Question about ASUS Ai Lifestyle M2N-E (ASKU49311) Motherboard
Ethernet port on motherboard not working cannot access internet. Router working fine,also changed ethernet cable but still not working.
    Top Expert:
  • ASUS Master
  • 76,164 Answers
Install a PCI express Ethernet card in one of the empty expansion slots, this will bypass the motherboard problem
Posted on Sep 09, 2010
Routor not connecting to modum
That is connect.
You will need to connect the router to the modem with the Ethernet cable.
First connect the computer to the modem with the Ethernet cable. Make sure that you can access Internet without router.
Connect the computer to the Ethernet port 1 and modem to the Internet port on Linksys router.
Open the setup page of the router.
Change the Internet connection settings according to the Internet service provider.
Create a wireless network and then connect your computer and other devices to the wireless network.
Read more about How to setup Linksys router.
Jun 21, 2012 | Cisco Linksys E1000 WirelessN Broadband...
Can not connect wireless to internet
verify that the cable are conned correctly. now the ethernet cable that come from the cable modem do not need to be plugin to the port that is label Internet, it need to be plug in any port 1 to 4. then access you router via a ethernet cable and setup the router of wireless access.
Jan 13, 2012 | Linksys Wireless-G Broadband Router
I use a cable internet connection which works. When I connect the router, I ran cable to blue connection on router and another ethernet cabel from the computer to another port on the router. When I do...
Turn the cable-modem off.
Turn the router off.
Use an Ethernet cable to connect the cable-modem to the 'WAN' (or 'INTERNET') port on the router.
Use another Ethernet cable to connect one of the 'LAN' (or 'NETWORK') ports on the router to the network-port on your computer.
Turn the cable-modem on, and wait for its lamps to settle-down to a steady pattern.
Turn the router on, and wait for its lamps to settle-down to a steady pattern.
On your computer, you should be able to access the Internet.
Also, look at the colour of the EIGHT wires at each of each Ethernet cable.
The order of the coloured wires should be IDENTICAL at both ends.
Jun 26, 2011 | Buffalo Technology Buffalo Wireless-N...
Hey. I want to use my Netgear WNR1000 as an extra accespoint for better range, is it possible?
Step 1: Make sure your old router is working. Step 1a: Connect the Broadband modem to your OLD_ROUTER's Internet (WAN) port. Then connect the computer to one of the four available ports on your router through an Ethernet cable.
Step 1b: Make sure that the Internet connection is working on your computer and on your wireless devices.
Step 2: Configure your new router
Most routers have an IP address of 192.168.1.1 so before you connect them, you need to ensure that they have been assigned two different IP addresses.
Step 2a: Shut down your OLD_ROUTER and the modem. Also unplug the Ethernet cable from the computer.
Step 2b. Plug the Ethernet cable into any of the numbered ports of NEW_ROUTER and connect the other end to your computer. Switch on the NEW_ROUTER.
Step 2c. Access the web dashboard of NEW_ROUTER (192.168.1.1) and change the local IP address to something like 192.168.2.1 so that there's no conflict with the old router. Save the changes.
Step 2d. Test the SSID name of the new router and make sure it's different from the old router. Also make sure that SSID broadcast is turned on. Save the changes.
Step 3: Connect the two routers
Step 3a. Connect the modem to the Internet Port of the OLD_ROUTER.
Step 3b. Connect one of the number ports of OLD_ROUTER to your computer.
Step 3c. Connect another free port on the OLD_ROUTER to the Internet Port of your NEW_ROUTER using an Ethernet or LAN cable.
Jun 04, 2011 | NetGear WNR1000 Router
I got a NETGEAR router and I have been trying to get my Motorola SURFboard to recognize it. I had the USB connection installed and the NETGEAR uses ethernet, so I tried to install the ethernet but my...
The Cable modem must be disconnected from the computer. You cannot use USB and Ethernet at the same time.
1. Turn off power to the Cable Modem and the Netgear Router. Do the same with the computer.
2. Connect an ethernet cable from the modem to the router's WAN (Internet) port.
3. Connect another ethernet cable from one of the remaining 4 LAN ports on the router to the computer's ethernet port.
4. Now power on the Cable Modem ONLY. Wait for the modem to sync up with your service provider
5. After about 2-5 minutes power up the router and wait about 1-2 minutes.
6. Now power on your PC.
Check and see if you have internet access. If not you may have to uninstall any cable modem software related to USB connection. if this is the case, then you may have to repeat steps 4-6.
Since most cable internet providers do not use proprietary connection settings, your internet connection should be up and running without changing any settings in the router or modem.
If this does not resolve your issues, we can continue to work with you.
Nov 29, 2010 | Arris SURFboard® SB5101 Cable Modem
My linksys w/2phone ports cannot hook up with the ethernet
Most Cable Internet Service Providers (ISPs) use Media Access Control (MAC) Address authentication to establish Internet connection for end-users. MAC address is a unique identifier assigned to the network adapter/s of the computer.
To set up your Linksys router to work with a Cable ISP, you have to enable the MAC Clone feature of the router. MAC Cloning is a procedure which enables a router to copy the MAC address of the computer registered with the ISP.
