Question about Dyson DC14 Animal Bagless Upright Cyclonic Vacuum
Hello. i only have one arm and am trying to figure out why my beater bar wont turn on my dyson dc14. the belt smells a little too. thanx, trixie
  • 377 Answers
Sounds like the beater bar is frozen in place. This sometimes happens when the ends of the bar become stuck in the holders. The solution is to remove the beater bar and clean the small holders on each end removing any debris that has built up. Spray with a little WD40 and then manually rotate the beater brush around the holders until it is free, then replace. Be sure the belt is installed properly.
Posted on Sep 09, 2010
The brushes on my dyson dc33 won't turn. I know the belt hasn't broke. Thanks SIMON
brushes on my dyson dc33 won't turn Simon, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.dyson.co.uk/support/dc07/dc07-clic/my-machine-is-not-working/my-dyson-will-not-stand-upright/my-dyson-will-not-stand-upright/no1/yes1/brushbar-not-turning-clutch-check
How to repair Dyson DC07 DC14 DC33
Dyson Burning Smell Beater Bar Brush Stuck DC14 Not Working Easy Fix
Aug 02, 2016 | Dyson Vacuums
I have strong hose suction but none below and beater bar is not turning
Beater Bar Belt Likely Broken--Can Be Checked By Removing Cover(s) Next To Beater Bar (on bottom)
Feb 27, 2015 | Dyson DC33 Multi-Floor Upright Bagless...
Fault finding
Have you accidentally switched off the beater bar via the dial on the head? Some models have a 'hard floors' and a 'carpets' setting (which disengages/engages the beater bar).
Jul 06, 2014 | Dyson Vacuums
Beater bar wont spin
hello rud.... this is due to either a broken belt or lots of carpet fibers or pet fur in the beater bar mechanism. turn it off, unplug it and then turn it on it's side and check to see if the bar turns freely by hand. if it does, you will have to replace the belt assembly.... most dyson's have the belt built in to a plastic housing forcing you to buy a pricey part. Joe
May 15, 2011 | Dyson DC14 All Floors Upright Vacuum...
How do I replace the belt on the beater bar?
if the belt is begining to smell it is friction from themotor trying to drive the roller Sounds like the rooler is getting caught up or jamming this can be taken out and cleaned
Jul 26, 2010 | Dyson DC14 Bagless Upright Cyclonic Vacuum
My beater brush will not spin. i cleaned it all off, but it will not turn when i turn the vacuum on
1. if you are smelling burnt rubber and hearing a loud squealing then your belt is tight but something is binding up the beater bar, more than likely if that is the case you need to take out the bar and see if the ends are packed up with carpet fibers, on the otherhand if the bar isn't moving and no smell or sound is present then more than likely your belt has slipped off the impeller shaft and all you have to do is pull it back onto the shaft, or the belt has snapped and you need to replace it
Feb 16, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
Brush does not turn on a Eureka vacuum
The belt is broken for the "beater bar"
goto www.dyson.com/ and view/download a manual. for step by step guide.
Apr 26, 2009 | Dyson DC14 All floors Bagless Upright...
Replace belt and dyson vacuam cleaner, model dc14 I ordered a new belt and brush replacement assembly and we can't seem to understand how to get it apart to change it
If the DC14 has a brush protected aspect i.e. a switch on the front that puts the drive belt off, the drive belt would have to be replaced by a professional repairer as this can't be done at home.
If the model doesn't have the brush control at the front, flip the Dyson over so that the beater bar is in the air and locate three/four screws that can be taken out with a coin or blunt knife. A turn is all that is required on those notches and the sole plate should come off once these notches have been undone. Then check the belt - if it has broken lift out the beater bar in the middle with your hand and replace the sections necessary. Be careful to check that the end caps are pushed in properly otherwise the beater bar will not sit correctly.
Apr 01, 2009 | Dyson DC14 All floors Bagless Upright...
Beater bar belt needs replacedon a dyson DC14 animal
Remove the glide plate at the bottom of rhe machine. Remove brush and broken belt. Fit new belt and re install brush. Fit glide plate, job done.
Its in the instruction book
Mar 08, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Dyson DC14 Animal Bagless Upright Cyclonic Vacuum Logo
245 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
