Question about Maytag Neptune MDG5500AW Gas Dryer
Maytag MDG5500AWW dryer won't start. Put in a new control board but still not starting up. Any suggestions what I can try?
  • Maytag Master
  • 8,220 Answers
Did you check for lint? Did you check the duct fuse?
If that thang had an air flow issue that fuse blow and then dryer don't say nothing mon ami.Maytag MDG5500AWW  dryer won't start. Put in a new - 783c115.jpg
Posted on Sep 09, 2010
My Maytag MDG5500AWW dryer will not start. When it's plugged in, the lights come on everywhere except the timer and sensor buttons, and all of the buttons are non-responsive. It has no error code but...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 02, 2011 | Dryers
It has elec. but will not start.. shows a digital display .8.8
sounds like something in the inside the board, of all the threads I have read this one seems to be the one that makes the most sense:
http://www.askmehelpdesk.com/appliances/error-code-8-8-maytag-dryer-mdg5500aww-439011.html
Jan 09, 2011 | Dryers
We own a Maytag Neptune Dryer Model No. MDG5500AWW and have already replaced the mother board. The dryer began beeping periodically and then it just won't start - controls are frozen but they do light up....
If you hear random beeping and a double beep sound when you are pressing a key it means that your problem is the keypad itself, not the board. The keypad on this model is the entire console (not a cheap part @ $200 but this was a very well built dryer so probably worth the repair). You most likely have one of the keys that is shorted out on the console that is causing all of your troubles.
Get yourself a new key-panel part number 33002536 and replace it and you should have your problems solved.
Good luck and please let me know if you have any other questions on this!!
Aug 14, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune MDG5500AWW gas dryer ignites, then flame goes out
The 'radiant sensor/ needs to be replaced. This sensor tells the system that the flame is lit and everything is good. Go to repairclinic.com
http://www.repairclinic.com/SSPartDetail.aspx?s=t-mdg5500aww-%3d%3di2681&PartID=2681
Oct 02, 2009 | Maytag Neptune MDG5500AW Gas Dryer
I replaced the thermistor on maytag neptune gas dryer, model #MDG5500AWW.It still will not start .Do I have to reset the control panel first to get it running?
did you forget to plug the door switch back in? or anything else? oh..it didn't start before...ok. you probably should have replaced the thermal fuse..it's white with 2 wires on it.
Jun 10, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Heat stops after a few minutes, control board already replaced
Thanks for the Chat session I hope I fixed your problem I would like to email you the complete service manual on your model if that is ok it will show you everything and how to break it down please post your email
Thanks Gary
May 18, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Maytag dryer model # mdg5500aww sensor not working is just starts a 37 minutes
How do I lift the top panel of my Maytag Neptune dryer model MDG5500AWW?
Jan 13, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Dryer will not start
If there is power at the start in those two places, check the voltage at the motor, some of these units have a thermal protector on them as well, they look like little round discs with two leads coming out of them. If you dont have continuity then its bad. Also its possible the motor windings are bad i would check the resistance on them as well. Let us know :-)
Sep 15, 2007 | Dryers
Maytag Neptune MDG5500AW Gas Dryer Logo
189 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