To set up a Linksys router with Cable connection, you need to perform four steps using the computer that's been registered with the ISP:
i. Verifying Internet Connection
ii. Connecting the Devices Together
iii. Checking the Router's LEDs
iv. Setting Up a Linksys Router for Cable Internet Connection
Connect the computer to the Broadband modem using an Ethernet cable without the router installed. If you cannot get online, contact your ISP. If it's online, use the computer to set up the router.
NOTE: Some cable modems use the USB port. If the physical connection is via USB port, you may not be able to go online via Ethernet connection. Contact your ISP to have the Ethernet port of the modem configured.
kb17251-001_en.png NOTE: The image may vary depending on the computer and modem you're using.
After confirming the Internet connection through the modem, connect the modem to the Internet port of the router; connect the computer to any of the four Ethernet ports at the back of the router. For instructions, click here.
After connecting the devices together, check the lights on the front panel of the router. Ensure that the Internet light, as well as numbered light corresponding to the Ethernet port where the computer is connected, is lit. For further instructions, click here.
Step 1:
Access the router's web-based setup page. For instructions, click here.
NOTE: If you are using a Mac computer to access the router's web-based setup page, click here.
Step 2:
On the Setup tab, click the MAC Address Clone sub-tab.
Step 3:
Select Enabled then click Clone My PC's MAC.
Step 4:
Click Save Settings.
Step 5:
Click the Status tab.
Step 6:
Check the Internet IP Address. If the Internet IP Address has numbers, this means the router has been properly configured. You should now be able to access the Internet. If you're still unable to access the Internet, powercycle the modem, the router and then restart the computer.
NOTE: If the IP address is still 0.0.0.0, click IP Address Release then, click IP Address Renew. If this does not change the IP Address, powercycle the modem, the router and then restart the computer.
Nov 14, 2010 | Linksys WRT54GX2 Wireless-G Broadband...
I have 2 wireless routers cascaded with each other... looks like they are having a problem because of their IP address... how do I change the IP address of the 2nd router which is not attached to a...
Wired the 2nd router into another computer ( you only need the power and an ethernet cable into the #1 port of the router )
reset and power cycle the router. then type 192.168.1.1 into the address bar of your internet browser. type admin on the password field, leave the username blank.
-->if you like to setup the router as only an access point
  • on the setup page of your router, disable the DHCP server and change the LAN ip of the router to 192.168.1.5
  • go to the security tab and uncheck all the filters (don't forget to save the settings )
  • go to the wireless tab and personalize the wireless network settings
  • plug a cable into the ethernet port ( 1,2,3 or 4) of main router and plug the other end to the ethernet port on the 2nd router
  • power cycle everything and you should be good
-->if you don't want to router to act as an access point
  • just changed the ip to 10.10.10.1, save the settings
  • plug an ethernet cable into the ethernet port on the main router, connect the other end to the internet ( yellow ) port of the 2nd router
hope this helps
Sep 04, 2010 | Linksys Wireless-G WRT54GS Router...
I cant install my router. The internet, power, WLAN, and DMZ lights are all on, but none of the Ethernet port lights are on, but when I try to complete the install I get the following error message: Unable...
If the ethernet light is not coming that means your router is not detecting your computer. Try to plug the computer on any other port.
To check if your ethernet ports are fine you can perform a loop back test. You can take a cable which is not connected to anything. Than put one end of the cable to one ethernet port and put other end of that same cable to any other ethernet port. If the light on the ethernet ports led up means your ports are fine and u need to reinsatll the drivers of the ethernet card on your computer. Else your routers ethernet port are not functioning. If that is the case you can try to reset the router.
Let me know your finding.
**If this works please rate else let me know in case of further help.**
Jul 03, 2010 | Linksys Wireless-G WRT54G Router
Connecting Laptop wireless and Desktop wired to the router
Do you need to see the desktop or just share folders from each other? If the latter then you need to do the following:
Use Windows Explorer and select a folder you want to share. Right click and select sharing and security.
On the sharing tab click on Share this folder. Enter a share name ( I like to enter the PC name _folder name; Rick1_Downloads)
Click on Permissions. If your ok with everyone using the PC's and Laptops having access then highlight Everyone and click on Full Control.
Do this on each PC and Laptop.
That should be it or darned near close.
Apr 10, 2009 | D-Link AirPlus DI-524 Wireless Router
Wireless router to modem problems
Since it says network cable unplugged on the computer when wired to the router, you need to check these first:
â Make sure that the Ethernet cable is connected from the modem to the router’s Internet (WAN) port and the computer to the numbered port of the router. The computer should used to be connecting to the Ethernet port of the modem, if not; you should contact your ISP first.
â Make sure that the Ethernet adapter/LAN card on your computer is working properly. You can check that on the device manager of your computer.
â If those are all working fine that would mean the router is not yet configured for Internet access or we can say that the settings for the provider are not synchronized with the router.
To configure the router, you can do these general steps:
1. Connect the computer to the numbered port of the router and the modem to the router’s Internet (WAN) port.
2. Turn off the computer, router and modem.
3. Turn on the modem first, wait for the lights to stabilize then turn on the router. As soon as the lights are stabilized, you can turn on the computer and check for internet connection.
However, if the Internet connection still does not work. That means there are additional settings needed to be done. You can message me about the name of your ISP and I will provide you the specific steps you need.
Sep 23, 2008 | Belkin (F5D7230-4) Router (587009)
Open Questions:
ASUS Ai Lifestyle M2N-E (ASKU49311) Motherboard Logo
213 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
