Question about Craftsman 1/2" Impact Wrench
Caftsman inpact wrench model 875-188992 will not work under load. runs good just blowing air thru it.
John deere 445 96 w 22 horse kawasaki fuel injected starts fine runs but rough with raw exhaust gas new olugs new fuel &filter new oil
When it runs rough is it blowing dark smoke? This is a sign of running rich like a choke will do and can cause stalling especially when the motor is warmed up. If it is not blowing dark smoke it sounds like maybe your injectors are not working properly and it is not getting enough fuel through them under load. either way as an injected machine it sounds like injectors may be the culprit since youve taken care of some other issues. You might try running a heavy dose of an injector cleaner through it (I've had good results with lucas brand) and see if that helps. Otherwise, you might try to manually clean the injectors.
Sep 25, 2012 | Garden
My CP impact wrench run fine when not removing a bolt. When removing the bolt it turns it a few rounds then stops
Try a good cleaning with diesel fuel. Keep adding diesel into air inlet until the fuel comes out clean (add diesel then connect air to blow it out) . Once clean, add several drops of oil and retest. If it works better but not full power, try another cleaning with wd40 and retest. Good luck
Oct 16, 2011 | Chicago Pneumatic 1/2" Air Impact Wrench
I have just recieved a porter cable impact wrench,how do i connect the air hose? it has a plug inside a larger nut where the connection for the air hose is,how do i get this out? i checked the instructions...
This plug is usually just a shipping plug to keep trash out. Remove it and install a male quick connect. Put some teflon tape or paste on the threads before installing. Then your end of your air hose should have a female quick connect to plug up to the impact.
Jan 13, 2011 | Porter Cable Tools & Hardware - Others
Need repair diagram ir 2135ti want to reassemble trigger for 1/2" 2135ti
try going to irtechpubs.com nd under industrial tools you will find your model number and can download a breakdown for it. Let me know if you have trouble, I went thru about 15 sites before I found it.
Nov 02, 2009 | Ingersoll Rand 2135Ti Air Impact Wrench
Were can i find maunal for air inpact guns on line so i can fix mine
need to know the brand to help you. here is a web site with some parts. and possible maiulals. http://www.justtools.com.au/prod1770.htm
Sep 15, 2009 | Impact Air Tools & Compressors
The fan sounds like it's blowing but little air comes out.
The A/C blender doors on the 2006 Ram are defective and are prone to breaking. Call your local dealer and ask them if they've heard of this problem. My truck had the same issue and Dodge repaired it under warranty. Good luck.
Aug 19, 2009 | 2006 Dodge Ram 1500
Friedrich a/c zq10 thermostat won't kick in
likely is the thermostat or could be the compressor going out on over load compressor runs blows cold air trips out on the over load fan will stay running jumper out the thermostat see if it stays running.like1/2 hr. if it does replace the thermostat not hard to change if you can find one.Tom
Jun 18, 2009 | Friedrich ZStar ZQ10A Air Conditioner
My 1/2" CP air wrench just blows air thru when I pull the trigger
I have ran into this many times, even though you keep it oiled dirt can and will get inside. what you need to do is unscrew the 4 alen head bolts and pull the nose off. You will see a shaft that looks kind of like a crankshaft with 5 or 6 flat carbon fiber plates sitting loosely in groves around the shaft. pull those out and clean them with solvent and check them for damage or wear. clean the inside of the gun with solvent or brake cleaner, reassemble and it should work fine. If the plates need replaced then you should be able to order them from a tool supplier,and they are not that much.
Jan 17, 2009 | Chicago Pneumatic 1/2" Air Impact Wrench
Heater blowing cold air.
Check the water contol valve operation ( under hood connected to heater hoses), do you have a full load of coolant?, also air mix door under dash, is the temp of the coolant hot?.Check them all out, you'll find it
Jan 03, 2009 | 2001 Volkswagen Passat
Ac conditioner stopped blowing
do you mean the fan doesnt blow either or its just not blowing cold air? check your fuses under dash and under the hood
i can try to help you further with more info
Jun 14, 2008 | 2004 Acura TL
Craftsman 1/2" Impact Wrench Logo
481 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
