Question about Toshiba 32HL67 32 in. LCD Television
When i turn on picture comes on just for few second right side of screen then goes off sound ok can knot bring up menu all voltages are acording to flow chart but i have no analog video to seine board at cn72a plug audio ok at cn71a
  • Toshiba Master
  • 3,866 Answers
This would be indeed a back light inverter issue, and yes it will need to be change out. You looking at $150 plus parts respectively.
hope this information does help please do click the accept button for my efforts.
Posted on Sep 09, 2010
When I turn on my Sharp TV the picture comes on for a second then goes black. The sound is working but the picture stays black.
hi quick test, in a dark room shine a flashlight on the screen, if you a can see an image, bring the menu up if you can see it the led or leds in panel may blown, thanks
shaun
Feb 15, 2017 | Televison & Video
My vizio tv has no picture but has sound BUT it started a few weeks before that where the screen got darker in a few spots and then eventually went all black.
Mark,
Try this first. Not sure, but most Vizio menus within the last 4 years should be close enough to navigate through. It's a little tricky to get to. You highlight picture, then you hit the right arrow to bring up the Picture menu. Go down to Advanced Video (one above Reset Picture Mode) and hit the right arrow again to bring up another submenu. Go down to Backlight Control. There are three options: OFF, DCR and OPC. Both DCR and OPC seem to cause a problem. Try turning this feature to "OFF" and see if the the problem goes away
Sep 03, 2016 | Vizio Televison & Video
My LG tv will go on then after a few seconds the screen goes from black back to picture of and on a few times then shuts off. Help!
LG LED TV has no picture (black screen) but still sound ...
www.tomsguide.com/answers/.../led-picture-black-screen-sound-fixed.ht...
7 days ago - My 32' LG LED TV has suddenly lost picture! The sound is all right but theScreen is pitch black. After switching it on the picture flashes for a second and thenthe ... LG LED TV has no picture (black screen) but still sound - can it be fixed? Tags: ... a touch on the screen reveals nothing so it's not the back light.
Monitor going black after 2 seconds [Solved] - CCM.net
ccm.net > Forum > Hardware
Oct 9, 2012 - Brightness goes down, display draws less juice, and you can at least use .... it's the LCD's Inverter ... you have to replace it for it to go back to ... If the screen is turning off every two seconds or so and then it comes ... i turn my tv on it comes right on, but then after a few minutes turns off, .... Digital Trends for LG. No display in monitor
Jan 11, 2013
Ps3 and hdmi cable
Oct 8, 2012
More results from ccm.net
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
Dec 20, 2015 | LG Televison & Video
When i turn the tv on the picture and sound come on ok then after a few seconds the picture goes off but the sound continues
solution
step 1 : at first test your fly back transformer
step 2 : test your video I.C.
step 3 : test contrast control system section
step 4 : A.C. transformer out put voltage testSend report :babul_jpi90@yahoo.com
thank you.
please only one vote me.
Jul 28, 2011 | Televison & Video
I turned on my tv and the memorex logo comes on the screen then it goes dark then the pictere comes in for 2 seconds then the screen goes black again. I have sound but no picture. I can't even bring up the...
LCD sets (other than those very new) use fluorescent back lighting to produce the picture. Those lights require high voltage to ionize them so the problem could be either the tubes themselves or the inverter that produces the high voltage is failing. Anyone with some degree of manual finesse and possessed of logic can cure this problem but it may be difficult to identify the failed part accurately meaning that if you 'shotgun' the problem, you would need to replace both the tube(s) and the inverter board. The latter is in most sets as a separate assembly which derives its operating voltage from the main power supply and will be obviously attached to the fluorescent tube(s).
The board will have to found from the manufacturer or a company that disassembles scrapped sets.
Check with the site below for availability:
Jimmy's Parts
Search on your set's model number and the term 'inverter.'
The tube(s) can be bought from several US suppliers.
Oct 17, 2010 | Memorex MLT3221 32 in. LCD TV
My magnavox 42mf438b lcd tv will be fine for about 10 minutes when i turn it on, then the screen goes completely black but it still has sound. it stays like this even if i turn it off and back on. i can...
that set is highly rated by users .. it first came out in early 2009 (i think) so you might check to see if any warranty remains ... the display is illuminated by several lamps .. each lamp has its own high voltage inverter .. all the innverters are powered by an output of the low voltage power supply (often 18 volts)... i would suspect a problem with that low voltage power supply.. either a bad capacitor or a thermal issue .. .. ..
Apr 10, 2010 | SNK Magnavox 42MF438B/27 42 in. LCD TV
Screen goes black after 5 seconds
This can be either the Inverter board or the power supply. If your able to check the necessary voltages on both we might be able to isolate which one is bad, then getting the parts for an Insignia is a whole new ball game. Let me know what you would like to do?
May 15, 2009 | Insignia I-LC26Q1 Television
Phillips 37PF73203 37 in Television goes straigt to Menu and stays
When I turn on my TV it goes straight to the menu screen. You can still hear sound but no picture. When I try to exit you see the picture for about a second then it automatically flashes back to the menu screen. Even if I try to use the functions in the menu screen it flashes right back to the main menu screen. Very frustrated...need help!
Jul 13, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
RZ-32LZ55
You didn't mention what your signal source is but if it is one of the two satellite services, the problem is probably with your receiver, not your set.
Just put your on-screen menu on the screen and if it times out, bring it up again and again.
If the menu continues to display each time, your set is OK.
Call the service provider, Dish or Direct TV.
May 29, 2008 | LG RZ32LZ50 32 in. LCD Television
No video
try to resolder the flyback side,the vertical section,and the regulators.
Oct 15, 2007 | Sony KV-35S40 TV
Toshiba 32HL67 32 in. LCD Television Logo
127 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
