Question about LG Refrigerators
My LG LRSC 26925TT refrigerator makes too much ice. There is no arm or any way I can see to adjust it. The manual says it stops when the bin is full. HOW does it now when the bin is full?
3 Suggested Answers
  • 1891 Answers
SOURCE: I have a LG refrigerator LRSC 26925TT and I need
most ref have ice makers. but if yours does not the the ice tray can be pruchased from l g / they are there own dist and most part supply houses do not have there parts . however sear's is a good source / try there web sight and i think you can order it there . i works for me ... mm
Posted on Oct 10, 2010
  • 47 Answers
SOURCE: Our ice maker keeps making
I cant id the model #. Does the I/M have a bail arm or is it optical. If it has an arm lift it to the upmost position. It should stay there and keep the ice from harvesting. If it does not you Might need a new I/M.
Posted on Apr 14, 2011
LG LRSC 26920tt won't make ice
In order to determine the problem you must check a few things:
1) Is there water in the ice tray? If not. verify the saddle valve is turned on, check the connection on the water valve, verify that there are no kinks in the inlet hose, and check he water filter to see if it is clogged.
2) Is the temperature correct? Make sure the fans are working properly and air is flowing. Verify the the frig and freezer are at the correct temperature and make sure the ice maker compartment door is sealing shut.
If these things check out ok, run an ice maker test. Make sure the ejector arm and feeler arm are in their original positions before beginning. If they are not:
1. Turn off icemaker and wait 5sec.
2. Turn on icemaker.
3. Wait until feeler arm and ejector are back to original positions.
To begin the icemaker test: Press and hold the test button on the icemaker for 5 seconds. If the LED, feeler arm and or ejector does not return to to their original positions the problem is with the ice maker.
The ice maker part number for your model is 5989JA0002G
Oct 14, 2013 | LG LRSC-26922 Side by Side Refrigerator
Ice maker keeps making ice, does not stop when bin is full
the ice maker should have what is called a bail arm that is what measures the ice in bin if there is one it should only move up and down if it moves any other direction the bail arm post could be broken
Oct 30, 2012 | U-Line Uline Origins Series...
Our ice maker keeps making ice even when the bin is full. LRSC 26945TT MODEL
Apr 14, 2011 | Refrigerators
I have a LG refrigerator LRSC 26925TT and I need to replace the Ice Tray - How do I do this?
Oct 10, 2010 | LG LSC26905TT Side by Side Refrigerator
Ice maker won't work
my mum use the same kind of freezer, when it had the problem on the ice maker, we both took it to a lg service center to renew the ice maker engine
May 31, 2010 | LG LRSC-26922 Side by Side Refrigerator
LG 26930tt side by side refrigerator water leaking
Make sure the unit is not all iced up, try to defrost it and then retry, turn off the ice maker and water supply before defrosting. Put a thermoter in the freezer to check temp.
Aug 30, 2009 | LG LRSC-26930 Side by Side Refrigerator
Ice maker stop making ice
I had the exact same problem after looking at the ice maker I saw that there was a test button I pressed the button and it started working again
try that!!
Dec 28, 2008 | LG LRSC-26922 Side by Side Refrigerator
Faulty ice maker
Hello. Yes, that is the correct position for the icemaker feeler arm. The updated icemaker has a longer feeler arm that hangs down a little more (thereby shutting off sooner when the ice piles up not so high).
Your water leak onto your food is from water spilling out of the front left corner of the ice tray during fill. This has also been updated with a plastic lip that keeps the water from sloshing out when filling up.
The photo shows that your ice tray appears to be unlevel and drooping in the front left corner. This happens with flex tray icemakers over time. The icetray does not fully flex back to its level posiiton. I do not feel you need to replace the entire icemaker. Repalcing just the ice tray should fix your issue.
Hope this helps, please rate my solution.
Jul 01, 2008 | LG LRSC-26922 Side by Side Refrigerator
Refrigerators Logo
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
