Question about Casio OC500 Oceanus watch
For module 5129 KHE, the world time indicator registers one hour later that correct. For example, if time in NYC is now 14:15 DST, London time registers 20:15 instead of 19:15. How do I correct this?
4 Suggested Answers
  • 13433 Answers
SOURCE: Daylight Saving Time will not set correctly
Use this page to download a copy of CASIO watch manuals in PDF format. To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
http://world.casio.com/wat/download/en/manual/
You will need a pdf reader on your pc, you will find all instructions in there.
If you don't have a pdf reader you can get one from
http://www.foxitsoftware.com/pdf/rd_intro.php
Posted on Jun 10, 2008
SOURCE: i have a ceptor 4305 module, i live in UK, DST
hold down the bottom right button for 5 seconds, until second hand goes to 12 and stays there.
keep pressing top right button through sequence of numbers and letters until it reaches 0, ie time difference to GMT. press bottom right button 10 times to restart watch
Posted on Apr 20, 2009
SOURCE: Casio Wave Captor Watch wont set to correct time.
You need to manually adjust or set the hands to the home position as they are not where the watch thinks they should be. This can happen when you bring your watch close to a strong magnetic field. Look in the manual to do this. Afterwards your watch should set to the correct time.
Posted on May 07, 2009
How to set the time ?
press BOTTOM button to light up.
press and hold 3 second top button DST----- will show up release button for a second then press again right away.
HOUR will be SELECT, press bottom button to change HOUR.
press TOP button again to SELECT MINUTE , press bottom button to change MINUTE .
same process change 12H to 24H
same process to change DAY-MONTH-YEAR.
same process to set DD-MM-YY
Same process to change CITY NYC , CCS, RIO,
hope everything will work
Aug 09, 2014 | Kenneth Cole Casual Quartz Digital...
Daylight savings time change casio atomic watch has not changed is there a way to change it manually
An example for G-shock: I searched for casio g-shock manual and got this: http://world.casio.com/wat/download/en/manual/
You enter model from back of watch and it gives you a searchable PDF manual.
For mine, model 2638 (and likely most G-shocks), you press and hold the upper left (Adjust) button until the City Code flashes. You then press the lower left (Mode) to enter DST mode then press the lower right (Receive) as it cycles through On, Off and Auto.
On moves 1 hour forward, Off moves 1 hour back. After you select, you press the upper left button (Adjust) twice and it's set. I would not pick Auto anymore as my watch is still set to the original DST days which were changed in the US years ago and no longer match, I don't believe the DST days used can be changed by the user and I don't believe Auto receive adjusts for DST.
Mar 13, 2011 | Casio Watches
What if I live in bristol and do not know which option, time to choose from to keep time upmost accurate london or GMT
The main difference, as I understand it, between London time and GMT is London time will shift for DST (daylight savings time) and GMT will not. Therefore, London time is probably your best bet.
Feb 08, 2011 | Casio G-Shock GW500A-1V Wrist Watch
Need a user manual for the time magazine free chronograph watch
I have NO ideal what kind of watch it is so I am giving general chronograph instructions. You will have to use as it applies to the watch you were given.
These instructions are provided for users who are not familiar with using a mechanical/analog chronograph. The instructions may be applied to any chronograph that has a seconds counter, 30 minute counter, and hour counter.
Please refer to the instructions of the appropriate model to determine the location of each counter on the dial. Note: some of the features described here may not be available on your particular model. Again, refer to the specifications to see if they apply to your model.
Using the chronographe functions:
How to read the chronographe:
For a chronographe that has a center seconds register, a 30 minute register and an hour register. Example 1: If the hour register is between the 1 and 2, but closer to the 1, and the minute register is at 20, and the seconds register is at 35, then the elapsed time is 1 hour 20 minutes and 35 seconds. Example 2: If the hour register is between the 1 and 2, but closer to the 2, and the minute register is at 20, and the seconds register is at 35, then the elapsed time is 1 hour 50 minutes and 35 seconds.
How to read the tachymetre:
If you are driving and want to determine the speed of the car using your tachymetre, start your chronograph when you pass a mile marker, stop your chronographe when you pass the next mile marker. Look at the center seconds hand and read the number on the Tachymetre scale, this number will indicate the miles per hour that the vehicle is travelling.
How to read the pulsometer:
Some watches have a pulsometer instead of a tachymetre. Use it as follows: Start the chronographe and begin counting the pulse. When you have counted 30 beats, stop the chronographe. The number on the pulsometer scale will indicate the pulse rate per minute.
How to read the telemeter:
Some watches have a telemeter instead of a tachymetre or pulsometer. Here is an example of one use for a telemeter: Start the chronographe when you see lighting. Stop the chronographe when you hear the thunder. Read the center seconds hand on the Telemetric scale and the number will indicate the distance separating the observer from the place where the lighting struck. This can give you a good indication of how far off a storm might be.
The many uses of a chronographe:
A chronograph has many practical uses, from timing a plane flight, a car ride, or simply being curious. There are also some uses for the chronographe that may not be so obvious. For example, you can use the chronographe on your watch as a dual timezone indicator. This is done as follows: If it is currently 6 A.M. in your home location and it is 12 noon in London, start your chronograph at exactly 6 o'clock. The number of hours displayed on your chronographe hour register will then show you the current time in London. Of course, these are just some uses of a chronographe. There are hundreds of uses for chronographes.
Instructions: Astronic Chronograph Chronograph Chronometer Power Reserve Chronometer Astronic Chronometer World Time Chronometer Retro Alarm General Chronograph Common Q & A's
Aug 12, 2010 | Watches
My red hour hand doesn't stay the same time difference . Sometimes it's two hours behind BST and sometimes six!
mcdevito75 here, Sounds like your watch is showing a different time zone, refer to your owners manual or vist a locl jeweler for adjustment on timeing, setting your watch. Your watch may be set up to show different world time zones, if so, you may have hit a button and now your watch is showing time in a different time zone as an example London / New York.
Jun 29, 2010 | Rolex Explorer II 16570 Wrist Watch
Apr 21, 2009 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Echo drive skyhawk,My watch's time zone is always one hour behind
You posted this in January, which is not during daylight savings time. The SMT setting doesn't turn on automatic DST switching for a particular timezone; rather, it is a manual override to adjust timezones to DST when it is actually active. There is no automatic DST adjustment for this watch (according to their FAQ). Turn SMT to OF for all timezones during winter months, and ON for applicable timezones during SuMmer Time (SMT).
Jan 17, 2009 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
How do I get the wave ceptor to come on ?Casio-2688
Try Googling (casio)(2688)(manual) without parens for instructions.
May 08, 2017 | Casio Watches
How do you set the time on a casio g shock watch????????
I had the same problem following recent daylight savings time (DST) change. The watch has three DST mode settings (ON, OFF, and AUTO). You get to the setting mode by pressing and holding the "adjust' button until the city time zone indicator starts to flash. Then press the "mode" button. This should give you the DST setting. Now press the "receive" button to cycle through the ON, OFF, and AUTO modes for DST. I set it for AUTO. I then existed the setting mode by pressing "adjust" again.
Now you can initiate a manual update of the time by pressing and holding the receive button. Put your watch by a window and make sure the signal strength indication is showing level 4 (full picture of satellite dish on my version). Give it a few minutes to down load new time.
After doing this the watch corrected itself and now shows correct time. Other wise I assume you could set the DST function to ON or OFF as well depending on whether you need to add or subtract the hour from the time.
Oct 26, 2008 | Casio G-Shock GW500A-1V Wrist Watch
Nov 08, 2007 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Casio OC500 Oceanus watch Logo
53 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
