Question about SUMMIT Professional Refrigerators
Outdoor refrigerator Model# spr62os dosent work. Main power switch on bottom wont saty on....and previous to that it wasnt cooling.
  • SUMMIT Profe... Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Sep 11, 2010
How do I get the fault codes up on a Panasonic split air conditioning system CUE24FKR
14.2.2 To Make a Diagnosis1 Timer LED starts to blink and the unit automatically stops the operation.
2 Press the CHECK button on the remote control continuously for 5 seconds.
3 "- -" will be displayed on the remote control display.
Note: Display only for "- -" (No signal transmission, no receiving sound and no Power LED blinking)
4 Press the TIMER ? or ? button on the remote control. The code "H00" (no abnormality) will be displayed
and signal will be transmit to the main unit.
5 Each press of the button (? or ?) will increase error code
number and transmit error code signal to the main unit.
6 When the latest abnormality code on the main unit and
code transmitted from the remote control are matched,
Power LED will light up for 30 seconds and a "beep" sound
(continuously for 4 seconds) will be heard. If no codes are
matched, Power LED will light up for 0.5 seconds and no
sound will be heard.
7 The breakdown diagnosis mode will be canceled unless
pressing the CHECK button continuously for 5 seconds or
operating the unit for 30 seconds.
8 The LED will be off if the unit is turned off or the RESET
button on the main unit is pressed.
Diagnosis
display Abnormality / Protection control Abnormality
Judgement Emergency operation Primary location to verify H00 No abnormality detected - Normal operation H11 Indoor / Outdoor abnormal communica
tion > 1 min after starting
operation Indoor fan operation
only • Internal / external cable connections
• Indoor / Outdoor PCB H14 Indoor intake air temperature sensor
abnormality Continue for 5 sec. - • Intake air temperature sensor (detec
tive or disconnected) H15 Outdoor compressor temperature sensor
abnormality Continue for 5 sec. - • Compressor temperature sensor
(detective or disconnected) H16 Outdoor Current Transformer open cir
cuit - - • Outdoor PCB
• IPM (Power transistor) module H19 Indoor fan motor mechanism locked 7 times occurance
continuously - • Indoor PCB
• Fan motor H23 Indoor heat exchanger temperature sen
sor abnormality Continue for 5 sec. O
(Cooling only) • Heat exchanger temperature sensor
(detective or disconnected) H24 Indoor heat exchanger temperature sen
sor 2 abnormality Continue for 5 sec. - • Heat exchanger temperature sensor
(detective or disconnected) H27 Outdoor intake air temperature sensor
abnormality Continue for 5 sec. O • Outdoor temperature sensor (detec
tive or disconnected) H28 Outdoor heat exchanger temperature
sensor abnormality Continue for 5 sec. O • Outdoor heat exchanger temperature
sensor (detective or disconnected) H30 Outdoor discharge air temperature sen
sor abnormality Continue for 5 sec. - • Outdoor temperature sensor (detec
tive or disconnected) H33 Indoor / Outdoor wrong connection - - • Indoor / Outdoor supply voltage H38 Indoor / Outdoor mismatch (brand code) H50 Ventilation motor abnormality 7 times occurance
• Ventilation motor H51 Nozzle lock abnormality 2 times occurance
continuously - • Nozzle H52 Limit switch abnormality - - • Indoor PCB H97 Outdoor fan motor mechanism locked 2 times occurance
within 30 minutes - • Indoor PCB
• Fan motor H98 Indoor high pressure protection - - • Air filter dirty
• Air circulation short circuit H99 Indoor heat exchanger anti-freezing pro
tection - - • Insufficient refrigerant
• Air filter dirty F11 Cooling / Heating cycle changeover
abnormality 4 times occurance
within 30 minutes - • 4-way valve
• V-coil F90 PFC control 4 times occurance
within 10 minutes - • Voltage at PFC F91 Refrigerantion cycle abnormality 2 times occurance
within 20 minutes - • No refrigerant
(3-way valve is closed) F93 Compressor rotation failure 4 times occurance
within 20 minutes - • Compressor F95 Cool high pressure protection 4 times occurance
within 20 minutes - • Outdoor refrigerant circuit F96 IPM (power transistor) overheating pro
within 30 minutes - • Excess refrigerant
• Improper heat radiation
• IPM (Power transistor) F97 Outdoor compressor overheating protec
within 10 minutes - • Insufficient refrigerant
• Compressor F98 Total running current protection 3 times occurance
within 20 minutes - • Excess refrigerant
• Improper heat radiation F99 Outdoor Direct Current (DC) peak detec
tion 7 times occurance
continuously - • Outdoor PCB
• Compressor
Note:
"O" - Frequency measured and fan speed fixed.
The memory data of error code is erased when the power supply is cut off, or press the Auto Switch until "beep" sound heard following by pressing the "CHECK" button at remote controller.
Although operation forced to stop when abnormality detected, emergency operation is possible for certain errors (refer to Error Codes Table) by using remote controller or Auto Switch at indoor unit. However, the remote controller signal receiving sound is changed from one "beep" to four "beep" sounds.
