Question about Poulan 25CC Gas BlowerVac
Fuel problems w/2005 poulan leaf blower.do i have to buy whole carb. kit for $23?
    President:
  • Poulan Master
  • 1,545 Answers
You can possibly repair this with just a "diaghram" kit. They have them for sale on Ebay and some online stores and they cost about 1/2 as much as a complete rebuild kit. Make sure you get the right one.
You can reference your carb here and get the exact part # for it if it is a Zama . RB=complete rebuild kit GND=gasket+diaghram kit: http://www.zamacarb.com/pdfs/QuickKit_CR2010.pdf
Please vote on this solution.
Posted on Sep 11, 2010
No gas getting into carb. What next??
A carb is about all you can do!
If you have primer unable to pull fuel into the motor it maybe one of two things.....a blocked fuel inlet in the carb or the fuel lines are backwards! Try swapping the fuel lines and see if anything changes. If nothing improves you will need to remove the carb and clean it out. Do not use compressed air! Use a can of carb cleaner and allow to air dry afterwards. If you can remove the fuel screen that might help too. A carb kit will come with a new one. The whole carb from eReplacmentparts is less than 30 bucks. Which is a real timesaver!
Jul 23, 2014 | Poulan Entire Fuel System For Bvm 200vs...
Pour gas in carb. will run few sec. replaced both gas lines and filter.
You will need to clean the carb or if this unit has a walbro carb buy a rebuild kit and it will work just fine.. Good Luck...
Mar 23, 2011 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Trying to get my Poulan leaf blower to run again. It suddenly quit. Have checked out fuel line, filter etc.-all ok. Took apart carb - no luck. It will run for a short burst if a add gas directlt to...
Open the carb back up. Directly under the inlet needle you will see a mesh screen. Remove and hold up to light. If it's clogged (and it's HIGHLY likely it will be) take the carb to a reputable dealer and buy a rebuild kit for it (not simply a diaphragm kit, the screen isn't in that one).
About 10 bucks for most kits.
Hope this helps.
Dolf-
Oct 06, 2009 | Garden
Thottle will no stay in one position. There is a black spacer that slides over the throttle shaft between the shaft an the leaver. Will a new leaver come with that black spacer. Blower model wt200
Three (3) possible carbs were available on your machine.
If you have:
Walbro model WT-606 carb, the choke and throttle levers are available in kit form (which leads me to believe the spacer comes with them). Throttle lever kit part #530071726 and choke lever kit part #530071725.
If you have:
ZAMA model C1Q-W11 carb, the choke AND throttle levers are BOTH a part of the carb itself. (Would need a whole carb to get your part.) Complete carb part #530071465.
If you have:
ZAMA model C1Q-W11C carb, the choke and throttle levers are available in kit form (which leads me to believe the spacer comes with them). Throttle lever kit part #530071715 and choke lever kit part #530071716.
Hope this helps.
Oct 04, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Poulan leaf blower won't start
Check the fuel lines for cracks/breaks. If they are o.k., then:
You will need to disassemble the carburetor and spray with carb.cleaner.Make sure the small screen is free of debris. (Should be able to see daylight through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance on:
1. Fuel line replacement or
2. Carburetor kit replacement
Just let me know.
Jim
Sep 26, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Poulan gas weedeater wont rev up
you seem to have carbarator problems you can take it apart and clean it and it should work
Sep 17, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
I have a weed eater blower bv1085, It just stopped. I have changed the fuel filter, air filter and plug but it still will not start any suggestions
Put a spark tester on it see if you have spark,if not.its your coil,would probably be cheaper to buy blower at yard sale than buy a coil. If tou do have spark order a rebuild kit for your carb.When you take the carb off and clean it,look real close,there will be a number on the carb,you need that number to order the right kit,all carbs on weedeater brand equip. are like that.
Aug 01, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Poulan pro leaf blower doesn't start
As long as it has fire, all you need to do is:
Check the fuel lines for cracks/breaks. If this is o.k., then you will need to disassemble the carburetor and spray with carb. cleaner. Use a Den Tek Brush,
(http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. Make sure the small screen in carb. is free of debris.
If you still have trouble after this, then you will need to buy a carb. kit and replace all appropriate parts.
Jim
Jun 06, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Weedeater won't take fuel
You need to remove the carb., disassemble and spay with carb. cleaner. Use a Den Tek Brush, (used for cleaning between teeth), toclean the small portals in carb. Check the small screen. It could have dirt clogged in it. Reasseble and start. If it still doesn't run properly, you will need to buy a carb. kit and replace the screen, needle valve, gasket(s), & diaphragm.
Jim
Jun 04, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Poulan 25CC Gas BlowerVac Logo
198 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
