Question about Poulan 14" Chainsaw
Runs about 20 sec. at a time, quits starts back up run again then quits...
  • 64 Answers
Sounds like the fuel tank isnt venting through the cap
Posted on Feb 23, 2011
  • 42 Answers
Had same problem, mine had water in the feul tank, drained tank and cleaned carburator , works fine now
Posted on Sep 09, 2010
Toyota avensis 1az will start but only runs for about 20-30 sec then dies but then to start it again and it starts for about 20-30 sec and dies again
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
Jan 24, 2017 | Toyota Cars & Trucks
My maytag quite series 100 _ fills with water starts running cycle but stops after about 20 sec _ it does this 3 times then shuts completely off
Sounds like the timer could be a issue . or motor running to hot clean all under and behind make sure no dust ..UNPLUG UNIT FIRST ,....
Sep 28, 2015 | Maytag Washing Machines
Kenmore 2495..When spin cycle starts, it only runs for about 7 secs then haults... waits for about 20 secs then starts again.
If it's an older machine it's probably time to replace it. It may need a new timer and if you call some one it will likely cost quite a bit of money. I tried to repair older machines and they broke down a short time later with something else.
May 20, 2015 | Washing Machines
88 chevy 2.5l, gets fuel will not start
An engine shut not backfire unless the timing is off, it has a burnt valve or an exhaust restriction. Since the crank sensor was the catalyst for the problem, I would again check it. It definately affects the timing for the fuel and spark
Sep 07, 2014 | Cars & Trucks
Water cooler runs for 20 sec and then stops says that bottler is empty. not pumping water?
either you faild to unpack it properly and left some thing in the dispenser area where the bottle drops in. It doesn`t pump water, it gavitys out of the bottle.
Apr 23, 2014 | Vitapur Energy Star Bottom Load Water...
Aireated fuel after cold soak
check for a loose fuel line hose/connection that is allowing the fuel to drain back over time and filling the line with air that is causing a air lock when trying to start
Apr 08, 2014 | Ford F-250 Cars & Trucks
Car starts then quits. have to wait about 20 mintues
I have the same problem with my bimmer.To find out if the fuel pump problem take fuel pump out and get something kinda nock on the pump put it back in and start the car. It will run but not 1 or 2 days it will die again. You know that mean.Replace the pump.
Aug 03, 2009 | 2000 Mitsubishi Eclipse
Poulan 14" Chainsaw Logo
106 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
