Is there a conversion kit for propane for this furnace?
    Master:
    Sergeant:
  • 449 Answers
Need more info
Posted on Sep 10, 2010
How do you convert to propane a kenmore elite model # 79671622310
You have to get the conversion kit. Mostly the burner gas nozzels has to be changed. Propane has a higher BTU value than natural gas. So the burner nozzle has to be smaller with propane.
You have to have the right nozzle kit for your dryer. Normally the propane nozzle kit comes with the new dryer. It is attached in a plastic seethrough bag and attached somewhere in the back of dryer.
Also you have to adjust the air opening in the burner for propane. Propane need more air than natural gas to burn properly. If you buy the conversion kit or find the conversion kit in the back of your unit, it will clearly give instructions how to do it.
Sep 26, 2014 | Dryers
Why does new furnance with propane conversion have yellow flames?
Make sure the kit included smaller sized orifice's and spring kit for the gas valve. The number on each orifice should be cross referenced with total btu's rating of the furnace. It does seem like there is too much fuel or not enough air intake (combustion air). The inches of W.C. seem fine, but you still may be getting too much volume of fuel with too large of sized orifice's. Hope that helps
Dec 20, 2013 | Heating & Cooling
Convert coleman furnace model# 7956B856 Serial# 039167560 from propane to natural gas . What do I do to the gas valve and what size orifice do I need ( or drill size to drill the propane orifice out ) .
You will need to get a natural gas conversion kit for your equipment. It will include around three different orifice sizes depending on elevation. Never drill orifices yourself as this is a gas appliance and could kill you. You will have to remove your gas manifold and unthread the existing orifices and screw in the new ones. As far as the gas valve you will need to unscrew and remove the adjustment screw and change the spring located underneath and reassemble. Once changed out you will need to check the manufacturers name plate and adjust the manifold pressure using a manometer. If this is not done having incorrect gas pressure can cause delayed ignition, overheating of the heat exchanger or high carbon monoxide levels. The conversion kit is inexpensive and should take less than an hour to do
Oct 25, 2013 | Coleman 7990-319p Evcon Gas Furnace...
I have two Williams 1403622 wall furnaces in my children's room. they seem to leak gas not when the furnace is on, only when it's on idle. Both heaters were converted to LP with the Williams Conversion...
When the units were converted, did the installer also adjust the burner's air intake valve to what's required for propane? Sometimes, that's forgotten. Also, I assume all of the connections were leak tested .... not just where the conversion kits were installed, but throughout the heater? The reason I asked this, is that propane enters the heaters at a higher pressure (water column inch) than Natural Gas. Almost twice as much. In which case, it may have loosened the seals in the regulators.
Those are the things, I'd be looking at.
Mar 03, 2011 | Williams 1403622 Gas Compact Heater
Is there a kit to change from propane to natural gas for a Daton model # 3e239e unit heater. I have talked to Graingers and they don't know and they say the unit has been discontinued. If there is can you...
Bill, the model number is good, but won't get anybody the part number of the gas valve. Basically, there are 2 issues to address, the pilot orifice size and the pressure regulator. Get the numbers off of the gas valve (OEM numbers, brand) (likely White-Rogers or Honeywell), and search via manufacturer for conversion kit. (Generally a spring and a pilot orifice). Should you locate a kit, be prepared to have someone properly adjust the manifold pressure once installed. Also, as the make things cheaper, sometimes they are built for one fuel or the other and sealed. You may end up buying a new gas valve. Being raised in a propane plant, I recall their skill-set far superior to general HVAC guys (like myself) in this arena. As propane conversions are a part of everyday life for them (temporarily making a furnace run on propane during construction and switching over once the gas line is hooked up), they are probably a good starting point!
Dec 03, 2010 | Dayton (3E379) Heater
Need a conversion kit for a wh-150 Janitrol furnace...changing from natural gas to propane.
Try national energy they sell gas spares .they are on line and have there own shops
Mar 06, 2010 | Goodman Heating & Cooling
Trouble shooting Hayward pool furnace
Big enough propane tank? proper pressure reducing valve on the propane? Check both of those.
May 30, 2009 | Hayward H Series Pool & Spa Heater 400k...
JDS8130 Cooktop Conversion Kit : Propane to Natural Gas Conversio
here is a site that has gas conversion kits
http://en.allexperts.com/q/Major-Appliances-3603/Jenn-Air-gas-range.htm
Jan 31, 2009 | Jenn-Air 30 in.JGD8430ADS Gas Cooktop
Propane conversion for cozy model CF503C
try national energy for a conversion kit they should be able to help or the will know some one who can
Jan 10, 2009 | Cozy CFR Utility Heater
Heating & Cooling Logo
12 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
