Question about Hitachi Televison & Video
Only sound no display on my hitachi 55PD8800TA
My plasma tv picture is fully gone but it still has sound. Tryed un plugging waiting ect still nothing What could it be? Hitachi 55 inch Plasma Model number 55pd8800ta
Sounds like your bulb is burned out. You can have a serviceman replace it or buy one and do it yourself. Go to ShopJimmy.com. They have your bulb and probably will give you instructions to replace the bulb, and answer any questions you have about it. Call ShopJimmy (877) 881-6492 / (952) 881-6492
Aug 11, 2016 | Televison & Video
Horizontal line problem. Toshiba 55pd8800ta
Check and replace damaged component/s at its vertical output section circuit. If you wish to get more details, check this site. Pull up older posts there. Check the site with patience, as it has over 2200 posts now. All are related to electronic equipment repair help.
Apr 05, 2013 | Televison & Video
My toshiba 55pd8800ta now has parrallel lines running across the screen, they are clear lines of the picture but out of sinc with each other. Help!
Hitachi 32' lcd Tv L32A03A manual guide
SAYA ADA MODEL LCD 32'' HITACHI L32A03A. ON GAMBAR DISPLAY JADI PUTIH. SOUND OK.TRY AV PUN SAMA. TERIMA KASIH
Aug 04, 2012 | Hitachi Televison & Video
HITACHI L22DP04U displays no signal
Press source and select the digital/usb option, sounds like you have 'TV' selected which is analog and will just display no signal with a blue screen.
Aug 15, 2010 | Hitachi Televison & Video
Sound, no picture, no display, just a black screen
its a Hitachi DLP
it has a lamp that illuminates the screen
it has most likely failed in your owners manuel it should be more specific and you can order a lamp and replace it your self
and you can order a lamp off of line or call hitachi
Oct 26, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi P50H401 display problem
it is problem your TV high voltage unite(EHT)
change it by authorised service centre
Aug 28, 2009 | Hitachi P50H401 50 in. Plasma HDTV
My Hitachi 50V710 has both indicator lights blinking and does not display any image. Temp LED and Lamp LED. But I hear the fan running and the lamp is the same I've always had. Whats wrong?
With both LED's flashing sounds like a bad lamp to me. Not uncommon for Hitachis LCD projections to have that symptom. Cjeck your owners manual for the light flash code. Good luck..
Jun 20, 2009 | Hitachi 42V710 42" Rear Projection HDTV
Televison & Video Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
