Question about Acoustic Energy AE1716B Digital Media Streamer
AE17-16B connection issues. I have owned this devce for a couple of years and thepower supply failed. I've replaced it with a multi voltage power supply BUT although I now have power to the device I'm unable to connect to my wireless network. It seems to be in a never ending loop. Is there a way I can re-set the device or another way to resolve my connection issue.
1 hour or 10 minutes, that helps with the blank screen at turning on, but does not solve the Initialising Network stuck problem
Posted on Jan 06, 2016
  • 8,457 Answers
Unplug,replug the unit about an hour later.It should reset it self,back to the factory setting.See,if that works.
Posted on Sep 09, 2010
Hd400 power
Line 6 has a network of authorized repair centers listed on their site. Due to the complexity of the device and the possibility of needing specialized parts, i suggest t you find the repair center nearest you and have them look into it.
May 31, 2017 | Line 6 POD HD400 Guitar Multi Effects...
I have an Asus X53S, and I'm experiencing charging
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Feb 26, 2013 | Computers & Internet
Dead set (no indication lights coming on when I push the power button.
Hi Gwendolyn,
First of all thank you for posting your question here at Fixya.
I'm assuming here that you're TV is a Vizio L32 HDTV.
My initial advice is to ensure that the AC source(outlet) is live. Please plug the unit to a known working outlet, if you are using a surge protector, directly plug the power cord of the TV to the outlet to confirm that the AC source is not the issue here.
If you've confirmed that the AC source is not the problem, then the fault is inside the TV and most likely the power supply. Most of the TV with a dead set symptoms that I've encountered is a power supply issue but of course needs to be confirm.
If your unit is not under warranty period (if so, avail it because the manufacturer will fix it for free, opening the rear cover will void the warranty), open the back cover, check the internal fuse of the power supply board, this is near where the AC power cord's directly connected. Check its continuity using the multimeter/ohmmeter, if you found it open, replaced it with a new same current rating that is printed on its body itself. Sometimes internal fuse fail due to voltage surge/flactuation, aging, etc, replacing with new one resolve the issue, however if the fuse blow again, this is an indication of more serious problem on the power supply board, it needs to replaced the entire board.
If the fuse is intact, you have to measure the output voltage of it through connector J1 (pin 9,10,11). You should be getting 5 Volts. If there's no voltage at these pin, you're power supply board is dead, replaced the entire board. If the 5 volts is present, replaced the main board.
I've provided you a links for the power supply board and mainboard below.
Vizio L32 Power supply board
Vizio L32 Mainboard
Let me know if you need further assistance.
Rating and feedback are highly appreciated!
Hope I helped you.
Good luck and take care!
Have a nice day!
Kind Regards,
Jdvillanueva
Dec 13, 2011 | Vizio L32 32 in. LCD HDTV
This is the strangest thing I've ever seen. I have a Gateway FPD1975W TFT Monitor and its always worked great. The other day it went into a sleep mode via windows, and now it wont boot up the input...
Your monitor problem is causes by the power supply. What is happening is the power supply voltages are not stable, just enough to power the unit up. When you connect it to a video signal the power demands slightly increase and the power supply can't handle it. This is a very common problem with LCD after a few years of use. The issue with the power supply is the capacitors have started to fail. These parts are used to filter the output voltage and when they start to fail the outputs start rippling hence the problem you are having. Here is a link to a repair article that shows how to repair the Gateway FPD1975W monitor.
http://www.ccl-la.com/blog/index.php/gateway-fpd1975w-monitor-repair/
I hope this helps you get back going.
BuddyMc
Sep 20, 2011 | Gateway FPD1975W 19" LCD Monitor
Hello my laptop will not tun on when i slide thepower switch. HELP ME PLASE. PLEASE Thank you VERY MUCH
Check for voltage at the tip of the power connector.
If there's power there, try removing the battery and powering it up.
If that doesn't work, you can try a new power supply, but get a written guarantee that if the unit doesn't work, that you can return it.
If a new power supply doesn't fix the issue, even with a new power supply, then chances are unless you are an electronics technician/technologist, you aren't going to be able to repair the unit yourself.
Most places will want to replace your motherboard - don't use these shops.
Find a place like www.SuperTech-IT.com that does component level repairs and can evaluate and repair the motherboard rather than replacing it.
Aug 08, 2011 | Computers & Internet
Hi, I've APC UPS ES 500 connected to my desktop computer. Have 1 year old battery but when checked without load displaying 12 V. Issues are: a. ups doesn't supply...
A battery showing 12V without a load attached means nothing. You probably have one or more weak cells and they simply cannot supply enough power. I would try a new battery before I try anything else.
Jul 21, 2011 | Office Equipment & Supplies
No power - lights no fan
  1. Verify that the power supply voltage switch is set correctly. If the input voltage for the power supply does not match the correct setting for your country, your computer may not power on at all.
  2. Check for disconnected computer power cable connections. A loose or unplugged power cable is one of the top reasons why a computer doesn't turn on.
  3. Perform a "lamp test" to verify power is being provided from the wall. Your computer isn't going to turn on if it's not getting power so you need to make sure that the power source is working properly.
  4. Test your power supply. At this point in your troubleshooting, it's very likely that thepower supply unit in your computer is no longer working and should be replaced. You should however test it just to be sure. There's no reason to replace a working piece of hardware when testing it is fairly easy.
    Replace your power supply if it fails your testing.
Feb 21, 2011 | Acer eMachines E7254520 Notebook PC
When I turn on the drive, the front pushbutton continually flashes red and blue, and the drive is not seen by the computer. It had worked fine up until now.
Its sounds to me like the external unit has died. This seems to be a common problem with this manufacturer after about a year of use. In most cases the actual hard drive will be fine but it will have to be removed from the case in order for the data to be accessed.
Oct 31, 2009 | Acomdata HybridDrive E5 Hard Drive
Computer wont boot have steady amber light on the start push button nothing on monitor
check you power cable and extension socket for steady power supply. if it is ok, consider plugging it into another outlet. if that fails, check your memory card. if you have more than one card installed, consider taking one out and restarting with one. if it fails, swap it with othe on and the othe out. if it fdails, take out the C-MOS battery from the motherboard and replace it after 2 or more minutes. restart the system.
Jul 23, 2009 | Computers & Internet
Acoustic Energy AE1716B Digital Media Streamer Logo
392 people viewed this question
Top Acoustic Energy Televison & Video Experts
Electro Med Services...
Are you an Acoustic Energy Televison and Video Expert? Answer questions, earn points and help others
