Question about GE Refrigerators
Display on fridge is coming and going off and it won"t cool
  • 101 Answers
Mother board
Posted on Sep 10, 2010
Fridge won't cool
The problem is either the fresh food section thermister or the=> W10196393 Damper12_11_2012_5_08_54_am.jpg
If you would like a Service Manual for this model click here=> MBF2562HEB_Maytag_Refrigerator_Service_Manual When ready I will be here to answer your questions, Thanks Sea Breeze
Dec 11, 2012 | Maytag MBF2556KE (251 cu ft) Bottom...
Fridge won't cool but freezer working fine
Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start. In your case freezer is cooling, then freezing, but its not defrosting. That's why fridge section is not cooling.-------
Click this link below and follow the troubleshooting:----
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
This will help.Thanks.Helpmech/.
Oct 31, 2011 | Refrigerators
MSD2356AD troubleshooting refrigerator won't cool frezer is ok
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 09, 2011 | Maytag Refrigerators
The ice is blocking the air blower in the frizer and it won't deprost. The friges can't get any cold unless if I put it high.
heatman101
Aug 09, 2011 | GE Profile Arctica Stainless Steel Top...
Fridge won't cool below 60, freezer won't go above 20
heatman101
Aug 08, 2011 | Refrigerators
The defrost won't cut in
heatman101
May 17, 2011 | Whirlpool Refrigerators
Fridge running warmer than it should, Cooling fan on back doesn't turn, the compressor/condensor running very hot , and no new ice being made. Cleaned the cooling grid which was full of dust.
Here is the basic idea on how to keep the refrigerator, air conditioner, or vacuum cleaner to work properly. Air is moved by an electric fan or blower in order for that product to work properly. If air movement is blocked the fridge won't get cold, the central air conditioner won't cool enough, the vacume cleaner won't clean as well. Check on your fridge's air movement by inspecting the bottom of the fridge for dust and cob webs. Remove the front bottom clip-on plastic grill. Or also even access the lower back of the fridge by removeing the screws holding up the heavy cardboard cover to see inside. Blockage of air flow will prevent a fridge from getting cold. Just like a vacuum cleaner stops working when the bag is filled with dust and fibers. The air could be blocked by the accumulation of dust and fibers. Look under your fridge if it is cloged, it will look just like the stuff on a dirty central air filter.
Dust and fiber buildup blocking the fridge's air movement from back to front (or visa-versa) of your fridge will slowly (years) prevent how good it cools. The build-up of dust and cobwebs prevents your fridge from cooling (more specifically prevents the heat to disapate from the metal heat disipating fins attached to the metal tubes to be blown off by the fans air). OK! Remedy for a vacuum cleaner REPLACE THE CLOGED VACUUM BAG.
Remedy for your fridge manually REMOVE THE CLOGING DUST AND FIBERS FROM UNDER YOUR FRIDGE. SORRY fridge manufacturers do not provide a dust filter like the vacume cleaner and central air systems manufacturers do. You have to figger out the best way you can clean it. Possibly vacuum with a crevice tool, or use a small brush than vacuum. The extreme would be unplug the fridge ( so you won't get electrocuted) bring a water hose into the kitchen and spray water at cobweb buildup at the bottom fridge, than wet vac the floor then wait 20 minutes to dry before pluging the fridge back into the electric outlet.
When you stand in front of your fridge and you hear the fridge electric motor turn on, the fan will blow air.The fridge
Apr 11, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
On my fridge freezer the freezer section is working but the fridge is not, on the control panel it displays a H instead of temp can you help?
heatman101
Mar 14, 2011 | Zanussi Refrigerators
A clicking sound was coming from behind my fridge and the temp display was not working. digital display. the light in the fridge comes on but the fridge is not working What could it be?
You have a bad main control board , located on the back of the refrig , behind an 8" X 10" panel . Part number WR55X10942 . This control board , usually clicks when the compressor tries to start , or when the compressor cooling fan tries to start . It also controls the display .
Sep 24, 2009 | GE Profile PDS20MFS Bottom Freezer...
Refrigerators Logo
Top Refrigerators Experts
Sal DeAngelo
dweatherby
