I have a bose tone mach L1 compact,when i plugged and swtch on this unit an irritating buzzing sound arising through the speaker .what should i do?.
  • Audio Player... Expert
  • 43 Answers
Make sure that both the T1® and Compact are attached to the same main power source. If that doesn't help.
Ask your question on the bose forum.
http://bose.infopop.cc
Please provide details of everything you have connected to the T1® and the Compact.
Posted on Sep 10, 2010
How do I stop vibration sound from the L1??
Try asking your question in the Bose forum (there's a DJ section).
Bose L1 Musicians
Jul 12, 2014 | Bose L1 Speaker
The Tone Match unit is not receiving power
If you are using the Bose ToneMatch cable (black cable - the connectors are round barrels with square connectors). Then this should work fine.
If it doesn't then try a different cable. You can use a network Cat-5 cable.
Note - if you are connecting to an L1® Model I or L1® classic then you need an T1 Power Supply.
T1 ToneMatch Audio Engine power supply tone-match-unit-not-receiving-power-l4qeg2fyniuwsgnfiobf0ph3-1-0.png
Apr 26, 2014 | Bose L1 Model II Dual Bass System with...
No sound from the Ipod jack side of the bose L1 system
There is no iPod jack side output (or headphone output) on any of the Bose L1® Systems.
If you are seeing an image that looks like an iPod, that is the iPod INPUT on the Bose Compact.
Here is more information about the Bose L1® Compact
L1 Compact Bose L1 Encyclopedia FAQ Wiki (fixya has picked up the wrong image - but just click the link and it will take you there).
Oct 31, 2013 | Bose Wave music system large Remote...
My L1 Bose system on light switches to red immediately after turning shystem onon
There are no user serviceable parts on the L1® Compact (except that you can order replacement extensions). If the power light (normally blue) immediately turns red and stays that way, the Compact will have to be serviced by Bose.
You can contact Bose Support online here:
Ask Bose for Help Forum
Oct 06, 2013 | Bose L1 Compact System
Bose L1 no volume
If the power light turns and stays yellow, there is nothing you can do to fix it. You'll need to talk to Bose L1® Support
Call Bose® Product & Technical Support at (877) 335-2673 (U.S. and Canada only)
Monday-Friday: 8:30 AM - 9:00 PM ET
Saturday 9:00 AM - 5:00 PM ET
Or write to them at the Bose Forum
Jul 28, 2013 | Bose L1 Speaker
Mackie dl1608 and Bose l1 humming
This sounds like a ground loop.
Make sure that everything in your signal chain (mixer and anything that plugs into the mixer, and the L1®) are all plugged into the same power source (power bar).
More tips here:
Ground Loop Bose L1 Encyclopedia FAQ Wiki
Jul 11, 2013 | Audio Players & Recorders
Bose L1 speaker short circuit, blow out speaker
If you reset the system (disconnect all cables including power for two minutes) and power it back on, and there are no lights or sound then there is nothing you can do to fix it. You'll need to talk to Bose L1® Support
Aug 12, 2012 | Bose L1 Speaker
Bose l1 crackle
Rotate the volume controls. Does this cause the crackle? Try working the controls through several turns up and down.
Also check that the lights on the top are not solid red. This would indicate that the inputs are clipping (the input signal is too strong) or the volume is turned up too high.
If that doesn't solve it call Bose® Product & Technical Support at (877) 335-2673 (U.S. and Canada only)
or write to them
May 18, 2012 | Bose L1 Speaker
Bose L1 Speaker Distorting
See this article on the inputs on the Bose L1®.
L1 Model Bose L1 Encyclopedia FAQ Wiki
Set the trim levels so that lights are solid green with occasional flickers of red.
Mar 15, 2012 | Bose L1 Speaker
Just bought a ProFX8 mixer to connect to my Bose L1 PA system, but as soon as I connect the outputs to the Bose inputs and raise the master fader there is a "ground hum" even without anything...
Make sure you are using BALANCED audio interconnect cables AND that the speakers and the mixer are powered from the SAME receptacle... Yes, this means running extension cords. It is a ground loop problem. You should be using XLR or TRS cables BALANCED cables from the mixer to the basss unit of the L1 system. The bass unit and the mixer MUST be powered from the same receptacle to avoid ground loops and hum.
Aug 17, 2011 | Mackie ProFX8 Professional Compact Mixer
64 people viewed this question
 Grubhead
Grubhead
