SOURCE: Zanussi built in aquasave zt 685
Since water doesn't drain out properly ,it could be a clog in the drain line. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. You should remove this line and clear it form any debris in the hose or the hose connection. Be sure to reattach the hose before starting the dishwasher again. Good luck!
SOURCE: Where can I get a manual for my zanussi aquasave
Your model did not appear on my search. Here's a link to Zanussi DWs, check your model number again and check here:
http://www.fixya.com/support/zanussi/dishwashers
Best regards, --W/D--
SOURCE: There is smelly water left in the Salt container.
I was very disappointed to find out that you did not actually offer me a solution to this (surely very simple) problem. For this reason I certainly would not take out a plan with a company like yours. You have offered me no advice whatsoever although you promised assistance.
You are obviously a company that cannot be relied on.
SOURCE: I have a problem with my Zanussi Aquasave ZT685
hi There - We have exactly the same problem which you describe, and wondered if you had managed to find a solution.
SOURCE: My Zanussi Aquasave built in dishwasher ZT485 is
Hi Press and hold the AIR DRY/HEAT DRY button for 15 seconds to
reset the control, if this won't work then unfortunately you will have to
replace the control board. Hope this helps...please post back for further
assistance. Daniel
