Question about Univex 746 Watts SRM30+ Stand Mixer
I have an older Univex 30Qt floor mixer-Ithink the model # is SM30 (it's hard to read because it's so faded) and it is increasingly hard to raise and lower the bowl arms. It defininetly needs to be lubricated, but I don't see any grease fittings when I look inside or outside and I don't want to disassemble it if I don't have to. What can I do?
3 Suggested Answers
bigg t
  • 640 Answers
SOURCE: Univex mixers
Im not bias on my opinion,but from the repairs i do on mixers hobart mixers are far superior than other manufactures.Hobart is over 100 yr old company that started with mixers and their service dept. is good.unlike any mixer out on the market they mirror off of hobart.
Posted on Nov 30, 2007
ricardok45
  • 135 Answers
SOURCE: Need oil/grease for Hobart 20 qt. mixer
Hi. Your A200 is in need of service. The grease's lifespan has expired. There are two ways of doing this. First, the expensive way. Call for a Hobart Tech to come and service the mixer. This will take about 4-5hrs to service at a rate around $100.00usd per hour, plus the cost of parts. He/she will need to change all seals, remove old grease and oil, check all bearings and gears for excessive wear and replace as necessary, this includes the planetary gear.
Now for the affordable solution. Unplug the mixer, remove the top cover. Gently use a small screwdriver to pry off the two circular metal dust caps found on the transmission housing, use a good flashlight to determine, through these openings, the quality, quantity and condition of the grease inside the transmission case. If there's a lot of oil you can remove much of it a bit at a time by using a wire coat hanger to which you can attach bits of cloth to absorb as much oil as you can. Once oil is removed, add new grease through these same holes until full (Chevron FM ALC EP-2, food grade lube). Run the mixer for a couple of minutes to distribute the new grease. Fill to the top once again and replace dust covers. Remove planetary, clean, inspect change seal and re-grease.
OPTION (mechanically challenging) You can do a more thorough job by removing the trans. cover completely, removing the 3 gear shafts inspect all bearings and gears, change seals on mainshaft and planetary. Remove old grease and oil, clean gearshafts and gears. Parts drawings are available from www.hobartservice.com It's free to register and then locate your parts drawings. Be sure that you have the correct files for your Model #, ML# if there is one and Spec.#, all found on the info plate.
When disassembling, take a digital photo of every step and lay the removed components on a piece of cardboard in the removed sequence. These practices will become valuable during re-assembly.
If this solution has assisted you, please rate it. ricardok45
Posted on Mar 20, 2009
How do I trouble shoot a 7512 slicer to free up a frozen slide arm?
There's a Carriage Arm Knob that has to be loosened that could be a possibility also your supposed to lubricate it weekly with mineral oil.
Sep 26, 2015 | Univex Duro 7512 Slicer
I need to raise the head of the mixer. The wire whip is hitting hard the button
Hi LEDAVETTORI, you don’t provide the model number or say if you have a ‘tilt-head’ or a ‘bowl-lift' mixer, which would helpful, but you can easily download a PDF version of your Owners Manual from the KA website at: (http://www.kitchenaid.com/flash.cmd?/#/page/home).
Click on Customer Care>Locate Manuals& Guides> and enter the 6 character model number and select a file listed under Owners Manuals and save that file to your PC. You’ll need to have Adobe Reader to be able to open it. Turn to Page 11 and you will find the instructions for adjusting the mixer head height. I have extracted the instructions below:
Beater to Bowl Clearance
Your mixer is adjusted at the factory so that the flat beater just clears the bottom of the bowl. If for any reason, the flat beater hits the bottom of the bowl or is too far away from the bowl, clearance.
Tilt-Head models
• Unplug mixer.
• Lift motor head.
• Turn screw (A) SLIGHTLY counter clockwise (left) to raise flat beater or clockwise (right) to lower flat beater.
• Make adjustment with flat beater, so it just clears surface of bowl.
If you over adjust the screw, the bowl lock lever may not lock into place.
Bowl-Lift models
• Unplug mixer.
• Place bowl lift handle in down position.
• Turn screw (B) SLIGHTLY counter clockwise (left) to raise flat beater and clockwise (right) to lower flat beater. •Make adjustments with flat beater, so it just clears surface of bowl.
If you find the adjustment screw missing, you’ll need to replace it. But now you’ll need
I hope this helps! –Howard, Burke, VA
If this solution has helped you, please rate it, thanks! - hslincoln
Dec 18, 2009 | Food Mixers
Hobart HZ (h600?) Raising handle is acting up
You will need to confirm the model number. An H600 or L800 have a wheel to manually turn to raise and lower the bowl. The M802 and V1401 hav a belt driven bowl lift clutch, operated by a lever. When you push the lever up or down, you are engaging a small transmission between the motor and main housing. You would need to remove the top cover and see what's happenning. It may be there is something other than the proper spiral pin joining the lift lever to the clutch input shaft, giving alot of backlash and insufficient selector movement.
Aug 18, 2009 | Hobart H600 Stand Mixer
Hobart mixer
Hi,im a hobart tech and know all these mixers well.What kind of mixer are you looking to write about?The differences are the sizes of bowls as 20qt,30qt,40qt,60,qt,80qt,140qt.Pick a mixer and i will write YOUR paper,but i want a fixya rating in return.
Mar 11, 2008 | Hobart HL600 Legacy Stand Mixer
Old hobart s-30 mixer oil
man you got an oldie but goodie mixer!im a hobart service tech for 8 years and have only seen about two dozen,unfortuantly parts for these units are exhuasted.as for the sight glass they do become cloudy over time and you cant determine the oil level.use a heavy gear case oil.the only way of telling is to drain the oil or if the unit is loud you should probably cange the oil.
Jan 20, 2008 | Hobart A200 Stand Mixer
Univex mixers
Nov 29, 2007 | Univex 250 Watts SRM12 Stand Mixer
Univex 746 Watts SRM30+ Stand Mixer Logo
96 people viewed this question
Top Univex Food Mixers Experts
eyecam
Are you an Univex Food Mixer Expert? Answer questions, earn points and help others
