Question about Sony Cyber-shot DSC-W190 Digital Camera
Hello, My Sony Cyber-shot DSC-W190 got wet and when I try to turn it on, basically the lens does not open it sounds like the camera is clicking as if it is struggling to turn on. Then the message on the screen reads, "Turn Power off and on again".. Once the camera dried, I was able to view my pictures but I can not take any pictures or videos.
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Sep 09, 2010
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 17 Answers
Aunsoft MTS/M2TS Converter helps you convert MTS and M2TS video files to MP4, MPG, WMV, AVI, and enables you to enjoy movies on computer or WMP, to further edit video for creation, to present video on HDTV, and to publish video online in web-friendly format. It makes your AVCHD camcorder videos editable on Adobe Premiere, Sony Vegas, Window Movie Maker, DVD Maker.
With this AVCHD camcorder converter, you can load videos from JVC, Canon, Panasonic, Sony camcorders. You can also control your video and music on popular portable devices including iPad, iPhone 4, Nexus One, HTC Hero, Motorola Droid X, Droid 2, Xbox 360, Zune, iPod, PSP, Creative Zen, Apple TV, iPhone anytime anywhere; or convert MTS/M2TS videos to the video formats supported by YouTube, Yahoo, Myspace, Google for web sharing.
http://www.aunsoft.com/mts-converter/
Posted on Nov 08, 2010
Turn the power off and on again
the mechanism of your lens assy is defective, replacing lens assembly will solve the problem
Feb 24, 2013 | Sony Cyber-shot DSC-W190 Digital Camera
How to change language from japanese to english in cyber shot DSC-W190
Press the MENU button. Select the toolbox icon. Select the last item on the menu.
Aug 15, 2012 | Sony Cyber-shot DSC-W190 Digital Camera
Sony dsc-w190 won't turn on
The system control board has shut the camera down to prevent damage, the lens housing will need to be replaced because you have two problems, one the lens is jammed and second the shutter is open, the cost to repair will be equal if not more than a new one.
Mar 31, 2012 | Sony Cyber-shot DSC-W190 Digital Camera
I have sony cyber shot DSC-w190. I am not able to activate date/time stamp..Please help me in this regards.
Please note that the camera does not have a feature for superimposing dates on images. By using "PMB" in the CDROM(supplied), you can print or save images with the date.
For you convenience please see the Image or consult User manual P.84
Thanks.
May 11, 2011 | Sony Cyber-shot DSC-W190 Digital Camera
When i turn off my camera sony cyber shot DSC-S90 the zoom wont retract and a word appear in the screen turn off and on again..any idea what's going on with it?
Sounds like you have some grit or gum on the lens barrel. This will cause the lens to stick in the partly closed position. Clean the lens barrel and try again. A rag moistened with methylated spirits may be needed. The rag must not be wet as we must not harm the special grease used in the lens.
If this fails it probably means an very expensive repair, or replacement.
Feb 19, 2011 | Sony Cyber-Shot DSC-S90 Digital Camera
How much is sony cyber-shot DSC-W190?
You can buy this at Price Range: $138.00 to $190.00. You can buy from ebay or amazon.com though this site :
http://www.dealtime.com/Sony-Cyber-shot-DSC-W190/info
Jan 14, 2011 | Sony Cyber-shot DSC-W190 Digital Camera
My sony cyber-shot DSC-W190 digital camera has a japanese language. I want to change its language to english. Any solution you can teach me? Please..
Click Sony Support and download English User Manual copy, press Menu, settings, main settings in same sequnece and select Initialize camera, this will set camera to default settings and camera will ask time, date and language settings, select English.
Hope this info will help you.
Nov 14, 2009 | Sony Cyber-shot DSC-W190 Digital Camera
Sony Cyber-shot DSC-W190 Digital Camera Logo
616 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
