaning properly and everything tastes like soap
To start with reduce the amount of detergent you are using. 2 teaspoons of detergent is enough for any wash.
Probably blocked spray arms is the cause of the unit not cleaning properly. Remove each spray arm (there are 3 in total) and check and clean all the holes as this is where the water sprays out from to clean the dishes and glasses. When they are blocked you get poor wash results. The bottom spray arm is the easiest and just pulls out the other two in the middle and the top you have to unscrew like a childs lock on a tablet bottle. Push up from underneath and unscrew each arm.
Hope this helps.
Posted on Jan 25, 2010
When I got my Miele dishwasher a year ago, I added salt but did not add water as it said to, the refill light has not come on in a whole year, should I do something?
I wouldn't worry, depending on how hard your water is it may use very little salt. There's no harm in topping it up to be on the safe side. Salt acts as a water softener that's all, which helps the detergent work better. If you are getting good cleaning I wouldn't worry about it.
Dec 09, 2014 | Miele Dishwashers
Miele dishwaher G638 Sc,,,,Salt PC light is on?
Hi - if its flashing rapidly then there a unrecognized hardware issue -if on permanently - it could be the float switch inside the salt container is not working/jammed - of course theres no salt in the dishwasher container..
Cheers
Jul 20, 2011 | Miele 24 in. G638 Plus Free-standing...
On my Dishwasher Miele G638 Plus, a red light shows up and it says PC salt, I dont know how to solve this, please help me.
Hi - its possiblily the following issues if its flashing rapidly then the electronic module maybe faulty. The other possibilties are the float switch inside the salt conatner is jammed or the reed switch for the float switch in the salt container does work.
May 30, 2011 | Miele 24 in. G638 Plus Free-standing...
What is the salt when it comes to the dishwasher
The light is just to let you know that the internal water softener needs water-softener salt.
If you do not use the softener (I do not at my house) then the light serves as a convenient on/off light.
Feb 17, 2011 | Miele 24 in. Novotronic G641 Plus Built-In...
Hi My dishwasher Miele G692 SC has the inlet/drain light illuminated. I have cleared the inlet and tap connection..... Any other suggestions before I ring Miele?
Have you checked the drain? On mine a small piece of broken glass had got past all the filters and had blocked the paddles of the pump - you have to release the spring clip and take off the top of the pump housing. Miele's seem very fussy about any blockages to the water outlet system.
You then have to hold down the start button to force a restart (cost me a call out to learn that) - but it is stated, sort of, in the problem fixing manual.
Nov 01, 2010 | Miele Dishwashers
Water leaking from under the machine (Miele G638 Plus) dishwasher
The salt tank is a pathetic piece of ****. The plastic cracks and leaks into the bottom tray, which in turn sets off the safety switch.
Follow the attaching hoses and bypass the salt tank unless you really need it. This will save you around $250 for a salt tank and $300 labour for callout and repair.
Mar 23, 2009 | Miele 24 in. G638 Plus Free-standing...
Aug 11, 2008 | Miele 24 in. G665 Built-in Dishwasher
Salt light on G641 model
i turn the dishwasher on the salt light keeps flashin ive cleared out the salt container and applied new salt and its still not working
Jul 08, 2008 | Miele Premier-Plus Built-in Dishwasher
Dec 07, 2007 | Dishwashers
Miele 24 in. G638 Plus Free-standing Dishwasher Logo
215 people viewed this question
Top Miele Dishwashers Experts
mpservices
Craig Butler
Craig Butler
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
