Question about Kenmore 62463 Microwave Oven
The lights work, the timer works, the clock works however with out warning the turn table and microwave do not work. What is the problem Microvave model: 62463
  • greg_samp83 Sep 09, 2010
    The lights still work inside the microwave, the clock and the timer. The turntable will not work ether will thw microwave. How do I check this high?
  • 11,800 Answers
You need to open it up and test the power source - it looks like the high voltage output is faulty.
Posted on Sep 09, 2010
  • Azrael SRL Sep 09, 2010
    You need to open the case of the microwave and, using a very good voltage meter, with a high tension setting, check the voltage at the motor of the table and at the magnetron. If the tensions are missing then the power source is faulty and will have to be replaced.
    Beware, the tension there is well above 1000 volts, if you don't know what you're doing it could easily kill you. If you aren't absolutely sure you can do that safely then take the microwave to a repair shop.
Microwave light and clock work but no heat
Could be one of the three door switches. If the fan turns on when cooking and no heat then the magnetron is bad. Most problems are the switches
Feb 20, 2014 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave has power, but nothing works.
The door switches are more than likely the problem, one or two will need to be replaced, I recommend a professional.
Mar 18, 2012 | Panasonic Microwave Ovens
My Frigidaire microwave stopped working while cooking food.
All lights are operational. Model number is FMV156DBC.
Aug 29, 2009 | Frigidaire FMV156DC Microwave Oven
Clock works, timer works-but turntable and other functions stoppe
you have a bad control board . this board had 2 relays one for the magntron and one for the turntable and the cooling fan together . when the turntable goes out so does the cooling fanm and the microwave overheats ...... there is no good fix for this , the control will cost more than a new microwave . please do not use with this happening . i have see them start on fire when it overheats . please be carefull good luck
Jan 15, 2009 | Emerson MW8108P Microwave Oven
Emerson Microwave MW8115SS
there is a thermal fuse inside that is likely blown.
easy to replace just have to google bullet thermal fuse.
May 11, 2008 | Microwave Ovens
Microwave Oven EM-804T
You need to trace the power feeding the high voltage transfomer. Because the table doesn't turn, it implies that a door switch or safety interlock is the problem.
Jan 01, 2008 | Microwave Ovens
Kenmore 62463 Microwave Oven Logo
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
