Question about Canon DR 2080C Path-Through Scanner
I am getting a "scanner parameters are incorrect.(-4408)" error message when trying to scan.
jackboy
  • 2985 Answers
SOURCE: Scanning negatives on CanoScan 600F, I get an error message "Cannot write or read. 252.0.0"
The Canon support site is the place to go for that if your Manual does not tell you.
However remove the software and reload it - it may be as simple as that.
Posted on Dec 26, 2007
  • 111 Answers
SOURCE: Canon LIDE 500F scanner does not scan - returns error message about releasing lock switch, detaching interface cable and reconnecting
Check the lock switch and make sure it is unlocked. I think the lock switch is on the bottom...or it may be under the lid near one of the hinges. Flip it back and forth and leave it in the unlocked position.
If this doesn't work, then it will most likely need service. Contact Canon Tech Support.
Posted on May 09, 2008
SOURCE: problems in using it
I ran into a similar problem with my LiDE 20 right after I upgraded my Adobe Reader from version 8.0 to version 9.0. Under the "Link scanned images to" section, the path was still pointing to the old version of Adobe Reader. To fix it, I clicked the "Set..." button and selected the appropriate path to the new version of Adobe Reader. You can also try clicking the "Link Deletion" button if you just want the file to be saved without displaying the image after scanning.
Posted on Oct 12, 2008
SOURCE: computer says there is no document on scanner
Had same problem with mac os 10.4 solution was downloading the latest epson driver from epson it still didn't work. turned out that the "epson perfection 1670.ds " old file was in the trash and the scanner was still using it. I turned off the scanner, rebooted the mac and "empty trash". Turned scanner back on and it worked. If you still have the problem make sure that you only have on "epson perfection 1670.ds" file in your HD,library,image capture,twain data sources.
Posted on Feb 11, 2009
  • 17 Answers
SOURCE: Link Scanned Image - Error Message on Canon CanoScan 500F
"Link Scanned images to..." refers to the programme you want to open the file. Navigate to the .exe of your preferred viewer
Posted on Jun 11, 2009
Show error 52.00
52.X PRINTER ERROR The laser scanner speed is incorrect. X description: 1 = Scanner startup error 2 = Scanner rotation error 1. Press GO. The page containing the error will automatically be reprinted. 2. Turn the printer off and then on. 3. Reseat cables to the laser/ scanner and engine controller. 4. Replace the laser/scanner.
Apr 16, 2016 | HP LaserJet 4350n Printer
Parameter incorrect error message
Adding more details would be helpful.
Jul 16, 2014 | Computers & Internet
Incorrect parameters when scanning
all setting getting to default then try again
May 18, 2012 | HP Photosmart 4180 All-in-One Printer
Canon DR-5010C when settings are changed to Auto Detection for page size gets an error message stating that "Scanning parameters are incorrect." I want to be able to scan stacks of paper of various sizes....
If you are using CapturePerfect 3, select page size as Auto-detection, detect size by Image width, Deskew by roller & Image, then you will get images exactly as that of the scanned image.
If you ae using CP2, then you can select Auto-detection AND page detection. The problem with CP2 is if the image is less than that of the guide-plate, you will get black background. You can clean this through software.
If you had select B&W scanning and chosen to save file in JPG format, the scanner will report error. JPG is only for Color/ Grey scale.
With CP2, I have observed that sometimes, the changes are not retained, unless you select 'default' first and alter the parameters. This is not found in CP3.
S. Mohan, Chennai, India.
Apr 28, 2010 | Canon DR-5010C Scanner
INCORRECT PARAMETER
usually when a device driver indicates "incorrect parameter" you need to reinstall the dirver for the device.
Apr 21, 2010 | BenQ Scan to Web 4300U Flatbed Scanner
My scanner fails to scan documents. It either generates a "warming-up" message OR "sorry, scanner could not be initialized. (Scanner parameter error.)" message.
there are many users facing this same error message.
there are options to solve the issue.the upper part of the printer is scanner.you have to remove that upper portion by removing the screws and internal locks on its inner layer.then check out if any dust is got collected on the scanner lens.the lens is a thin glass layer in the scanner that reads the document which you place on the glass.if the dust gets collected on the lens it will show this error messages.but if after cleaning it shows same message that means the internal board is got faulty.there is a mini circuit board beside the scanner glass.internally.so the upper scanner assembly needs replacement.in the scanner assembly set you get the new circuit board.scanner assembly means not the upper scanner glass it only includes the inner assembly and the circuit board of scanner assembly.the cost of new assembly is near to $40.you can get this assembly at any local printer repair shop.they have it in spare or they can easily get it from nearest service center of the hp company.
thanks.
Nov 20, 2009 | HP PSC 950 All-In-One InkJet Printer
HP PSC All-In-One inkjet printer--incorrect parameters
RE CONFIGURE , REMOVE everything that has to do with the HP printer from your laptop , and RE INSTALL IT using the installation disk, hope this helps , AJ
May 18, 2009 | HP PSC 2355v All-In-One InkJet Printer
Open Questions:
See all Canon DR 2080C Path-Through Scanner Questions
Canon DR 2080C Path-Through Scanner Logo
1,032 people viewed this question
old marine
old marine
