Question about Texas Instruments Office Equipment & Supplies
Imy TI-83 plus calculator won't let me multiply by negative exponents.
  • kakima Sep 09, 2010
    Are you using the (-) key to enter negative exponents? The - key is for subtraction, the (-) key to the right of the decimal point is for negation.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
Having gone over a month without a response to my query, I assume it was simply a matter of using (-) instead of -.
Posted on Oct 15, 2010
How to get a negative exponent
Use the (-) key just to the right of the decimal point key.
Nov 10, 2013 | Texas Instruments TI-83 Plus Calculator
How to enter exponents
If you mean an exponent of ten, use the EE function (the shifted function of the "," key, located just above the "7" key. For example, to enter 1.2 times ten to the negative 3, press 1 . 2 2ND [EE] (-) 3
To raise a number to an exponent, use the ^ key located just above the divide key. For example, to calculate 3 raised to the 4th, press 3 ^ 4 ENTER
Sep 26, 2011 | Texas Instruments TI-83 Plus Calculator
I have a TI-83 plus calculator. I put into the calculator 96-5.970 ^2 multiplied by 0.2723 and it gave me the answer 2.4507 ^E- 4 Is there anyway to get the answer to the decimal value instead of it...
2.4507E-4 is scientific notation for 2.4507 times ten to the minus 4, or .00024507.
Take the 2.4507 and move the decimal point, to the left if the exponent is negative, to the right if it is positive, the specified number of positions.
If the magnitude of the result is too small or too large, the calculator will automatically switch to scientific notation. Imagine a number that has more than 12 digits to the left of the decimal point. How is that going to fit onto the display? Or a number that is 0 followed by the decimal point followed by 12 0s and then some significant digits?
Jun 21, 2011 | Texas Instruments TI-83 Plus Calculator
How do i multiply fractions on texas instrument TI-83 calculator
The division sign acts like a fraction on the ti-83; to multiply two fractions you may want to wrap them both in parenthesis to get the order of operations correct.
Vote early and often
Sep 24, 2010 | Texas Instruments TI-83 Plus Calculator
I need to know how to enter anything above cube root into my TI-83.
  1. Use the universal power key marked with [^].
  2. To avoid problems if the exponent is an expression, enclose it in parentheses.
  3. To enter any power type number^(exponent)
  4. If exponent is negative use the (-) change sign key next to the dot, below the 3 key.
  5. To calculate the roots (cubic, fourth, fifth, etc.) roots use the fact that a root of n-th order can be represented as ^(1/n)
  6. Ex: cube root of 27: 27^(1/3); square root of 64 : 64^(1/2) or 64^(0.5)
Feb 26, 2010 | Texas Instruments TI-83 Plus Calculator
What button do I use to find negative log on my TI-83 calculator...also how do I put in a negative exponent?? i.e 1*10 to the negative 6th .....
You compute the negative of a logarithm the same way you compute the negative of anything else. However, do you really mean the antilog (inverse logarithm)? Use 2ND [e^x] for the natural antilog, 2ND [10^x] for the common antilog.
For negative exponents, as well as negative anything, use the (-) key next to the decimal point. For your example, 1 EE (-) 6
Feb 25, 2010 | Texas Instruments TI-30XA Calculator
I don't know how to multiply by a negative exponent. ex: 10(-8) ....the -8 is the exponent.
Press [2nd][,] to activate (EE) which appears on screen as a lower case E, enter the change sign (-) right of the [dot] on the bottom row of keys, enter the value of the exponent.
Ex: Enter Avogadro's number of Generalk Chemistry fame
6.02[SHIFT][,] (EE) (-)23
Here is screen capture of what it will look like.
Feb 23, 2010 | Texas Instruments TI-83 Plus Calculator
How to use negative exponents on a calculator?
Uh yes it will allow you to enter a negative exponent.... press the numbers you want then hit EXP button, then hit the +/- button and then the exponent. 60 % of the time, it works...... everytime.
Sep 20, 2009 | Texas Instruments TI-83 Plus Calculator
Multiplying exponential numbers
I am needing to find out what key I can push for an exponent. I have an exponent that is 2520 and I dont know what button to push for it.
The problem is as follows:
3000 ( 1+ 0.06/360) exp.2520
3000 ( 1.000166667) exp. 2520
3000 - 4565.72
Final Answer
1565.72
Now how in the world did they get 4565.72. What buttons am I needing to push.
Mar 12, 2009 | Texas Instruments TI-83 Plus Calculator
TI-83 Plus No Longer Squares Correctly
when you type -2 imagine your calculator doing the equation: -1 x 2. The - sign actually stands for a -1 so when you do -2 squared your calculator is simply following order of operations. It first squares the 2 making it 4, then it multiplies the negative making it -4. In order to get around this you must use parenthese. (-2)^2.
Hope this helped
Nov 20, 2008 | Texas Instruments TI-83 Plus Silver...
406 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