Oct 13, 2017 | Panasonic Heating & Cooling
I have a kenmore bottom freezer refrigerator model # 795.78304.804 bout 10are11years old just stopped working nothing will come on . checked power at box and it's good
main switch/thermostat control inside of fridge needs replacing...to prove...tap/bump switch a couple of times and you should hear fridge power up...if so replace switch/thermostat...
Oct 16, 2016 | Kenmore Refrigerators
The camera s 730 works poperly in doors but dosent take pictures outdoors ( after taking the picture it show a the picture as a white screen ) pl. help asap as i am with my family for a vacation pl...
Problem with the Samsung Digimax S730 Digital Camera the camera s 730 works poperly in doors but dosent take pictures outdoors ( after taking the picture it show a the picture as a white screen )
Jul 14, 2011 | Samsung Digimax S730 Digital Camera
Fujitsu AST12LSACW - The green timer light is blinking on the indoor unit. The unit is in cooling mode but the compressor dosent come on and only the indoor fan operates. There is power to the outdoor unit...
Compressor contactor relay struck or relay not activated. Remove L1 and L2 wires and jumper with L1 with T1, L2 with T2 and check now. Be careful. It's only checking. When compressor starts, switch off and replace contactor relay.
Jan 27, 2011 | Refrigerators
Frigidaire frs26r4a the freez and fridge stoped cooling found evaporator was cold but fan wasnt working replaced fan still did not work whats keeping the fan from working thanks
Either the defrost timer or the door switch...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 19, 2010 | Frigidaire FRS26R4A Side by Side...
I have a 1991 model gmn100-4 furnace and air con power supply 115 volts 1ph60hz less than 12 amps my problem is when fan moter kicks in the air unit does not i checked and theres power from breaker box to...
Hi Jimmy, yes, I bet it is hot with that high humidity. From what you are saying, it sounds to me like this pusher switch is the contactor at the out door unit. It has the power lines going into it, and out the other side. It will have contacts on it that you can push down, is this what you are talking about when you say pusher switch? The indoor unit is 115 volts, you are right about that, but the outdoor unit contactor/pusher switch is 230 volts. You should have a box mounted by the outdoor unit for high voltage. Most all of the disconnect boxes have 2- 30 to 35 amp fuses inside them. You may not see them, so pull the plug and the plastic cover in the box to see if you have them. If you do, you may have blown a fuse. Replace both of them. This box is powered by a breaker at your main panel also. You will have a double pole breaker and make sure its not tripped. This contactor has a 24 volt coil on the bottom of it and is energized by the thermostat which closes the contacts to send power through to start the unit. You have to have 230 volts there. Turn the stat on cooling and go out to see if the pusher/contactor switch is energized. If so and the unit is not on, you have no high voltage there to run it, so check for fuses and the main breaker. You have power to the indoor unit, but not the out door unit. Start here and do these checks. Keep me posted on this Jimmy, and get back to me if this does not start the unit or if you trip a breaker. I will be watching for you. We will get it going. If this does the trick, be sure and rate me kindly as I know you will. Keep me updated by my user name below.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor.
Aug 02, 2010 | Goodman Heating & Cooling
Freezer working but refrigerator is not cooling
if freezer is close to zero, top to bottom, and fridge is warm(ing), then you likely have a defrost problem, you will notice an abundance of snow/frost on back wall of freezer. it could either be your heater, thermistor, defrost safety thermostat, or your defrost control/main cpu, depending on model. if either or both sides are warm at the top, and cold at bottom, then your freezer fan is out. again depending on your model, it may just be the fan, or a combination fan/main cpu board hope this helps
Feb 15, 2010 | GE Profile PSW26P Stainless Steel Side by...
20.8 cu frost proof modelfrt21gnh. compressor wont come on. has been unused since aug. 08. the original problem was it wasnt cooling on freezer or bottom, now compressor wont come on when plugged in. the...
You may have a blocked capiliary tube or the refrigerant has leaked, sadly domestic fridges have a conciderable amount to go wrong with them, but based on the order you discribed you have a blocked cap tub and now it has progressed to cuase the compressor to trip on over load or you have experianced a burn out. you may with to consider junking it and get a new fridge as the repair costs will be considerable!
Aug 11, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
Bottom wont stay cold top frezer it work bottom ref. wont saty cold and the light work and the fan blowing so im looking for why it wont stay cold at the bottom reg.
make sure you don't have the air flow passages in the back of the freezer blocked with food items or frost. if you have alot of food or items in the freezer and its packed tight it won't let the cold air circulate into the bottom unit
Jul 24, 2009 | Refrigerators
Power surges in area now it wont frezze and barely cools down on food side
WELL IT SURE WASNT THRU YOU GUYS AND YOU SO CALLED FREE ADVICE SECTION --- ITS ALWAYS ABOUT THE FUCKIN MONEY ----HAVE A GREAT DAY
May 17, 2009 | Frigidaire FRS26R4A Side by Side...
Refrigerators Logo
85 people viewed this question
Top SUMMIT Professional Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a SUMMIT Professional Refrigerator Expert? Answer questions, earn points and help others
