Question about Whirlpool GBD307PRS Stainless Steel Electric Double Oven
Only the light inside the oven works and only the beeping sounds are herd on the control panel but no control lights work and oven does not work. then after 12 to 24 hrs the control panel starts working again and the oven works , then in a couple of days it quits again. then in the morning it just starts working again.
  • 42 Answers
SOURCE: Whirlpool Double oven control panel
Sounds like you may need a new control panel
Since the keyboard and the control panel cost about the same ($150) get them checked befor you order any parts.
keyboard - part # 8300440
control board part # 830219
Posted on Aug 11, 2009
EllaWatson25
  • 725 Answers
SOURCE: oven made beeping sound and went out like there
Yes, it most likely will go out again. It has a weak spot in it. It is recommended that you go ahead and get this repaired BEFORE the busy holiday season hits.
The best of luck to you!
Ella
Posted on Oct 22, 2009
SOURCE: Whirlpool electric double oven #RBD305PDQ14 control panel blank
The control panel part on my Whirlpool double oven (part #8302319) went blank six months back. Replaced it. Asked if there was a warranty on the part, was told no there was not. Yesterday, the six month old control panel went blank. Disappointed that Whirlpool manufactures such garbage.
Posted on Feb 01, 2010
TheMobilian
  • 8220 Answers
SOURCE: Whirlpool Gold double oven -
I was just looking over a manual for a late model double oven. Their is a thermal limit going into the controls that will open if the temp rises enough to harm the controls. They look like this one.2605a73.jpg That kills all power to the control and you will see nothing on the display.
This manual will give an idea where to look:
Late model double oven
Posted on Sep 27, 2010
  • 84 Answers
SOURCE: I have a Whirlpool double oven (model
An E6 F2 error code on these parts has always been due to the control board. These controllers can be repaired quickly and reliably at www.fixyourboard.com If buttons are not working or you get an F2-E0 or F2-E1 then it is the keypad
Posted on Nov 03, 2010
Frigidaire PLEB30S8CCA baking element not working
Good Morning Jane, thank you for your post!
From what you have described, it sounds like you possibly have problem with a faulty thermal fuse, power supply board, user interface board or a communication error with the EOC (Electronic Oven Control). This is not a typical do it yourself job. Please reach out to an expert technician to ensure the appropriate replacement part(s) is ordered and is installed correctly to prevent future issues.
Best regards!
Feb 10, 2014 | Frigidaire 30 in. Electric Gallery Series...
GE profile convection double oven. Model#jkp56w0w1ww 1.The touch panel on the Oven is off and none of the button works. There is not light or code in the display area. 2. The light inside the oven...
Oh, you probably got this fixed already. If it happens again, it helps to take the control panel off, insert paper towel folded up neatly and slotted into the ribbon (it absorbs the moisture which causes the ribbon to short out). Sounds crazy but it's true! I saved our family hundreds of dollars with a piece of paper towel!
Aug 18, 2013 | GE Ovens
Power failure control panel beeps no lights on panel and oven wont turn on. have lights on inside of oven. do i need a code, never have before. always showed PF for power failure.
Was the oven doing a self clean when the PF occurred? If so the cavity limit probably tripped.
Sometimes the owner wants to shut down the process of self clean for whatever reason that also trips the cavity limit. If the oven circuit breaker is weak then their could be a power failure during which the oven was on and that could cause the cavity limit to trip. No lights on panel means the temp inside the oven control panel exceeded normal operating temp and the small inline fuse going into the control panel has melted:
This is what that small fuse looks like. To get to the insides
you usually drop the side trim exposing the screws then the controls fold outward.
Service manual for American stoves and more
Oct 23, 2011 | Whirlpool Ovens
Amana AEW4530DDS cancel button the only button to beep or work on control panel. Time of day lights up. oven wont work . before oven went t/u had it on broil with the door open a bit. did this fry the...
A qualified technician needs to troubleshoot the unit and determine if the bubble-keypad has broken or the control board that 'controls' it. The control board would be my guess, and would also cost the most.
Mar 16, 2010 | Amana AEW4530DDS Electric Single Oven
Whirlpool Accubake System Mod.# RBD275PB10 front panel blank
GBD RBD Whirlpool Oven Problems Causes and Solutions
Hello Edward!
This blank display is a common control board problem. If the buttons beep when pressed, then the control board is getting adequate power. If the buttons beep.. and your oven light still turns on when the oven door is open.. this a text book control board failure. We at Fixyourboard.com can solve this problem for you, and back the remanufacture with a two year warranty.
May 13, 2017 | Whirlpool RBD305PD Electric Double Oven
I suspect a poor connection at the wiring to the EOC is the cause of the failures.
Apr 21, 2017 | Whirlpool RBD305PD Electric Double Oven
Oven comes on for no reason followed by the start beep
yes you can kill the power and lock out the box with a pad lock for safety. the panel is attached by screws usually on the bottom of panel. lower and seperate the control panel ribbon from the erc (electronic range control). without removing any other components leave ribbon loose and replace panel. turn power back on. if the beeping does not recur, the control panel probably has a stuck key. if it does resume the erc is faulty
May 17, 2009 | GE JKP20 Electric Single Oven
A lot of people seem to have ran into this problem. I had no luck finding a solution to this problem anywhere on the internet. I finally fixed this problem by replacing the control board. Wanted to put this info out here for others. The part swaps out fairly easy for all of you considering the fix yourself. Sears direct had the cheapest price.
Jul 08, 2008 | Whirlpool RBD305PDS Electric Double Oven
Whirlpool GBD307PDS Double oven stopped working.
The beeping sound is a fault code. Problem is it isn't listed. In either the top or bottom oven panel there should be a service sheet. The codes are located on this service sheet.
Jan 22, 2008 | Whirlpool GBD307PDS Electric Double Oven
Whirlpool GBD307PRS Stainless Steel Electric Double Oven Logo
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal DeAngelo
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
