Question about Lenovo IdeaPad Y510 Notebook
Lenovo Y 510 right bottom case screws came out .repair shop says I need a bottom casing but they can't find one. Lenoovo admitted they it was a design problem but they doid not have a recall on them.. it is out of warrenty and they do not sell the part. Any ideas?
  • 794 Answers
Hi mtown,
Lenovo is the only one who do have the the bottom casing for your Y510 and there's nowhere you can buy from. If you were already informed by Lenovo that they do not sell the part and the machine is already out of warranty then I'm afraid to say that there's really nothing more we can do for this. If you want you may contact Lenovo once again because they do an out of warranty repair. You can inquire about how much the cause may be.
Hope it helps.
Thank you for using Fixya.
Posted on Apr 09, 2011
How do I remove casing of Lenovo B50. No longer under warranty and charging port has fallen inside of casing. Tried tweezers, couldn't get it.
Need to remove the bottom panel of unit. Need all sorts of special, miniature screw drivers to do the deed.
Keep track of what was from where for the reverse put together process.
Sep 20, 2015 | Lenovo Computers & Internet
I have taken this xbox apart once before but did not get very far. What type of tools are necessary to repair this type of Xbox 360? I would also like to update the CD/DVD drive on it. Any hints or ti
Most of this can be taken apart with a screwdriver . The case is a little tricky. You will notice from the side...where the case is split, there are tabs on the inside that you need to press. I poked a small screwdriver through the vent holes to press them and get the box apart.
Oct 04, 2012 | Video Game Consoles & Games
The plastic casing supporting the hinge on the inside has broken which causes the right side rear of the laptop to have a buckled look. The screw is still there but isn't screwing into anything. I am...
Hi mandyfin,
Based on your concern I recommend to contact lenovo technical support at 877-453-6686 then option number 2. They will set a depot repair to fix the issue.
Hope it helps,
Thank you for using FixYa
Best regards,
Reyjoshua07
Jan 24, 2011 | Lenovo IdeaPad Y510 Notebook
My bottom case of lenovo y510 is cracked where the right hinges are attached. my warranty is over..please help.
Hi drsachin90,
For your hinge issue, I recommend to contact the technical support of Lenovo. They will set up a depot repair for you to diagnose the computer and to repair it completely. You may contact them at this number 1-877-4Lenovo (1-877-453-6686).
--> Hours of operation, 24 hours a day 7 days a week.
Hope it helps. Thanks for using Fixya
Oct 27, 2010 | Lenovo IdeaPad Y510 Notebook
Want to remove my hard disc... but.. I can get to and remove the 2 screws on the "inside" of the drive.. but.. the two screws next to the case are so close to the case I can't get to them. Am I missing...
The hard drive is secured to the frame and this frame needs to be removed to get access to all the screws holding the hard drive to the frame. The frame may have screws holding it to the case or accessed from the front of the computer after you remove the front faceplate panel.
Sep 25, 2010 | Gateway 510 X PC Desktop
IMac G5 CASE SCREWS STRIPPED
just replace the screws with a slightly larger thread
this will give you an idea of what is available (which you should be able to purchase at any hardware store)
http://www.accuratescrew.com/Captive-Screws.aspx
Robert
Jan 29, 2009 | Apple iMac G5 Desktop
Lenovo y510
This is the known issue with the Y 510 so please contact to the customer care and get it replaced.
Nov 02, 2008 | Lenovo IdeaPad Y510 Notebook
Replacing CD-RW/DVD Drive
I own a Presario F730US. I have had it apart many times and it is a difficult case to open. There are several ribbon cables that are easily damaged if you are not very careful. You have to pop up the speaker cover panel as there are case screws under it as well. Once inside you will see the screws that retain the optical drive. Once you remove them it will slide right out and the new one will slide right in. I can not overstate how careful you have to be. If you are not 100% sure of yourself I would recomend that you take it to a repair shop and let a qualified tech assist you. The screws you need to get to are under the keyboard. The whole laptop does not need to be disassembled to swap the drive. Once you pop the speaker bazel and the keyboard you are home free. If you need more help feel free to ask.
George
Aug 03, 2008 | Compaq Presario 700 470024-192 Notebook
Disc read error
Hi P,
You have to take the case apart first, 6 screw coveres then 6 screws. Pop the top off. Get you a new laser from ebay. Take the solder blob off of the new laser when you get it. The rail to the right of the laser is retained by two holds which are held by a screw each. The arm that connects the laser to the worm gear will have to be placed on the new laser.
If your uncomfortable with replacing a laser or do not have the soldering tools to remove the shipping solder blob, you need to find a repair shop to send your Slim to for repair.
Click on "Repair Directory" at the bottom of this screen. Then on the next page, click on "Video Game Consoles" Pick a good Repair shop dedicated to repairing Playstations.
Nov 22, 2007 | Sony PlayStation 2 Slimline Console
Tv lamp replacement
I just did this myself. I'm a novice but it wasn't that hard. Your choices are to purchase a complete unit including the casing from a Sony repair shop for around $250, or just replace the lamp.
I just replaced the lamp and saved $130.
I just removed the screws from the side of the casing that protect the lamp. I disconnected the contact points and then popped open the housing.
Remove the screws and the nut that attach to the lamp. Wear gloves when you handle the new lamp so you don't shorten the lifespan of the bulb.
re-attach all the screws and slide it back in.
It took me the longest to have line up the contact points when sliding it back into the TV. Make sure all the connections are snug and keep at it. Don't give up! I'll admit I was tempted!
Oct 27, 2007 | Sony KDS-R50XBR1 50" HDTV
Lenovo IdeaPad Y510 Notebook Logo
62 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
