Question about GE Refrigerators
I have a TAX4DNCBL GE fridge, small dorm like size that is not cold inside. the outer walls feel cold.
  • 101 Answers
Sounds like sealed system problem
Posted on Sep 10, 2010
My freezer frosted over everything because the door was not shut tight and now it will not clear.
take out all the food out of the freezer,unplug the fridge and get a hair dryer and start melting out all the ice in the freezer,then blow the hot air into the vent holes on the back wall until you don't see any more water dripping down through the slots in the back wall.turn the machine back on,open the fridge door after around 5 or 10 minutes and if you feel cold air blowing into the fridge you fixed the problem,if you don't feel cold air keep hitting the inside back wall with the hair dryer and keep blowing the hot air into the holes in the back wall.all that it does is the freezer gets cold and there's a fan behind the back wall in the freezer,the fan blows the cold air into the fridge side,if the air ducts are frozen the air can't circulate into the fridge section so you have to melt the ice out so the cold air can blow from the freezer to the fridge.good luck,if you have another fridge remove the food and unplug it and leave the doors open for a day and it will melt out.good luck
Jun 16, 2011 | Kenmore 65234 Bottom Freezer Refrigerator
I have a side by side GE fridge. The freezer is working fine, but the fridge part won't get cold.
Is the freezer frosted up on the back wall (inside)? Check the settings. Both controls should be in the middle of the range.
Jan 30, 2011 | GE Refrigerators
The refrigerator is not cooling properly. Two small vents on the inside wall. one is producing cool air the other is not. The freezer works fine.
Your defroster timer switch may be at faught. The defrost timer turns on a heating coil to defrost your frige. This is only a guess since I don't have the year. Do this: feel the walls if they are hard and they have no give to them, then your fridge is frozen up solid and no air can circulate. Unplug you fridge for 24 to 36 hours. Put towels on the floor to catch the water. If the defrost timer is bad it will defrost naturally with room temp. Plug back in after 24 to 36 hrs and see if bottom is now getting cold. If it is the defrost timer, the solution is not cheap. It's up to you to repair or invest in new. Good luck Google burdfrenzy
Nov 26, 2010 | GE GSS25LGM Side by Side Refrigerator
Fridge will not get cold
Was your fridge transported upright at all times? There are warnings on most brands not to lay them down due to potential damage. If that was not the case, those small units are often easy to repair.
[Note to garing: The person said there was no ice anywhere but on the back. Dorm sized refridgerators are rarely frost free, so your answer was pointless.]
Aug 17, 2009 | Haier HSB03 Compact Refrigerator
I just bought a RoadPro 2500 and i want to buy like a dorm fridge how many watts or volts size would work??
If you are referring to the RoadPro RPPI-250
  • 2000 Watts Continuous Power
  • 2500 Watts Power Output @ 10 Minutes
  • 5000 Watts Peak Power Output.
  • A small fridge will use about 500 -700 watts, with startup wattage at around 2000watts.
  • So, a dorm fridge will work fine.
  • the RoadPro converts DC to AC voltage, so a regular 120 volt dorm fridge will work.
  • Jul 05, 2009 | RoadPro RPPI-2500W Inverter
    Freezer works, fridge not cooling but water was leaking from under fridge a few weeks ago, could not find source . Small compact frigidaire unit for dorm room.
    Most if not all fridges under $2000 only use a single compressor meaning the refrigeration is provided by venting the freezer air into the compartment. Water under the unit likely indicates the fridge is not properly sealing and moisture is condensing on the cold coils and dripping.
    Jun 24, 2009 | Refrigerators
    GE Side By Side top portion of fridge and freezer not cooling
    Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
    Refrigerator not Cooling or Fridge not Cooling
    How to Defrost Refrigerator Defrost Timer Problem
    Water Running in refrigerator from Freezer
    Refrigerator or Freezer not Cooling or Getting Cold
    heatman101
    Jan 28, 2009 | GE Hotpoint Top-Freezer Refrigerator
    I was given a small fridge. It was built by GE and is not but a few years old! It will turn on but will not cool! Please give me some troubleshooting tips to try to fix this thing!
    Most of the dorm sized refrigerators is see that run but dont cool have a sealed system problem which is either a leak or compressor problem. Look in the small freezer section. many times, people are too impatiant to defrost them properly and use a tool to chip the ice away and inadvertantly puncture a hole in the tubing causing a leak. Seen that happen quite a few times.
    Jan 26, 2009 | Refrigerators
    Fridge running but not staying cold
    you have a defrost problem, if SxS ref. most likely bad defrost heaters. They are behind interior back wall. Sounds like you have a GE.
    Jan 05, 2008 | Refrigerators
    Refrigerators Logo
    206 people viewed this question
    Top Refrigerators Experts
    Sal De
    Charles T Nevin
    Charles T Nevin
    Randy Justice
