Question about Husqvarna "Chain Saw - 16" Bar, 3 Hp
I have a problem keeping my saw to idol, other than that it runs fine. what are my options?
    Habit-Forming:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 87 Answers
The idle screw is not marked. It is the only screw that is not protected.
The H and L screws directly connected to the carb are for the fuel to air ratio on your carburator. There is the Low one and the High one each have to be adjusted to work together with the other.
Check all your screws to the head or for any air leaks on the gasket that connects the cylinder head to the chassis. Also check all vacuum hoses. And fuel hose for leaks.
Posted on Aug 27, 2014
    Scholar:
  • 111 Answers
Adjust the Low idle screw so that it doesn't die out. On most saws, to adjust the idle, look for an opening that has an L next to it (there is also one for high idle speed with an H next to it). Use a small screwdriver, and be careful--many of the idle adjustment screws are plastic so you don't want to strip it.
Posted on Oct 06, 2011
Starting issues after fueling
Sound like water in your fuel tank. Get heet and try that.
Feb 22, 2014 | Cars & Trucks
Have a 1992 toyota corolla 3 speed auto, that shakes when stopped at a stop light, and when you take off it runs fine. changed plugs cap and rotor and still does it..
Check your engine idol. It could be that your idol speed is set to low. It should probably run at between 800 and 1000 RPM. If it is not then your idol is to low.
Jan 03, 2011 | 1992 Toyota Corolla
My saw runs fine for about five minutes then shuts off while its ideling. why does it do that and how can i fix it?
If it is a new chain saw, then what it is, is that they set the carb to run a higher idol until the motor breaks in once this happens you have to change the low idle on the chain saw to help balance everything out. Do it in short 1/4 turns until you get it just right. Your owners manual will show you which one is high and which one is low. Please rate
May 25, 2010 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Po507 could that be the idol air control
did you replace both 02 sensors? 02 sensors and camshaft position sensor do most of the engine timing. A bad vacuum hose will throw the timing off as well.
Sep 21, 2009 | 2002 Mitsubishi Galant
I cant get my rm 125 to idol
But it runs fine other wise? as long as you keep it above idle runs fine but then dies at idle? id so then you need to clean the carbs the slow jet is dirty. hope this helps
Jun 27, 2009 | 2003 Suzuki RM 125
Car wont idol but runs fine when pressing on gas pedal
either the tps is out of parameters or you need to adjust the idle up a bit
Apr 16, 2009 | Toyota Camry Cars & Trucks
Check engine light on,idols rough,fine at all other speeds.
I decided to check the idol air control valve,when I removed it I found the problem right behind it. The P C V valve hose was just about into where it fastens to the intake,the other end was bad also. Cost me aout $6.00 Where auto parts stores were telling me parts would cost two or three hundred $$.
Jan 20, 2009 | 2001 Ford Escort ZX2
Vehicle in hi idol
plug the pcv hoses back up listen for a vacuum leak
Oct 20, 2008 | 1993 Ford Explorer Limited
Husqvarna "Chain Saw - 16" Bar, 3 Hp Logo
176 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
