Question about GE Profile JGB900 Gas Kitchen Range
I've arranged to purchase this range from Sears. Does anyone know if the back of this range is open? Behind my present stove the gas connection protrudes from the wall about 16 inches off the floor. Is this going to be a problem for the installation of the GE jgb900? Thanks
  • 101 Answers
Possible
Posted on Sep 10, 2010
My range master 90gas oven lights but the flame stays small and can not be turned up
gas present no pressure increase
repair will need a qualified gas fitter
has gas thermostats to each burner
and stove sections ..might be one of those
if all burners are affected
the gas regulator main line connection to stove
located at the back into the stove plumbing
Oct 31, 2016 | Kitchen Ranges
We have a Frigidaire electronic ignition range about a decade old. The stove works fine. But lately we've noticed if we're using any stove elements the oven won't ignite and heat up. Conve
Sounds like the pressure regulator on the stove is going bad. The pressure regulator is located in the back. Your gas supply line should connect directly to it.
Dec 23, 2012 | Kitchen Ranges
Mgrh752cds gas stove switched back from LP to Natural Gas
http://www.partselect.com/2084108-3-M-Whirlpool-74006429-Gas-Pressure-Regulator.jpg
This is the part you need. It will have instructions with it. Order this part from repairclinic.com because you really don't need it, just the directions with it, and after you switch back to gas, just send it back for a 100% refund.
Jun 04, 2012 | Maytag MGRH752CDS (Gas) Stainless Steel...
I have a galaxy gas range says it is set up for gas or propane how do i switch it and is it expensive
The cost of the parts is low. Many ranges have the conversion kit attached to the back of the unit. (If installed, pull the range away from the wall and then check the back. Another likely spot is behind the storage drawer.) If the parts aren't provided, then check your manual for information on ordering the conversion kit. (At least one range I've researched had a price under $20 for the conversion kit.)
The biggest cost is to get a licensed installer to do the conversion. This is required to maintain the warranty. It is also required by law in some states. Talk to your gas company (most appliance shops do not have staff that handle propane conversions).
The instructions are included with the conversion kit. It's fairly simple and takes a screwdriver, wrench and ratchet with correct sized socket (mine took a 10mm). A nutdriver can be helpful. Check your instructions for any other tools you need. With the stove unplugged and disconnected from the gas supply, turn over the LP/NG part in the regulator (do not remove the entire regulator). Adjust the air flow damper. Remove the current orifices for both the range and the stovetop. For best results do these one at a time (the orifices are labeled and are for specific locations). In the oven, you need to remove a few covers to reach the various dampers and orifices.
Then connect the stove back to the incoming gas line and power supply (use a new flexible gas line for the connection to the regulator). Check for leaks. Then you may need to adjust the flame for each of the inlets. The stovetop burners usually have a set screw behind the knob so turn on the flame and then remove the knob. The set screw takes a very small screwdriver.
I hope this helps.
(please note I did this from memory after reading the directions on the new stove we had delivered about 2 months ago. That was an LG stove so some differences in the instructions are inevitable.)
Aug 25, 2010 | Sears 61301 Gas Kitchen Range
I have an antique Sears Country Kitchen Gas Range, Model Number: 143.6806800. Sears has told me the part I need has been discontinued. Can you recommend anyone/anything I can do to locate this part? Is...
My oven does not work. Was told the thermostat was out and can't find another one. It is a model 600 sears country kitchen electric stove.
Apr 10, 2010 | Kitchen Ranges
Model NO. FGF379WECD. Serial NO. VF65008987 I would like to know how old this stove is. this is a fridigaire gas stove.
I have a FGF379WECS ( I believe the letters at the end of the model just denotes your finish; my unit is stainless steel) with a serial number in a similar range as your's.
I purchased my stove from Sears winter of 1999/200.
HTH.
Sep 28, 2009 | Frigidaire Kitchen Ranges
Sear elite model 790.31043800
bought new orffices and then the gas company converted it.
Sep 05, 2009 | Kenmore 79383 Dual Fuel (Electric and Gas)...
Yellow flame after an Lp conversion
I remember having a stove with an adjustable orifice in the oven. It looked like a double nut arrangement. If that is what you find, tightening them to each other shrinks the size. Should turn fairly easy, do not force. You may also find a pilot adjustment behind the oven control knob. Hope this helps.
May 19, 2009 | KitchenAid KGST307 Gas Kitchen Range
Tappan Range Model TGF351ESJ Nat. Gas to Propane
Yes you can convert the range
2. Provide an adequate gas supply.
This unit is pre-set to operate on 4" natural gas manifold
pressure. Aconvertible pressure regulator is connected to the
manifold and MUST be connected inseries with the gas supply
line. If the LP/Propane conversion kit has been used, follow
instructions provided with the kit for converting the pressure
regulator to LP/Propane use. The LP kit can be found on the
back side of the range (some models).
I yours does not have the kit on back go to sears to get one.
Good Luck
Please rate FixYa!
Dec 19, 2008 | Jenn-Air JGR8855BDS Gas Kitchen Range
Kenmore free standing range
look on the bad of your stove,there should be four braas fitting,on a piece of cardboard,these are your fitting for lp gas change over,just unscrew the old one and replace with these,let me know-miike
Sep 21, 2008 | Kitchen Ranges
GE Profile JGB900 Gas Kitchen Range Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
