Question about Danby 5.5 cu. ft. / 156 liter Chest Freezer Millenium DCF550W
I want to make a kegerator out of this. But does anyone know where the coils are in the unit.
  • Danby Master
  • 3,361 Answers
Plug the freezer in a let it run.
After a short while you will see frost lines inside the freezer.
There will be corresponding hot areas outside the freezer if you feel along the outside of the freezer.
The frost lines and hot areas are your coil routing.
You would tap your holes between coils.
Posted on Sep 09, 2010
Testimonial: "You guys ROCK never thought about that. "
How do I convert a Kenmore c675 chest freezer to a kegerator. also, in what range can the temperature range be controlled after conversion
sorry but I don't think it can be done as the compresser needs to be properly located so it gets oiled .why would they sell both if it could be done ?
Jan 02, 2015 | Kenmore Freezers
Kegerator not cooling
which fan , inside or out.. if outside condensor fan is running then it has a bad 175 capacitor or if the compressor is running then it is low on refrigerant. if the cond fan is not running then check thermostat.. you can do this by connecting the two wires together.. another way to check the compressor, cond fan is to reach under and unplug the wires going to comptessor and plug into a 12ga extention cord.
Nov 17, 2013 | True Direct Draw Systems: Kegerator...
Replacing true kegerator parts
no use a Ranco p# A12-700 make sure the capillary is in the coilto sense the temp and set it to 1.5 on the knob. any colder and it could get too cold . you may be able to set it at 2 but be careful. it is a constant cut in at 37 degrees coil temp. the box temp will drop to usually to 28 or 29 at cut out.
Dec 31, 2012 | True Direct Draw Systems: Kegerator...
Do true kegerator parts have to be replaced with true parts
Depends on what part you are looking for. I use condenser motors, evaporator motors, thermostats, and even compressors and capillary tubes that I sometimes get at local suppliers. If you're looking for gaskets, hinges, panels, tap heads or something like that it may be easier to get from True.
Dec 31, 2012 | True Direct Draw Systems: Kegerator TDD-3
TDD 2 Kegerator clicking and not cooling?
It's extremely rare that the compressor will be any good. Usually replacing the start relay does nothing on these small units. If you know how to use a multi-meter and are any good at wiring the cheapest way to go is to get what is called a 3-in-1 start kit at a HVAC wholesaler. You need to know the model of the compressor and/or the horsepower to get the right one. I would recommend getting a service tech to look it over though. Most likely the compressor is locked up.
Nov 16, 2012 | True Direct Draw Systems: Kegerator TDD-2
Whirlpool Chest Freezer Not Cooling Properly After Brown Out
work should be performed by a qualified service technician. verify that there is proper voltage at the wall outlet using a voltage meter. if it is ok check for voltage to the compressor relay. if it is ok unplug the freezer and check for continuity at the start relay and overload. if it is open you have a relay or overload. if it is ok check for the ohms rating at the compressor. common to start/common to run, start to run should be the total of both. also start/run to ground if any of these are open you have a system problem.
Apr 30, 2017 | Freezers
My True 23F has had extensive work performed since I bought it used. On two separate occasions, it worked well for a month, then shut down. At this posting, the compressor will not come on at all. ...
http://www.truemfg.com/pdf/InstallManuals/T-SERIES/t_series_english.pdf
this should take you to their site for a manual on your freezer. I has info on the time clock and how to set it.
First, be sure it has the correct power to the unit. I would then check the temperature control. Be sure it is sending power to the compressor unit. If a contactor is used, is the coil on the contactor getting the correct power? Start there and let me know if we need to go further. Good Luck
Sep 12, 2010 | True 23 cu. ft. / 651 liter Commercial...
Frigidaire chest frezer kegerator conversion
The cabinet is the condensor. The lines run all around it. Unless you add an external condensor kit, the only safe place for holes is the door.
Apr 15, 2008 | Frigidaire 13 cu. ft. / 368 liter Chest...
Kenmore upright freezer
1)forget about the key you'll be disposing of this unit anyway
2)the alarm is to tell you that the unit is above ideal temp.
3)the unit isn't making temp due to refrigeration issue. if it isn't cold enough on 3 then 1 won't do it either.
Apr 09, 2008 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Danby 5.5 cu. ft. / 156 liter Chest Freezer Millenium DCF550W Logo
232 people viewed this question
Top Danby Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
charles
Are you a Danby Freezer Expert? Answer questions, earn points and help others
