Question about Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum
Heats up, but I get no steam, just hot water comes out.
  • Euro-Pro Master
  • 43,501 Answers
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
g
Posted on Sep 25, 2010
Steam mop not putting out steam although it is heating up
Well, if you have heat and there is water in it then this is one of two things. The delivery hose is clogged either too or from the heating unit or the heating coil is not getting hot enough. Look for dripping water that is not turning to steam while it is running. That would eliminate the clogged problem. Then you could look at the heating temperature at that point.
Jun 03, 2016 | Vacuums
I have the euro steam blaster s3325 when I turn it on, the steam ready **** comes on right away not heating can the heating element be replaced? thanks
There is a device attach to the heating element called a thermo fuse, this devise brakes down when it get to hot.
open the machine and replace it with the same value. it is written on it..
Nov 20, 2012 | Euro-Pro S3325 Handheld Steam Vacuum
Easy steam express ll not steaming
The problem with the DD steam mop is not getting steam out but trying to get it to keep coming out. If U disassemble the plastic housing around the handle U will see a small part connected to 2 hoses, one going to the water reservoir the other going to the heating unit. This is the pump which provides water to the heating unit, and if this fails U won't get steam. U can try disassembling this and try to get the piston to move more freely. A loud clicking sound coming from this should indicate good movement and a feeble click click click may indicate restricted movement.
Hope this helps
Apr 28, 2012 | Dirt Devil CE7000 Easy Steamer Upright...
Is there a trigger handle to turn off and on
no betty, stupid bit of kit imo, no operating switch, just on/off at the switch, which heats the water up. i measured 500ml of water heated using my kettle, put the top on, switched on, and waited. first time the steam didn't come out of the nozzle, so i removed the end and cleaned the nozzle with water, blew down the end from the big end, and replaced it, steam came out. big grumble though, the steam coming out is not that warm, don't advise you to, but i directed against my fingers, it's only hot at the exit of the pointing bit, used it to try and clean floor tiles and grout, complete waste of time. i wouldn't advise anyone to buy one.
Dec 11, 2011 | Tristar SB Steam Buggy Vacuum
I have a swan steam generator model s14021 and its all working but when you press button to get steam water pours out!
Dont know the model ,but steam is water and if water pours out than the steam heat portion isnt getting hot . Probably a heating element out
Feb 17, 2011 | Vacuums
IWOULD TO KNOW IF STEAM CLEANER ARE HEATED WATER
yes, they heat water to over boiling point by putting it under pressure so you only get steam. it cleans with very little water.
Jul 27, 2008 | Vacuums
Prolectrix 3 tier steam
Is the unit spraying ok? If not then the heater may be plugged. Other than that, you should fill the tank with hot tap water, the the heater will only heat it alittle more, you won't really see steam.
Jan 19, 2008 | Bissell 1699 ProHeat Clear View Upright...
Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum Logo
27 people viewed this question
Top Euro-Pro Vacuums Experts
Dennis Key
Dennis Key
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
