Question about Canon imageRUNNER 1023N Black and White Copier
The printer copies turn out with a faint gray background through half of the copy. Its as if something is dirty and it printing the dirt.
  • 1,219 Answers
it could be few things,
Its probably drum unit fault, probably the cleaner is worn out and doesnt clean drum surface enough.Remove the drum unit and see if there is "leftovers" on drum surface and if Yes change the drum unit.
If the copie isnt baked enough that means that the fixing roller is worn out and you need to change it.
If You are using replacment toner, not genuine from Canon, also it can cause problems like bacground, dots, spots,...
Hope that helps!
Posted on Sep 10, 2010
Background on all white pages copies are gray
check printer settings or document settings back ground color settings
you can print a page color to any of the color bar settings so there is a setting that has been change to grey that is causing the problem
Dec 11, 2015 | Epson Stylus NX400 InkJet Printer
Streaks on copies
Run the printers maintenance software and run the align print head option and the run the clean print head option and check again and see if the streaking is still occurring.
Apr 10, 2014 | Canon imageRUNNER 2200
How to stop backgrounds being printed when i copy something
The optics are dirty.Use a flash light and look at the optics on the printer.I'm sure you will see their dirty.Remove glass ,Clean the mirrors in the scanner cavity with a moist cloth.Don't scratch or press to hard the mirrors are brittle.
Apr 09, 2013 | Epson Stylus CX9400 Photo Printer
Canon np 3030 copy problem
print something from the Menu or report (do not make a copy) if it comes w/ the problem. Could be dirty laser glass or toner empty. if it comes normal, It's a dirty dOCUMENT SCANNER.
Oct 20, 2012 | Canon imageRUNNER 1600 Laser Printer
Why won't my Bixolong SRP-275 print the second copy of the receipt? It only printers the first copy, and the second copy is faint at best. thanks,
So it is printing the second copy, just faint? If everything is set correctly in your pos system in regards to fonts, etc, then unfortunately that sounds like a hardware problem. It could possibly be the power supply failing not supply enough current to drive the thermal head, or a main board problem, or even the thermal head might be failing. You could try cleaning the thermal head (black shiny thing you can see when you lift lid up) with isopropyl alcohol. Failing that you need a tech.
Feb 04, 2011 | POS X BIXOLON Samsung Kps SRP350 Thermal...
Gray background
if you have a laser printer you may need to clean the printer or install a new drum cartridge, if it is ink-jet you will have to clean the bottom of the ink cradle it sound like you getting grey background from a toner/drum cartridge.
good Luck
Let em know if this helps.
Jan 29, 2009 | HP LaserJet 1200 Printer
Mfc 5840cn acts like its printing but does not
is this when printing from pc or just making copies? if its about copying, gray background may be caused by the scanning mechanism.
Nov 18, 2008 | Brother MFC-5440CN All-In-One InkJet...
Toshiba 3550 Copier - Printing a faint ''gray'' band over text
Depending on how many copies you have run, the drum as well as the cleaning blade needs to be replaced.  That should get rid of the gray band.
Nov 11, 2008 | Gestetner DSc224 Copier
Sharp ARM162 faint copies
Your macchine might need a PM
A few possiblities
Open the right side there is a transfer on the piece that slides out, That is the Transfer, check the wire see if it is broken, if it is broken, call a tech, or if not broken try to clean this with a can of air.
The charge might be dirty, the developer might be bad, is the machine level?
Could also be in need of a new drum.
The optics might be dirty.
But most likely a charge somewhere is dirty, or the developer is bad.
I would call a Tech for a PM (PM is new drum, developer, charge, and a decent tech will clean the optics and machine)
Oct 23, 2008 | Sharp AR-M277 Black and White Copier
Canon imageRUNNER 1023N Black and White Copier Logo
153 people viewed this question
old marine
old marine
