Question about Bosch Ovens
Have a Bosch HBL 655 UAC double oven, stainless steel. Control panel went "pop", breaker kicked off and won't reset.
  • 116 Answers
SOURCE: Double oven / convection not working
It is likely that the convection element is burned out and needs to be replaced. If all other functions are working then this is the place to start. Teh back panel inside of the oven can be removed by removing the 4 visible philips screws on it. The element should look smooth and round, if not then it needs to be replaced. Be sure to turn power off to the oven before replacing it. Remove the screws that fasten the element to the back wall and gently pull the element away from the wall an inch or so. the wires will be exposed and can be unclipped from the element do not let them fall inside of the back of the oven or you will have to remove the oven from the wall to get at the back panel. Install the new element in the reverse procedure. If the element looks good then it will have to be tested with a multimeter to verify that it is still good before proceeding to check the selector switch for burn marks.
Posted on Mar 11, 2007
  • 833 Answers
SOURCE: Whirlpool Double oven - control panel stopped working
Atlanta...sounds like you may have a power supply problem or the panel is bad. Cut the power, open the unit up and see if there is a fuse in there or a reset. No good? Then replace the circuit board. They just, well, die sometime. Happened to my microwave. Some units may be available remanufactured. Look around on the web.
Posted on Dec 07, 2007
SOURCE: Dead Whirlpool Double Oven
This happened to us the first time we used the self-cleaning feature. The repairman said we had to replace the whole electronic panel -- but when he put in the new panel it didn't work either. It turned out he just needed to replace the oven shutdown thermal fuse I believe. We finally got up enough courage to try the self-cleaning again and the exact thing happened. The door is locked and the electronic panel is dead again. So when we get it fixed we will never use the self-clean again.
Posted on Dec 05, 2008
SOURCE: how to remove the control panel on Whirlpool double oven Model RBD305PDS14
Emge & Associates is investigating gas and electric ovens manufactured by Whirlpool, including such popular brands as Whirlpool, Jenn-Air, KitchenAid and Maytag.
The firm is investigating reports that the electronic control panel on certain models is subject to failure after a limited number of uses of the appliance’s “self-cleaning” setting. While most foods are cooked at temperatures reaching 375 degrees, the “self-cleaning” setting raises the interior oven temperature to 1,400 degrees. Due to defects in the design and or manufacturing, the electronics contained on many ranges are damaged by extremely high heat. Repairs to damaged control panels typically cost in excess of $300 per replacement.
If you have experienced failure of the control panel in your range after using the “self-cleaning” setting, you can join this investigation by contacting Emge & Associates at (800) 629-3409 or (619) 618-2974.
Posted on Dec 19, 2009
barkencoa
  • 3463 Answers
SOURCE: Bosch HBL 645 oven door won't close all the way
I am afraid that the door hinges are non adjustable, and the only solution is to replace them as a pair.
There should be some kind of latch mechanism at the end of the hinge
where it is fastened to the door to compress the hinge to enable you to remove them.
Hope this helps.
Posted on Jan 04, 2010
F31
If the cooling fan is constantly running then means thermal overload probably faulty, it has failed in closed position.
Best to get an engineer to help
warmest regards
Richard the Repairman
Mar 30, 2014 | Bosch HBL 455 Stainless Steel Electric...
Calibrate bosch oven thermostat
This process varied for every make and model. For your particular model refer to the owners manual the instructions will be in there.
Apr 24, 2012 | Bosch HBL 455 Stainless Steel Electric...
I need to download a manual for this product. Where can i find it?
I found a users manual for Bosch wall ovens at Retrevo.com
http://www.retrevo.com/s/Bosch-HBL755AUC-Ovens-review-manual/id/925ci470/t/1-2/
Feb 12, 2011 | Bosch HBL 755 Stainless Steel Electric...
Temperature fluxuates constently on our double
The problem is obviously due to a faulty thermostat.
It could be the main oven stat, or an external thermostat that is the cause of the trouble.
Jan 18, 2010 | Bosch HBL 455 Stainless Steel Electric...
I have a mark on the stainless steel finish on my Bosch Oven
i am in the uk and i use barkeepers friend this usually shifts anything on steel i dont know if you use something different in the u/s.its a white powdery substance which you aply with a damp clth then wipe of as it dries works superbly.
Jan 10, 2010 | Bosch HBL 755 Stainless Steel Electric...
Bosch Double oven - top oven will not open - seems like it is locked
i am not aware of a bosch oven that locks the top door usually only main oven will lock if self clean pyro oven,the small oven never has this feature sounds more like a hinge problem check nothing is fouling the lower part of the oven door.
Dec 30, 2009 | Bosch HBL 755 Stainless Steel Electric...
700 series Bosch double convection ovens - Convection roast works, convection bake does not. Fast pre-heat does not work. We tried to reset ovens according to Bosch instruction manual guidelines, but it...
The good sign is that the motor works fine as do heaters. If the operator interface acknowledges feature selection by beeping or what have you, we can safely say the problem lies with the control board or relay.
Oct 02, 2009 | Bosch HBL 455 Stainless Steel Electric...
Bosch HBN745AUC control panel broken and needs to be replaced. Any DIY advise appreciate, included the parts no. and cost information.
If you mean the glass in front of the display and touch panel is smashed, you can buy a new glass panel, about $200, part 239424 (for a stainless oven), see bosch parts link below. Probably the electronic touch sensor board underneath is fine, but its basically glued to the glass panel so will be a bit tricky to peel off and re-glue to the new one.
http://www.bosch-eshop.com/eshop(bD1lbiZjPTAwOQ==)/bosch/us/prodp.htm?prod=HBL745AUC%2f02&ESHOPTYPE=S
Jul 12, 2009 | Bosch HBL 745 Stainless Steel Electric...
Ovens Logo
102 people viewed this question
Top Bosch Ovens Experts
ashburton
reliableservice
Are you a Bosch Oven Expert? Answer questions, earn points and help others
