Question about Refrigerators
I have a Frigidare model FRS23R4A, side x side refrigerator. The refrigerator section is freezing up. We have continually reduced the setting to 1. What is the fix?
  • Refrigerators Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 11, 2010
Frigidare model frs22zrg side by side Refrigerator,frezzer side keep freezing up, don't think heater coming on to defrost
This is very possible. If the ice is building up. You will have to remove the freezer panel and check the heater first for continuity. If it is good then it is more than likely the defrost thermostat. if they are both good then the defrost timer or control is the problem.
Aug 14, 2014 | Refrigerators
Model FRS23R4A - loud humming noise coming from inside freezer section at top behind the ice maker. What might this be?
Somebody hiding in your freezer? Na, I'm just kiddin! Sounds like an evap fan going bad on ya. Eventually you will need to replace the fan!
Thanks and please rate me!
Tips Provided by: www.HoustonRefrigeratorRepair.com Brian Gillespie (GOFAR Services, LLC)
Aug 26, 2011 | Frigidaire FRS23R4A Side by Side...
Our refriderator is freezing stuff when it is set to a lower setting
turn down the freezer, for starters. Troubleshoot here: http://www.frigidaire.com/manuals.aspx
Sep 11, 2009 | Frigidaire FRS23R4A Side by Side...
My frig is doing exactly what is described by sass97 on jul 25 ,2008 .frigidare phsc39eess5. email is shan @teleport.com
Hi, could you please be more specific to your exact problem. Once I have more information I will be more then happy to assist you further. Please don't reject my solution until I get a chance to do so.
Thank you,
Lee
Jul 26, 2009 | Frigidaire FRS23R4A Side by Side...
I have upright frigidare frezer model fu2064dwi how can I check the capacitor, it is not rattling
The capacitor won't rattle good or bad. The compressor starter/overload relay is probably what causes most compressor starting problems if the compressor is ok. It will rattle if bad and show continuity with an ohm meter upright and not when it's upsidedown
Jul 01, 2009 | Frigidaire FRS23R4A Side by Side...
Water not entering freezing tray on frigidare side
Try replacing the washer in the solenoid valve. Sometimes it leaks by enough to freeze in the dispensing tube.
Feb 23, 2009 | Kenmore 53642 / 53644 Side by Side...
Fridge keeps freezing thing
HI thanks for your question. the factory setting is ok. try to adjust the other setting to a higher# try this give it some time to adjust and set the other to a lower# thanks
Oct 15, 2008 | Frigidaire FRS23R4A Side by Side...
Refrigerator model NoGC20C7C3Ewith fridge setting just on and freezer setting low following defrosting the operation seams ok but deteriorates with ice forming on the rear freezer panel and the lower...
Defrost system problem. Could be in heaters, defrost thermostat, or defrost timing circuit. Freezing in vegetable section is due to air back flow related to frozen evaporator coil in freezer compartment.
Colder air settles and warmer air raises.
Ice maker problem is separate. Bar up engages micro switch that is supposed to shut it off. Bad micro-switch?
May 27, 2008 | Maytag Refrigerators
Refrigerators Logo
60 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
