Question about Kenmore 43142 Front Load Washer
I have trouble with code F60 on kenmore washer...
  • 15,935 Answers
The error is an indication a motor speed problem. You will need to check the following:
- Check the wiring harness. Verify all connections between the Drive Motor, Motor Control Unit (MCU), and Central Control Unit (CCU).
NOTE: The MCU is a circuit board located in the vicinity of the Drive Motor on the bottom rear of the washer. To access the MCU, you will need to remove the back panel of the washer.
NOTE: The CCU is the main computer for the washer and is located behind the wash tub. You will need to remove the top panel to access the CCU. This is accomplished by removing the three screws in the back of the washer that hold the top in place. Once the screws are removed, the top panel will slide back, then lift off.
- Check the Drive Motor. Perform a continuity check of the Drive Motor windings. Remove the connector plug and check across pins 1 to 2, 2 to 3, and 1 to 3. All readings should be approximately 6 ohms. HINT: You can also take this reading by removing connector 2 from the MCU and measuring across pins 1, 2 and 3. If the readings are good, this will also prove the wiring and connector good.
- Check the MCU. The connectors are numbered 1 to 3 (L to R). That is, with the MCU installed, connector 1 is on the bottom, followed by 2 in the middle, and 3 on top.
Connector 1 - is the serial communications link between the MCU and CCU and has three wires. At the opposite end, this will be the 2nd connector from the rear on the left-hand side of the CCU.
Connector 2 - is the link between the MCU and the Drive Motor. Pins 1, 2, and 3 on this connector are the Drive Motor windings. Pins 4 and 5 are for the tachometer.
Connector 3 – is the primary power connector. Pins 1 to 2 should read 120VAC with the door in the locked position. Pin 3 is ground. At the opposite end, this is the 4th connector from the right on the front of the CCU.
NOTE: All the connector pins are numbered R to L.
If your continuity readings are normal for the Drive Motor and you have verified all connectors, replace the MCU.
If any of the Drive Motor windings indicate readings higher that 6 ohms, replace the Drive Motor.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 09, 2010
Kenmore front load model 40272900 e codes (control Error)
If the washer's full model number is 79640272900, then the unit was made by LG. Looking up LG front-load washing machine error codes will give the available codes. Here is one listing: http://www.appliancefactoryparts.com/blog/2010/02/washing-machine-fault-codes/#LG . Some of these codes are also available in the manual in the Trouble-shooting section. Manage My Life has the manual as a PDF here: http://www.managemylife.com/mmh/owner_manuals/17952/KENMORE-Residential-Washers-L0910072?brand_name_search=79640272900 .
I hope this helps.
Sep 21, 2013 | Computers & Internet
What is code F1 mean on the Whilrpool Cabrio. The washer stops about 5 seconds when I first put it on.
Ok the Cabrios have alot of problems. In your owners manual there is a big page where it gives you errors codes and what to do it also givees you a diagnostic feature which helps determine the problem. This site gives you the fault codes and what to replace. F1 means primary control failure. Also sometimes when the control board is bad something else could also be wrong. Good Luck
F1 (F60-68)
Primary Control Failure F then 1 flashes when there is a primary control failure. Replace the machine control assembly.
See Accessing & Removing the Electronic Assemblies. F1 (F60-68)
See Accessing & Removing the Electronic Assemblies.http://www.advantagesupplyfl.com/WhirlpoolCabrioWasherFaultCodes.html
Jun 02, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Error code F-28
It may be that the drain pump is not the problem at all. Error Code F-28 on the Kenmore HE2 means that there is a signal error between the Central Control Unit (CCU) and the Motor Control Unit (MCU)
Mar 13, 2009 | Kenmore HE2 Plus Front Load Washer
Washer stops washing and gives a p5 trouble code
PF - Power Failure - PF error code indicates a power failure during the dryer's cycle. Press and HOLD start to continue the cycle, or press off/pause to clear display.
Mar 12, 2009 | Kenmore Elite 45986 Front Load Washer
Iget a f-11 trouble code on my kenmore elite he4t washer.
REplace your MCU. The MCU is the Drive Motor Control board and is located in the rear of the washer adjacent to the Drive Motor on the left-hand side (facing from the rear with the back panel removed). The wiring harness can also cause the error, but it is not as common a problem. Go onto kenmore.com and find your right washing machine and replace the part yourself. First try and take the wiring harness off and then reconnect it and see if the error code goes away if it doesnt then replace the part. Please Rate. Thank you
Feb 12, 2009 | Kenmore Elite 45986 Front Load Washer
Washer wont spin or wash
F51 trouble code is the washer sensor. Try unplugging the system for 1 minute then plug back in and see what happens =. If that does not work then open the back of the washer by the knobs and in the middle there are 3 sensors check which one has a burnt mark on it and replace it. Other thing is to call Kenmore and see if they will come out and replace since this is a VERY serious problem.
If you are satisfied with my answer please raate
Feb 12, 2009 | Kenmore 27032
Kenmore 43142 Front Load Washer Logo
101 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
