Question about Reddy Heating & Cooling
Comes on and runs and after a few seconds it will go out.it still has ignition and still spraying fuel /at this time it is blowing smoke then it will burn for a short time and go out again. it is a 75000 btu.heater.
  • 1,476 Answers
Cdoman,
This is a common problem with Reddy Heaters after they get a few years on them. Your air/fuel mixture needs to be set. I have a tip at http://www.fixya.com/support/r4124129-yearly_maintenance_reddy_heaters which explains the problem, where to get parts and how to complete the repair.
Thanks for using FixYa and for the generous rating!!
hardrocko
Posted on Sep 12, 2010
Blows black smoke and sputters
Hi David, The link below is a youtube video showing why and how to stop your motor from blowing black smoke...........CHEERS..
How to troubleshoot engine smoke color issues Must watch
Apr 28, 2016 | Garden
RK70N Stationary diesel engine won't continue to run.
you could have a stuck valve. Cam pushes valve stem to open valve and the spring should cause valve to close as the rocker comes up. Or if the valve is burned or otherwise covered in "junk" it will not seal closed b the spring action.
Oct 19, 2014 | Cars & Trucks
Masada pu ran out of gas will not only if i prime, for a few seconds
Fuel pump is not running (if electric) or floats stuck. Outside of those, hole in fuel line, possibly even line in tank. My old one had a sight glass on the float bowl where you could see if fuel was in it.
Apr 01, 2014 | Cars & Trucks
Black smoke coming from exhaust occasionally.
Black smoke is indicative of carbon or incomplete combustion caused by either poor ignition (weak spark) or too much fuel (choke setting). Check out these areas.
Mar 31, 2017 | 2003 Suzuki VL 1500 Intruder LC
When filled with kerosene then plugged in, the heater will kick on for about 3 seconds and the fan will run but it will not ignite, then it shuts off. reddy heater 55, 55000btu. runs on K1 or fuel oil.
REDDY HEATER 40 KEROSENE FIRES UP FOR A FEW SECONDS AND QUITS WITH A WHITE CLOUD OF SMOKE COMING OUT THE END
MY REDDY HEATER 35 KEROSENE RAN OUT OF FUEL AND WILL NOT RUN AT ALL WHEN PLUGGED IN
Jan 11, 2010 | Reddy Heater-30-55,000 BTU Variable
Need diagram of a force 150hp outboard motor
To winterize a Force outboard you should start the engine and remove the fuel line. Remove the air box and while the engine is running rev up the engine a bit and spray the fogging oil into the throat of each carberator when the engine is about to run out of fuel. keep spraying the fogging oil until you see thick smoke coming from the exhaust area. The exhaust comes out of the center of the prop. When you see the blue smoke then keep spraying and let off the throttle and choke the engine so it dies. Stabilize or get rid of your fuel in the fuel tank and you can let it sit like that for the winter. Leave the outboard in the down position so that any water will drain by gravity out of the prop. When you want to use it next spring just hook up fresh fuel, squeeze the fuel bulb and fire the engine up. It will smoke for a few seconds until that fogging oil burns out of there but it will be ready to run.
Oct 10, 2009 | Boating
Jetta tdi 2007 running rough on start up at times. blowing excessive amounts of smoke from exhaust at times. poor idle at times feels like running on three and a half cylinders, takes a few seconds too...
You may want to check the ignition system. The smoke could be because of unburnt fuel. You may be running on less then 4 cylinders. Check if all spark plugs are firing. You may also want to use a scanner if there are error codes found in its ECU.
Jul 10, 2009 | 2003 Volkswagen Jetta TDI
Craftsman riding mower starts, then runs for 30 seconds, then pours out white tons of white smoke and sputters and dies. It will then re-start and repeat the same. The amount of smoke is tremendous. It...
The smoke is oil going in to the combustion chamber, will have to check for broken rings or piston. also if the tractor was stored in a position that the oil would run to the combustion chamber it will do that untill all the oil is burn
Mar 22, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Runs a few minutes and quits
hi this could be 3 problems ? no spark so vapour not igniting so excess vapour coming out as smoke, if it ignites stays on for a while goes out the flame probe is faulty, fuel filter is blocked needs new one , the fuel pipe going into tank has a non return vavle in it ( its a plastic ball in line with pipe ) if this is missing or stuck it allows fuel to drain back into tank and causes a air lock in heater causing vapour into chamber result in smoke coming out of end, as a quick fix for that you can fill pipe with fuel bend it so its traps in fuel like fire place pipe in tank when stopping fire stick mole gripps on pipe so next time fuel is there ready
Jan 22, 2009 | Reddy Heater 60,000 BTU Kerosene...
2004 cavalier fuel problem?
Please call me its easier to explain on the phone, in the mean time try something easy hit the fuel pump on thebottom with a brick or rock then have someone listen to the fill neck of the tank for the two second "buzz" as soon as you turn on the ignition, has this vehicle been run way way low on fuel many times or the fuel filter neglected to been changed at the 15,000 miles interval?
call me or I can call you 253-691-6206
Aug 24, 2008 | 2004 Chevrolet Cavalier
Heating & Cooling Logo
87 people viewed this question
Top Reddy Heating & Cooling Experts
Mack Baxter
paulcarew
Richard Marsh
Richard Marsh
Level 1 Expert
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
