Question about Whirlpool Duet GHW9150P Front Load Washer
My washer is displaying an "F02" message. What does this mean?
  • Whirlpool Master
  • 8,220 Answers
If the drain time exceeds eight minutes, the water valves are turned off
and “F/02” is flashed. Press PAUSE/CANCEL two times to clear the
display.
NOTE: After four minutes the “Sud” error will be displayed, then four
minutes later the “F/02” error code will be displayedMy washer is displaying an - fc2323f.jpg3830f06.jpg
Your tech sheet? GHW9150PW0 Tech Sheet # 8182277 Rev #
Duet service manual and codes
WaMy washer is displaying an - 7a83e56.giftion helpful? 7a83e56.gifMy washer is displaying an - 5a197a7.jpgmi
Rate it or hate it:
Posted on Sep 09, 2010
  • RangerRickF Sep 12, 2010
    After you remove the clean out, with a flashlight check the pump impeller. I had a womans blouse shoulder pad wrapped around the impeller. It had bypassed the clean out! OK now. F2 was the code. PS wet vac out all the water you can from the tub before removing the clean out. You won't have enough towels if you have a full load in when it quit. Rick F.
SOURCE: F02 what does it mean
I have had this issue more than once. It was an easy fix for me (maybe a 20 minute job and best of all no money). For my F 02 error it was my 4 year olds socks that some how got down the drain line and stuck in the clean out. Here is what you do. There are 3 screws bottom of the front access plate. Remove these and the lower access plate will pop right off. Right in front you will see the pump and the drain line. It has a clean out right there. Unscrew the cap (be ready for alot of water to rush out, so have alot of towels ready). Once the water is drained remove the cap. The cap has a trap so that larger items do not get to the pump. This is where I find the socks stuck. Clean it out, tighten the cap back into place, put the access panel back on, and hit run. Has worked for me at leaste 3 times. Those pesky kid socks every time.
Posted on Nov 14, 2008
  • 1294 Answers
SOURCE: F02 problem
This is actually for the Kenmore Elite, but it should help.
You have to check your filter to remove blockage. Lift the machine at front to have access to 3 torx screws under the front panel. Slide downwards out. Have a wet vac ready. You will see the pump filter right in front. Gently unscrew, water will begin to drip, use the wet vac. Remove the cap & pull the filter out to remove all debris & lint, make sure there is nothing in the impeller. Refit carefully.
Your dealer wants to make more $$ so he won't write these details in the user's manual.
Posted on Mar 08, 2009
jsrock516
  • 5911 Answers
SOURCE: Our Kenmore HE4T frontload washer is displaying an
"F02" is a Long Drain error code. This is an indication that you have an obstruction somewhere in the drainage system. Most commonly, there is something lodged in the drain pump or inlet line running from the wash tub to the pump. There is a white screw off cap on the drain pump that you can remove to inspect the pump impeller and clean. The following link explains:
http://www.fixya.com/support/r3608545-f02_error_code
Included is a follow-on link that explains how to check the drain pump to clean. You may also have to remove the inlet hose that runs from the bottom of the wash tub to the inlet side of the drain pump. Debris and small articles of clothing can commonly clog in this area as well causing the drain cycle to fail.
NOTE: The "SUD" error code can often occur in conjunction with the "F02" error code. This is due to air being detected in the drainage system, which can occur if the pump is not running, or if you have an obstruction BEFORE the pump. You need to remove the inlet hose from the pump to ensure it is also not blocked. Correct your drainage system fault, and the SUD error should go away.
If you have any questions about this repair, or need additional assistance, please let me know. I hope this helps you.
NOTE: If these preliminary measures do not correct your problem, you may have to replace the drain pump. It does not take much to damage the pump impeller or motor. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced.
Posted on Dec 17, 2009
tbirdfan1
  • 3051 Answers
SOURCE: F02 Error message
Hell F/02 Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
o there>
Posted on Jul 06, 2010
blueextc3221
  • 15935 Answers
SOURCE: a code F02 appears on
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
(Tip Courtesy JSRock)
Thanks for using FixYa!!
Posted on Dec 10, 2010
What does F-02 flashing on the display of my Whirlpool Duet washer mean?
Hello & Welcome to FixYa
F02 is a drain error in your Kenmore washer, if the unit is unable to drain then after 4 minutes it will display suds and then F02. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Jun 11, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool washer ghw9150pw0, error message f02. I have removed, cleaned and checked all drain lines and checked backflow ball. everything is good. May I assume the pump is bad.
HELLO THERE AND THANK YOU FOR CHOOSING FIXYA
The f02 error code is a long drain error meaning the following and here is what needs to be checked before replacing the pump
Long Drain
Jun 06, 2011 | Washing Machines
F02 error and not draining correctly (pool of water left at the bottom of the washer after cycle has completed). This is on a whirlpool duet front loading washer.
Hi
Error F02 appears after 8mins of SUDs error. Error F02 means Long drain, means washer is taking longer time than normal to drain. Press PAUSE/CANCEL twice to clear the display. NOTE: After 4 minutes the SUD error will be displayed, and then 4 minutes later the F02 error code will be displayed.
There are 3 small 9/32 hex head screws that hold the front panel on. Unscrew the 3 hex head screws (9/32 socket or nut driver size), now remove the front kick panel. Unscrew the white drain cap -WARNING-- lots of water will drain out when you loosen the white cap. Once all the water is out, remove and take out the filter trap.
Hope this helps... Please post back for more information
Daniel
Jan 01, 2011 | Whirlpool Washing Machines
F 02 is being displayed on washer. Can the washer be fixed from the front of machine.
Hi
? Check the drain hose and make sure it is not plugged or kinked.
? Check the electrical connections at the pump and make sure the pump is running.
? Check the drain pump filter for foreign objects.
? If the above does not correct the problem, replace the pump.
Daniel
Jan 01, 2011 | Whirlpool Duet GHW9150P Front Load Washer
F02 Error message
57f1973.jpgUse a nutdriver (1/4th in) to get that bottom panel off.001354b.jpgaab6887.jpg
Jul 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool washer keeps sending me a message of F02? what does that mean?
the F02 message is an error message,try to check the settings on your washer or put it off and remove the plugg from the mains after some time plugg it back into the mains and put it on
Feb 27, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
I have a Kenomore Elite HE4t Washer. I am getting an F02 error message. I've tried to rerun washer & get SUDS on and off. Fo2 message appears again and cycle shuts down. Door will not unlock. Any...
HI. this code represents a Long Drain issue.
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• If the above does not correct the problem replace the pump
Oct 14, 2009 | Kenmore Elite HE4 Electric Dryer
F02 error message. What does this mean and what do I need to do?
Her is what f02 means for your washer.
Long Drain
Her is what to look for.
Good Luck
Oct 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
What does the "sud" message mean?
hello fo2 means if the drain time exceeds 8 minutes the water valves are turned off and f/02 flashes. things to check / check the drain hose for any kinks and blockages check the electrical connection to the pump make sure the pump is running / check the drain pump filter make sure its not block if these do not sort the problem replace the pump. to clear the display press pause and cancel to clear good luck
shaun
Mar 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
329 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
