Question about Paragon 4001-00 24-hr Timer Control 120v Ac Cd101
Need a programing Manual for a Paragon electronic timer, used for bells.
Paragon 4000 is a mechanical dial-type timer
You probably have Paragon EC4000 digital timer:
Single channel, NO, NC contacts, SPST with 5 poles or SPDT with 8 poles.
To identify your timer: Paragon 4000-7000 series
If you have EC4000, the following pdf files are helpful
EC4000 Sale sheet
EC4000 Programming
Posted on Oct 01, 2010
Need a manual for paragon timer EC 74/120D
Try Googling (paragon)(EC 74/120D)(manual) without parens.
Nov 11, 2013 | Paragon 4001-00 24-hr Timer Control 120v...
Need New LCD for Paragon EC71/18S Single Channel Electronic Control
Paragon EC71 single-channel timer is no longer available.
Replace with Intermatic ET series.
ET1700 series for 7-day.
ET70115 for 365 day
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#ET1100-1700
http://waterheatertimer.org/Paragon-timers-and-manuals.html#EC71
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 12, 2011 | Paragon 4001-00 24-hr Timer Control 120v...
I need to read a manual. I can't get my timer to turn on my outdoor Christmas lights.
You posted under Paragon 4001 120Volt timer
If this is not your timer, look at next page to identify timer
Or add a comment
Paragon 4000 series manual
http://waterheatertimer.org/pdf/Paragon-4000-series.pdf
4000 series uses X2772 tripper
Clock dial rotates with passing time.
If you need more help, add a comment.
Dec 08, 2010 | Paragon 4001-00 24-hr Timer Control 120v...
Lost instruction manual. How do I progam my Paragon Electric timer Model EC7004/120
Link below has Paragon EC7000 series timers and manuals
EC7004/120 is 7-day programmable timer.
Single channel 120Volt SPST NEMA1 indoor timer.
Program up to 16 events per week
EC7000 series programming manual shows wiring, explains keypad, has steps for setting current time, and shows 24 steps for programming timer. Plus troubleshooting.
It is impractical to write out those steps when they appear in manual.
http://waterheatertimer.org/pdf/Paragon-EC7000-04-05-manual.pdf
EC7000 series Sell sheet with model numbers
http://waterheatertimer.org/pdf/Paragon-EC7000-sell.pdf
Description of model numbers at Uni-line
http://www.uni-line.com/modules/catalog/SearchResults.aspx?catName=19030&pID=19029&mode=categorysearch
Dec 01, 2010 | Paragon Amf 7008-00 Timer 7 Day 120 Volt...
I am in need of a manual for a Paragon EC128 energy control system
Open following link to identify timer and for possible manual, shows image of EC74 4-channel timer and manual
http://waterheatertimer.org/Paragon-timers-and-manuals.html#EC74
I believe the EC128 is 8 channel timer with same programming as EC74, except the timer has more contactors, and more individual programs.
Add a comment and say if the manual matches.
Otherwise, my searches for EC128 manual have turned up nothing and your input would be useful to others.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Nov 21, 2010 | Paragon 4001-00 24-hr Timer Control 120v...
My paragon timer4001-ov runs but will not trip on/ off trippers if this cannot be repaired what would be a good replacement for 120 volt supply
I don't see the 4001-ov in the Paragon spec sheet
http://waterheatertimer.org/pdf/Paragon-4000-24hr-7000-7day.pdf
To test the general condition of your Paragon timer, use the manual override.
If the manual override works perfectly, then you may need new tripper pins.
The Paragon 4000 series uses X2772 tripper pin.
Google search Paragon X2772 tripper turns up prices of $9 for a pair of trippers
A simple 120V replacement timer is the Intermatic T-101
For outdoor, use the T-101R 'R' for raintight
Lowes usually has the T-101 on the store shelf and they sell the T-101R online
http://www.lowes.com/pd_29405
http://www.aplussupply.com/intermatic/timer.htm
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T101
Oct 28, 2010 | Paragon 4001-00 24-hr Timer Control 120v...
I have a EC4000 electronic digital timer. The problem is when the timer hits a preset time to turn the boiler on , the boiler will not turn on, but when I hit the manual override button on the timer the...
Paragon EC4000series are programmable timers
EC4000/120 for 120V
EC4000/277 for 208-277V
Is this a new installation?
Or was timer working fine until recently?
1) With digital programmable timers like EC4000, if there is conflict in programming, or missed program, then timer might skip the program.
For example if program1 says ON at 7 and OFF at 8, and program2 says the opposite.
2) If wiring is reversed, then the manual override will work but clock will not operate, and the timer will not function.
a) for 120V timer:
-120V black wire from breaker goes to terminal2
-120V white wire from breaker to terminal1
-jumper wire from terminal2 to terminal3
-Load black wire to terminal4
-Load white wire to terminal1
b) for 240V timer
-240V Hots from breaker go to terminal1 and 2
-Load wires connect to terminal4 and terminal1
Below is link to EC4000 instruction manual
http://waterheatertimer.org/pdf/Paragon-EC4000-program.pdf
Troubleshooting steps say to review set-points.
Solutions:
Checking wiring as described above
Check programming.
Reset timer and re-program set times.
If you need more help, add a comment at bottom
Oct 26, 2010 | Paragon 4001-00 24-hr Timer Control 120v...
Paragon 4001-00 24-hr Timer Control 120v Ac Cd101 Logo
785 people viewed this question
Top Paragon Hardware & Accessories Experts
Gene Haynes
Steve
jdthefixer
Are you a Paragon Hardware and Accessory Expert? Answer questions, earn points and help others
