Question about Toyota Car Audio & Video
2006 Tyota Prius radio problem. (standard single CD , 6 speaker system) The steering wheel controls work fine, but the dashboard controls dont work. (except the tuning & volume controls) Any ideas? Can not eject CD's, scan, aux, etc.
    Top Expert:
  • Toyota Master
  • 79,077 Answers
The touch plate in back of the face of the radio is defective, Toyota doesn't sell parts to the general public, so u must have the radio repaired by a factory approved repair center, the site link below can repair the radio as well as provide assistance in the removal of the radio from the dash.
http://www.carstereohelp.com/strtoyota.htm
Posted on Sep 09, 2010
2006 toyota prius dash is not lit up. Car runs fine. Cannot see speed, fuel, etc.
Check a nob with a bulb sign on the dash or beside the steering wheel,its the control for the brightness
Sep 04, 2014 | 2006 Toyota Prius
2006 Prius - battery died, and after jump start, radio is acting strange.
The radio is likely in theft lookout due to loss of battery power. theft lockout.
Feb 01, 2018 | 2006 Toyota Prius
There is no sound coming from the speakers, not even the bluetooth. The volume control on the steering wheel and the knob also doesn't work. The radio, cd & dvd player work fine.
So everything is coming on but you have no sound from anything?If that is the case you may want to check the amp fuse.The car has a factory amp i'm trying to remember i think it is in the trunk.Look in your owners manuel for the fuse box location.If the fuse is good then the factory amp may be bad.Or you may have a blown speaker that is showing a short and putting the amp into protect.If the amp and or speakers are bad i highly recommend just buying after market speakers/amp.The price for the factory equipment is very high and there labor rates even higher lol.Plus if properly installed you will noticed better sound from the after market stuff as long as you get brand name equipment.Go to a well trusted audio shop in your area they should be able to see if it is a speaker or amp problem if your fuses are all good.They should be able to test the impedance of the speakers at the amp for you and see what is going on.
Oct 02, 2012 | 2006 Infiniti M35
Steering Wheel Control
I installed a body lift and now none of my steering wheel controls dont work any ideas
May 07, 2009 | 2005 Nissan Altima
Removal of 2008 Prius steering wheel -
with a small flat screwdriver, remove the 2 by 2 inch black plastic covers behind the steering wheel. one of them has a hole for the cruis control lever.
loosen but dont remove the two torx screws behind these covers.
allow the airbag to fall out into your hands.
carefully raise the two yellow retainers on the airbag wires, then pull the wires away from the airbag module.
then squeeze and pull the black horn wire from the airbag.
to replace the steering wheel, unplug all the wires you see and remove the 19mm nut holding the wheel.
then by hand wiggle the steering wheel toward you.
Mar 24, 2009 | 2008 Toyota Prius
2005 Toyota Camry JBL Radio Replacement: Info button issue
Crutchfield sells an aftermarket kit that allows the steering wheel controls to work, but it's $74, and you head unit must be remote control capable. They also sell a wiring harness that works with Kenwood/Toyota as long as you have the original wiring harness that came with the Kenwoood. You'll need to do some snipping and krimping however.
Mar 22, 2009 | Car Audio & Video
2006 Toyota Prius Radio Buttons inoperable
ouch thats a pricey one you have to replace the head unit there is no lock out for the buttons so if they dont work its a mechanical failure and its all one seald unit screen and all and it costs just shy of 2500.00 dollars
Mar 21, 2009 | 2001 Toyota Prius
Some of my dashboard lights are out... ie; radio preset numbers, radio controls on the steering wheel, etc. Are there fuses I should be checking?
no they just go out they are little single L E Ds inside radio and controls on the steering wheel. As for the dashboard some of the light can be replaced with bulbs but there is also LEDs in there as well. Hope it helps
Jul 27, 2008 | 1999 GMC Sierra
Car Audio & Video Logo
179 people viewed this question
Top Toyota Car Audio & Video Experts
Martin Clarke
Martin Clarke
wadingriver
wadingriver
Are you a Toyota Car Audio and Video Expert? Answer questions, earn points and help others
