Question about Dryers
Hi. My LG Tromm Dryer DLG3788 warms at times, heats hot others and sometimes won't heat at all. Either way the clothes either don't dry at all or take hours. Any suggestions? Thanks.
  • Dryers Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Sep 12, 2010
Clothes aren't getting dry
Check your vent hose and where it exits the building, clean away all lint anything blocking the vent cap or in the vent hose. Remove the vent from the back of the dryer and make sure it is all clean and clear there and make sure the betn is not kinked up when putting the dryer back into it space. Now before you blow me off, if any of this is true for your dryer the heat will build up and trip the thermostat causing it not to heat properly and the blower wheel can not move the air to collect the moisture and remove it from inside the dryer. Also, any sagging vent line can collect moisture which turns to a puddle of water in the line and this to will not allow your dryer to dry the clothes. Good luck I hope I have helped you.
Mar 30, 2014 | LG Tromm Electric Dryer
My LG TROMM Dryer is not heating up and it takes several cycles to dry clothes,
Hello & Welcome to FixYa
If everything else in the dryer is working fine and it won't heat so it means that the thermal fuse which is located inside the rear panel on the blower wheel housing is bad and needs replacement. Please get back to me if you have any other questions.
Dec 01, 2010 | LG DLE2514 Electric Dryer
My LG tromm dryer wont heat and i don't know how ignite the pilot
heatman101
Aug 02, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
My lg tromm DLG69885 gas dryer is not heating; otherwise it works fine. Dry light flashes cooling light stays on solid
I am using LG Tromm DLE2514 washer dryer. It 's running but didn't dried the clothes. I clean it's lint but still it's not working. The one thing i notice now is it's drying light is blinking and cooling light is turn on all the time during the cycle. So what's the problem with my dryer?
May 20, 2010 | LG DLG5932W Gas Dryer
LG TROMM Front Load Dryer / Not drying clothes
check the vent or condensor depending on what type of dryer.
Sep 28, 2009 | Dryers
Lg tromm front load dryer dlg5988w
dryer has two fuses check both circuit breakers one is for heating the other is for the plug this fixed my front load lg this gives you the heat that you need to dry your clothes
Mar 01, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG tromm electric dryer not heating up
Check the heating element. That is the part that warms the dryer up to dry ther clothes
Feb 25, 2008 | Whirlpool GGW3878J Dryer
Dryers Logo
220 people viewed this question
Top Dryers Experts
