Question about Hayward 2HP Pool Pump Motor A O Smith Electric Pool Motor for 56J Frame
The long bolts that hold the ends on are stuck, don"t want to snap them off
  • 990 Answers
Oil and heat, oil and heat.
Posted on Sep 09, 2010
Replace Thermostat in 2001 Expedition 5.4 bolts won't break
Use and extension and socket,breaking will make it worse.
Jan 20, 2013 | 2001 Ford Expedition
CV axle stuck in the transmission in1993 Mercury Capri
The axle must be removed in a sharp snapping motion and it must be pulled straight out, use a large pipe wrench and quickly snap it back while holding the axle shaft straight out, they do get stuck but it will come out believe me.. The heavier the weighted objects you use to slide along the shaft to snap it out the better, I have a huge Crescent adjustable open end wrench (about 6 pounds) that I use. The only thing that holds the axle in is a round internal snap ring that sits in the groove inside the transmission case.
Apr 23, 2012 | 1993 Mercury Capri
Cannot get rear axle out of rear end
most axles you have to take off the differential cover and there will be a large pin that goes through the center of the carrier. this pin usually has a small bolt holding it in place. remove bolt and pin and that should allow you to push axle in enough to remove the c-clip on the end of the axle.then you can pull axle out of housing.
Dec 31, 2011 | Dodge Cars & Trucks
My Ryobi 18V cordless drill will not close to hold the bit. It is open and stuck. Can somebody help me
This could be caused by several things.
open it all the way and check the claws for damage or something stuck in them
there should be an allen head bolt inside at the base...check to see if this is loose....it is a left hand thread, if it is tight and the problem is damaged claws then take out this allen bolt, tighten a large allen key in jaws (or grab the outside with visegrips) and give it a sharp snap to the right to remove the end and replace it.
Aug 30, 2011 | Ryobi 18volt 12" Cordless Drill Model P206
Waterpump is stuck and unable to remove to replace
You don`t Have all the Bolt`s Out or Off ; With all the bolts out the water pump WILL ALMOST FALL OFF ;CHECK for more Bolts holding it on
Aug 20, 2011 | 1990 Pontiac Sunbird
1991 toyota pickup driveaxle removal . 4wd stuck.
there are 6 bolts to remove that hold the drive-axle to the front end housing, you then need to remove the hub and the gears inside, you will then find a snap ring on the other side of the drive-axle that needs to be removed a little moving around and you should be able to remove the axle
Apr 12, 2010 | 1991 Toyota Pickup
I just snapped the bolt off the rear fender of my VStar 650 Classic that holds down the passenger seat, how do I replace it?
Was it seized in place or did you over-tighten it?
If you cannot access the other end of the bolt with vise-grips then I would drill it out and then try to extract it with an ez-out. If its really stuck you have no choice but to drill then re-tap the hole.
Mar 03, 2010 | 2007 Yamaha V Star Classic
I'm having trouble getting rear rotors off of a 1999 F350 4x4 dually. I can't figure out how to get the snap ring off.
snap ring? Its a full floater! Take bolts off end of shaft pull shaft out,remove bearing lock nut (the correct socket works so sweet!), pull hub and rotor off, The studs hold the rotor to hub or some have external torx bolts that hold it to the hub.Remove those and you may need to tap hard with a hammer to separate. Where is that snap ring?
You will need new seals,and studs are a good idea,how do those parking brake shoes look?
Apr 24, 2009 | Ford F-350 Cars & Trucks
The bolts that hold the drive shaft in the car fell out
here's the illustration with parts and numbers you need. take to dealer parts counter. If the bolts cam out, are you sure the u-joints did not get damaged?
#12 is the bolts
Item Part Number Description 1 — Needle Rollers (Part of 4635) 2 — Grease Seal (Part of 4635) 3 — Bearing Cup (Part of 4635) 4 — Thrust Washer (Part of 4635) 5 — Spider (Part of 4635) 6 4635 Universal Joint 7 4841 Driveshaft Slip Yoke 8 — Snap Ring (8 Req'd) (Part of 4635) 9 4602 Driveshaft 10 4782 Driveshaft Centering Socket Yoke 11 4851 Rear Axle Universal Joint Flange 12 N800574-S100 Bolt (4 Req'd) 13 4635 Universal Joint 14 — End Yoke (Part of 4635) A — Tighten to 93-130 Nm (71-95 Lb-Ft)
Mar 03, 2009 | 1986 Mercury Grand Marquis
Remove fuel filter from bracket
the three lines just snap into the top of the plastic bracket and 1 half inch bolt holds it on. remove the hole thing stand it on end and tap it off the old filter the new one should slide in easier.
Feb 23, 2009 | 1998 Chevrolet S-10 Pickup
Hayward 2HP Pool Pump Motor A O Smith Electric Pool Motor  for 56J Frame Logo
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
