Question about Smart Parts Shocker NXT Paintball Gun
My gun just beeps when i pull the trigger even when hooked up to hpa.battery is new.last time i used the gun just before it messed up i had it hooked to o2 and it would fire then beep ,i have a anti syphon tube installed to. the air shot out the asa instead of the reg when i took off the tank.usually gun holds air with tank off then you shoot it to get rid of stored air,this time it shot out the asa????
    Problem Solver:
  • 15 Answers
You have probably messed up your solenoid, did you fire the marker straight up with the o2? I would make sure that all of the board settings are back to factory default especially the dwell and reattempt with compressed air. If the marker is still not firing get your hands on a new solenoid for it.
Posted on Jan 04, 2011
Phase three on cv or cc have current going to mig wire, wire is live without hitten gun trigger. mega arc is hooked up to a Hobart suitcase
May need to take gun apart and see if trigger is sticking or replace lead.
we use Miller at work. The feeder has a switch that makes the trigger turn off and on with quick pull of trigger so you don't have to hold it entire time.
check wiring to make sure it's wired right so your not bypassing the trigger switch.
hope it helps.
Nov 02, 2015 | Hobart Welding Tools
My new porter cable RN175B nail gun won't discharge a nail
If the trigger is set to single fire, you will need to place the gun against the work then pull trigger as you have done. Try setting the trigger to bump fire and try again. If hear a thump inside the gun, remove the head and check that the head valve in not stuck from lack of lubrication. Easy test, remove the nails, remove trigger pin, remove trigger and manually push trigger firing valve. If the gun fires then suspect faulty trigger or safety arm not lifting enought to activate the trigger valve. Good luck
Nov 21, 2012 | Air Tools & Compressors
Pneumatic stapler trigger stuck
The click sound indicates that the headvalve opened to fire piston down the barrel, however piston is already down or is stuck in-place. If the piston/driver is not broken or stuck, push piston to top of cylinder to reset. If only one shot and piston stays down, most likely the check band is broken. Check band is on the outside of cylinder (lower part) is is usually an oring or band of rubber covering small holes drilled into cylinder. Check valve /band is what causes the piston to return to top. If check band is good, most likely piston is bent or oring is too tight. If you open the gun, lube all parts with white grease or silicone paste lube. Good luck
Nov 03, 2012 | Air Tools & Compressors
NEW BRAD NAILER ONCE LOADED WILL NOT WORK
Many modern brad and finish nails use a sequential fire trigger system. You have to push the nose of the tool down to depress the safety THEN pull the trigger. This is the opposite of how a bottom fire works where you hold the trigger and bump the nose to fire the gun.
Mar 02, 2012 | Air Tools & Compressors
I have response trigger on my a5 and only shots one shot at a time when pointing straight. When i raise the gun to the air and shot it response trigger works. What could be the problem?
If you are using CO2 it may be affecting the system. With a gun down straight, you could draw liquid CO2 into the internals. A siphon tube can be installed in a CO2 tank to stop or manage this. If you have access to someone's air tank, try using HPA (high pressure air aka nitrogen). If it fires fine with air you have deducted that the CO2 is to blame. Simple. Switch to air. It's better for the gun anyway! Now if the air didnt change anything I would think a component of the response trigger system is to blame. I am not familiar with the response trigger( I use E-grips) but I would think that a part that may slide or move forward or bak when you lift the gun up would be to blame. Most local shops should be able to diagnose the problem. I did find an installation video by Tippmann on youtube.
Here is a link.
A5 response kit installation
Mar 31, 2011 | Tippmann A 5 Standard Paintball Gun
Builds up to much pressure in hose and stalls engine
Sounds like the unloader is not working. try replacing it and see if that helps.
Mar 16, 2009 | Campbell Hausfeld PW2102 Gas Pressure...
Air leaks arond trigger when depressed, but no nail fires.
Where does the air leak out from? If it leaks from the trigger DeWalt makes a trigger valve assembly part # 641006-00 list 8.89 BUT if it leaks from other areas we have to look into it deeper. If it is just the trigger valve let me know and I will give you instructions how to remove and install the new one.
Feb 05, 2009 | Dewalt Round Head Framing Nailer D51845
Arrow Fastener Co./Electric Staple Gun - ETF50BN
First make sure no staple is jammed between the hammer and the anvil or plunger and you might also try to spay with pb blaster or wd 40 and pull yhe trigger several times very rapidly and see if this will free plunger , does work to free sometimes
Jan 22, 2009 | Arrow T50P ARROW STAPLE GUN
Smart Parts Shocker NXT Paintball Gun Logo
73 people viewed this question
Top Smart Parts Sport & Outdoor - Others Experts
Are you a Smart Parts Sport and Outdoor - Other Expert? Answer questions, earn points and help others
