Question about Amana ABB1927DE Bottom Freezer Refrigerator
The feezer runs constantly but the upper part of the refrigerator is warm the unit is about 5 years old and I have had the circut board replaced 1.5 years ago is it common for the refrigerator to fail this often
  • Amana Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 11, 2010
Unit is running constantly but cannot maintain freezer temp, holding around -10c. Fridge temp ok at 4c. Unit is 2 years old and is a replacement for one that died at 1 year old - same symptoms as the first...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 13, 2010 | Zanussi ZEBF250W Bottom Freezer...
Fan seems to be working, but feezer and refrig. not as cold as should be, ice cubes not freezing over night. fan motor was replaced about a year ago. refrig. is about 8 years old
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
heatman101
Sep 26, 2010 | GE GTS22KBP Top Freezer Refrigerator
I have a Performa side by side 7 years old, had a repairman out because it started running constantly...Dx was there is a freon leak. Isn't this uncommon for a fridge that is not THAT old?
It happens alot in my 18+ years i have seen them leak 1 day later to 30 or 40 years later.If it was running and not stoping and freezer and fridge warm or hot it may be a leak if it runs alot and freezer is cold and fridge warm then it is not a freon leak.
May 18, 2010 | Refrigerators
GE side by side - upper freezer warming once a week then freezing
Had the same problem. Bottom of freezer was about the right temp but the upper part was way too warm. Fridge side was fine. Ice maker stopped making ice - it wasn't broken, but it won't run through its cycle if the temp is too high. Cubes already in storage hopper melted and water refroze as it ran to lower, colder part of fridge. Problem: Fan controller for freezer compartment was faulty. The fan itself was fine. Fix: GE replaced the main circuit board that controls everything on this model, including the freezer compartment fan. Once that was done, temp returned to normal, ice maker is happy again. The board had undergone several revisions from the factory installed one (could tell this by comparing the part number on the old and new boards - they increment it when they revise it.) Bad news: the part/labor were expensive and of course failed after the warranty ran out. Good news: the board is now guaranteed for 5 yrs. (Why wouldn't the factory-installed board ALSO be good for five years instead of just one? It's not like the replacement boards are made better.) Labor is covered only for 90 days though so it won't be free if they have to come back after that.
Mar 03, 2009 | GE Profile PSW26P Stainless Steel Side by...
Unit is not coming on.
unj plug the unit for 15 minutes and then try to turn it back on. Is there a reset on your unit? What type of unit is it.
Dec 21, 2008 | Maytag MCD2257HES Side by Side...
AC,DC, gas RV fridge Dometic
You more than likely need to replace the control cable between the upper and lower board. It comes as a kit with the upper board. You can also do a bypass test by unplugging your thermoster from the circuit board. The thermoster is the temperature control for the refrigerator nothing to do with the freezer.
rvtech@myway.com
www.coachtech.info
734 777 6432
Jul 26, 2008 | Dometic NDR 1292 Refrigerator
FRIGIDAIRE REFRIGERATOR PROBLEMS
Freezer stayed cold but upper compartment wouldn't. Freeze started having problems with staying cold. I just paid $377 to get the two year old evaporate fan replaced. It is located inside the frig behind the panel in the freezer compartment. It took about 15 minutes. Seems this part is part of the evaporator system but not covered by anything other than the first one year warranty. Problem solved but what a ripoff from Kitchenaid.
Jun 21, 2008 | Refrigerators
Need help
A removable panel in the rear gives access to the compressor and condenser. Remove the panel and clean out the condenser. Make sure the condenser fan operates when the compressor runs. Restore the panel to its original position for normal operation.
May 27, 2008 | Maytag MSD2756G Side by Side Refrigerator
Amana ABB1927DE Bottom Freezer Refrigerator Logo
85 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
