Question about Apple iPod nano
My silver ipod nano third generation is not working, all the buttons are not working the center button and the circle clicker button isn't. I have restarted it and erased everything off it and there is no joy is there anything i can do. i can open it with the lock switch and then the screen goes on standby. please email back thanks from shauna.
  • 395 Answers
Goto the website http://www.felixbruns.de/iPod/firmware/
and download the selected firmware for the ipod touch model you have. if your unsure if the model / type you can goto http://www.felixbruns.de/iPod/firmware/#
and type in the last 3 numbers of your serial number to find out
if you want to downgrade or upgrade, choose the firmware you want to downgrade to, then go to itunes and shift-click on restore and choose the firmware you want to change to. this will restore your ipod touch
Posted on Sep 09, 2010
How to fix power button
I could spend a lot of time describing how you heat round the screen, pry it off, move battery, remove 2 screws holding button assembly, relocate or shim button and reassemble it, but it's easier to point you at someone else's good work and some videos (thanks to those people)
Fix Power Button iPod Nano 6th Generation
Nottingham Solving power button problem in iPod Nano 6th gen The Computer Room...
iPod nano 6th gen power button problem The Computer Room How to
Jun 27, 2014 | Apple Ipod Nano 6th Generation Silver 8 Gb...
I have the third generation nano i-pod from apple and the enter [middle] button doesn't work. The wheel does though.
try to press the middle button and the menu button at the same time.my ipod froze and when i pressed these two buttons it worked
i hope this works.
Mar 07, 2009 | Apple iPod nano 3rd Generation
My ipod nano third generation is frozen
You should not plug the ipod to pc while it is playing because it is switches from the playing mode to sync and charging mode you can not play and use the ipod while it is connected with the software without ejecting it from itunes. Do a reset by pressing and holding the center and menu buttons at the same time until the screen goes back and apple logo pops up. This should reset your ipod and fix the problem.
Feb 20, 2009 | Apple iPod nano
Wrong language on ipod
This is simple but good to know.
Select your language.
If you have an iPod nano or Fifth Generation iPod (iPod with video):
  1. Scroll down to the last menu option but don't select it.
  2. Scroll up one menu item. This should be Settings.
  3. Press the Center (Select) button. This takes you to the Settings menu.
  4. Scroll down to the last menu option but don't select it; in English, this is the "Reset All Settings" option.
  5. Scroll up to the third menu item from the bottom one. This should be Language.
  6. Press the Center button to select Language.
  7. Select your preferred language from the list.
-----John
If that doesn't work go to: http://support.apple.com/kb/HT1824
Nov 24, 2008 | Apple iPod nano
Ipod nano
to put your own music on it you will need to download the latest version of itunes
http://www.apple.com/itunes/download/
then create a library of music in itunes and plug your ipod into the computer and sync your ipod with itunes to download the music onto it.
If the ipod has music on it already then you can just scroll through the library on it to listen to the music, if it is not music you want, then follow the above advice and you will be able to copy your own music into itunes then sync it with your ipod.
Hope this helps
Oct 31, 2008 | Apple iPod nano
Volumn locked on ipod nano 4gb third generation
Press and hold down the center button while pressing on the menu button.
This will reboot your IPod.
Jun 21, 2008 | Apple iPod nano 3rd Generation
Please help, Ipod troubles
for this plug the ipod to comp then restart the system.. then wait for 10 to 12 min..
May 26, 2008 | Apple iPod nano 3rd Generation
Ipod won't turn on 3rd generation silver
Has the battery been charged lately? If not, try charging it first and then try to turn it on. If that is not the case your ipod probably just needs to be reset. Try pressing the center button with the menu button together and hold those two buttons together for about 6-10 seconds. You should get an apple icon that comes on before you will see your menu for your applications.
May 18, 2008 | Apple iPod nano 3rd Generation
Operate an ipod
To get it unlocked: Find a black (or silver) oval switch on it. Move the switch to the left and orange will appear. Your ipod will be unlocked.
To scroll through things: Move your finger around the black circle.
To select something: Press the center black button.
To shut your ipod off: Hold down the pause button (button on bottom of scroll circle) for three seconds. Then switch the hold button to the right to lock it.
To pause something: Press the pause button (button on the bottom of the scroll circle).
I hope my solution was helpful. Please rate it.
Jan 17, 2008 | Apple iPod nano
Apple iPod nano Logo
53 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Computer Repairing
Computer Repairing
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
