Question about Compaq Evo N610C Notebook
Compaq evo N610c appears to have a b lack screen, however in direcy light the screen is visable. if pluged into an external monitor the display is visable.
  • rosey0335 Sep 09, 2010
    Didn't resolve my problem but i accept it
    President:
  • 2,777 Answers
The first thing to try would be to turn the brightness up on the screen. There should be a FN (or function) key on the keyboard, and an associated key (usually under one of the F keys, such as F6, F7 at the top of the keyboard, or on one of the keys) that has a brightness adjustment for both UP and DOWN (brighter and dimmer). Try holding down the function key and press the key that looks like it would indicate BRIGHTER, usually a circle with some lines coming out of it indicating glowing. I assume you may have already tried this so...
This indicates that the actual LCD / screen on the laptop's back-light has failed. You can try to shut down the computer, make sure it is off and then take out the battery from the bottom of the laptop. Leave it off for a good 30 - 90 seconds and then go ahead and put it back in. Try turning the unit back on. If the screen is still the same you will need to replace the screen, or replace the whole laptop.
Usually screens are quite expensive, and unless you have expertise at installing them, I wouldn't try to do it yourself. Most likely you will want to buy a new machine. The good news is that you can still sell this machine on ebay, just make sure you list it as having the back-light "burned out" or something to that effect.
Posted on Sep 09, 2010
Screen does not come on when I switch my compaq evo n610c on ? Any Ideas ?
If you see a dark screen meaning look deep into the screen if you see a logo thru it then it means that the life of the bulbs is done you have to replace the screen is cheap on ebay i got mine there and it works fine to take apart is also easy. But before you spend your money attache an external monitor to it from the VGA on back if it show on the screen then yes your screen is bad if it does'nt then the board is bad.
Oct 01, 2010 | Compaq Evo N610C Notebook
My screen will not work. If I hook my laptop up to an external monitor it will work. How do I resolve this issue?
connect it to an external monitor and click f5 once if it dosent work it means that your monitor is burned
Jan 03, 2010 | Compaq Evo N610C Notebook
The screen on my Compaq Evo N610c is dim
You could have a faulty inverter or a CCFL lamp, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Jul 11, 2009 | Compaq Presario Notebook
Laptop dispalys to monitor but laptop panel cannot be activate
Thanks for all the details..
The issue seems to be with the video card drivers here...
Go to www.hp.com/suport and download the latest video card and the chipset drivers
before you download ...uninstall the nvidia chipset or any display software from program and features.
after you have installed the software.. go to the nvidia control panel > setup multiple monitors. and browse throughout the options >
It should be dual display and not extended display.
Also try with a new user profile...
Hope this helps..
Regards,
Anup
Apr 05, 2009 | HP Compaq Evo n610c Notebook
Compaq Evo N610c
u have to reinstall your disply driver
Oct 07, 2008 | HP Compaq Evo n610c Notebook
Evo n610c black black screen please help
If an external monitor works, then the LCD has failed and needs replaced.
Jul 13, 2008 | Compaq Evo N610C Notebook
COMPAQ N610C DISTORTED DISPLAY?
Sounds like video failure. If your video is integrated as most laptops are, it will require a motherboard replacement.
Jun 27, 2008 | Compaq Evo N610C Notebook
Compaq evo n610 screen dead
all you need do is to change the LCD (screen) and the module.
module is closse to the screen, under the monitor.
Jun 13, 2008 | Compaq Evo N610C Notebook
Compaq N610C
lcd displays are backlit with florescent lights, they could be burnt out.
May 17, 2008 | Compaq Evo N610C Notebook
Compaq EVO N610c
Hey there i might be young im 14 years old but i have the same laptop (Compaq N610c) and i had the same problem i found out that if you take the ram out and rub the small golden plates with a rubber then place it back (the ram is found next to the mouse pad) i then powered the laptop up without the hard drive i then took the battery several times and powered up it then started working again within 5 mins of taking the battery in and then taking it out again it then starting to power up with the screen showing the logo at the begining after it had shown the logo i turned it off then inserted the hard drive back into the laptop and powered up it worked and is still working now Hope This Helps :D My Email Adress Is znet-productions@hotmail.co.uk
if you have anymore problems.
Sep 11, 2007 | HP Compaq Evo n610c Notebook
Compaq Evo N610C Notebook Logo
103 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
