Question about LG 42LG50 42 in. LCD HDTV
I purchased an LG BD570 for connection with an 42lg50 LCD TV. I am not using a home theater system and connected directly to the TV with HDMI cable. I am having issues with both the sound quality (sounding muted) and DVD picture quality. I have tried many settings on the TV and player but none seem to agree. I think I am supposed to use the PCM stereo audio settings, but not sure as the manuals are all terribly confusing. Any advice before I return the blu ray player?
    Problem Solver:
  • 19 Answers
You may find a fix hear i did http://www.tvrepairhelp.webs.com/
Posted on Dec 18, 2011
  • LG Master
  • 8,457 Answers
Yes,put it in PCM stereo audio setting.Should work find with the Blu Ray player using the HDMI cable.
Posted on Sep 09, 2010
How to connect LG lcd tv to home theator it is not having adio out put
Hello, "ps_history".
Do both the TV and the Home Theater have HDMI ports?
HDMI ports and cables have the audio connections built-in.
So, IF they are available, try that.
Jul 27, 2012 | Insignia 5.1-Ch. Home Theater System with...
I have a Bose home theater system and a Sharp Aquos tv. I'm trying to hook up the Bose dvd directly to the tv. Problem - tv only has HDMI input capability and Bose does not. I purchased a HDMI convert
Hello
You haven't given any description about the converter you bought. Please send me the model number and brand name of the converter did you bought. OK.
Nov 18, 2011 | Sharp AQUOS 52" Flat-Panel LCD HDTV
Trying to connect a sony home theatre system so that the akai television plays through the home teatre speakers. I used an hdmi cable, but the tv still only plays threough the tv.
The HDMI jacks on the TV are HDMI in. Thus to get the theater system to play the sound, you use the HDMI out from your set top box to the HDMI in of the Sony theater system and then the HDMI out of the theater system to the TV. (Connecting the HDMI in of the TV to the HDMI in of the home theater system will not work.)
If you are watching OTA TV or a direct coax cable connection, you need to hook up the TV audio out to the home theater system audio in to use these speakers with the TV. Then you probably need to set the TV to use the external speakers. This will probably be in the Menu under Audio. (Toggle external speakers on/off)
The Akai LCT2785TA has RCA audio out (1/4" red and white jacks). If your home theater system has RCA audio in, just get a patch cable (MM ends on each side of the cable). If your home theater system only has digital audio inputs, you will need a converter. http://www.ramelectronics.net/audio-video/audio-converters-extenders/analog-to-digital-digital-to-analog/1t-ap-216/prod1TAP216.html is a link to one appropriate converter.
I hope this helps.
Oct 10, 2011 | Akai LCT2785TA 27 in. LCD Television
How can I hook up a panasonic home theater to my brand new LG lcd tv?
Your TV must have an HDMI connector. Please check if your home theater also has an HDMI connector - like this one:
If so, then all you need to do is buy an HDMI cable, and connect one end to your home theater, and the other to your TV. HDMI cables have a digital connection that carries both audio and video, so they are quite convenient. Don't forget to select the HDMI input using your TV's remote control.
Tip: HDMI uses a digital transmission scheme which is fairly robust (unlike analog transmissions), so a $5 HDMI cable will perform just as good as a $50 or $100 HDMI cable. Don't let those store clerks rip you off.
If your home theater does not have an HDMI output, then you must use the analog connections. Look at the back of your home theater and make note of the connectors labeled as 'Output' (both audio and video). You should buy cables with connectors matching those connections.
If you need more clarification on this subject, just ask.
Mar 02, 2011 | Panasonic Audio Players & Recorders
I have and lg tv and a samsung home theater
optical audio cable from home theater to tv. can be purchased on line for a few bucks.
Dec 21, 2009 | LG LHT854 Theater System
LG HT502 wont recognize hdmi cable. it says hdmi
go into the video setup menu, and select HDMI set up and select "ON" that should do it
Jul 15, 2009 | LG LHY-518 System
Need some sound to my home theatre system
Just 2feb827.jpgrun red and white composite audio cables from the audio out ports above the AVin1 ports on the back of the tv to one of the audio input ports on the home theater system, remember which input port you connected it to and when you want to watch tv with the home theater sound just switch to that input on the home theater system.
Feb 04, 2009 | LG 42LG50 42 in. LCD HDTV
LG 5010 42" + Xbox360 + DVD RECIEVER/ Surround Sound SET UP HELP!
give me a shoult at our workshop. I'll give you a hand
SIon
0845 20 20 118
Mediarx.co.uk
Dec 12, 2008 | LG 42LG50 42 in. LCD HDTV
SET UP VIERA LINK PANASONIC PT960
Can you explain a bit more please. What exactly is the problem? Are you getting any picture or audio through to the TV? Are you getting any picture or audio through to the home theatre? Have you got the home theatre setup via HDMI? Have you connected the audio from the cable to the home theatre via optical or phono? What model is your LG LCD HDTV?
I already have the manual in front of me for your home theatre system. If you can give me some more information I can help you out.
Thanks.
Nov 30, 2008 | Panasonic Home Theater System System
Hook up sylvania lc370ss8 LCD TV to a lg lht734 DVD home theater system
Hook a digital optic cable from the Tv's digital ouput to the Recievers digital sound in. This should fix it. You might have to switch the input of the reciever.
Mar 21, 2008 | LG LHT734 System
LG 42LG50 42 in. LCD HDTV Logo
270 people viewed this question
