Question about LG Televison & Video
42LG3000. 3 sets at the hotel and all keep switching back on within 5 seconds of turning them off. Any ideas. Lg say it is not a known fault. richard@thehollieshotel.com
SOURCE: Lg Plasma Display settings keep switching
When you boot up your tv for the first time, you get to choose between home and shop-mode.
In your case, he TV is set to "shop-mode".
Then it will go back to factory settings after 5-10 minutes. (so that customers won't mess up the settings all the time)
So change the settings from shop to home, and your problem is fixed!
Posted on Mar 01, 2009
SOURCE: pioneer pdp 502mx goes to standby no picture after power on
Contact Pioneer at 1-800-421-1404 about getting an in-home power supply replacement. This is a known issue with some plasma displays. Some of you would experience a loud pop and then the power supply fails. You get a red light below the ON button, when you press on, the red light will turn green for a second and then back to red. The plasma display will not turn on after the power supply fails. Call Pioneer at 1-800-421-1404.
Brought to you by http://abstravel.com and http://reservaciones.com
Posted on Mar 29, 2009
SOURCE: tv keeps disconnecting from digital tv, returns within 5 seconds but highly annoying! pictue goes blank and sounds goes aswell , almost like the tv has turned off only to restart itself
It sounds like it is loseing signal, check your connections, and make sure you have the correct cable
Posted on Jun 01, 2009
  • 8457 Answers
SOURCE: WHERE CAN I DOWNLOAD A USER MANUAL FOR A 42LG3000
Try the LG website itself u should able to download the owner manual,if your tv model still in the selling market.If not give LG a call talk to their costumer service department pay them a fee they will sent it out to u.
Posted on Nov 24, 2011
SOURCE: I have a Lg 42" lcd tv (42LG3000) TV is wall
White screen with good audio. before buying pcbs & such. try my repair method.. you need to get the lcd unit off the facia & then remove the front lcd metal frame. at the top of the screen you have 2 thin pcbs - chances are that the ribbon cable got at least one track unbonded. first off put some double sided tape under the pcbs to stick then to the frame - that'll take the bend out of those pcbs !! next put cellotape over the ribbon cables. i then cut 6 pieces of sponge 15mm thick & wide as the ribbon cable & glue to the tape on the ribbon at what would be the top edge of the screen (covering the point where ribbon meets pcb).. put the metal frame on top edge first to keep the sponge straight !! put it back together & fire it up. if it still aint working you may need a tcon pcb (little square one at the top). this fixed my 42lg3000 but can work on others with same fault !!
Posted on Dec 19, 2011
Lg tv has flashing warning
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices
http://electro-medical.blogspot.com/
Nov 18, 2015 | LG 42LG30 42 in. LCD HDTV
How do I set a Hotel LG TV back to Default Settings?
To release the Hotel mode; you have to enter its service mode option. If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Type in the brand name and type (TV, VCR, DVD player etc:) of your device, in the search box [at the top right] of the home page. It will make surf easy.
Jul 07, 2015 | LG Televison & Video
Helllo, wanted to know how to get out of hotel mode
The following are for LG TVs: From your remote, push MENU button for 5 seconds then type 1105 and press OK. You should now have a special menu displayed where you can modify the settings or disable hotel mode. Use the same procedure to go back and modify or enable hotel mode.
Oct 20, 2014 | Televison & Video
LG DVD & surround sound plays for about 5 seconds, then screen blanks out for about two seconds, then it comes back on... for about 5 seconds, and so it goes on. This is with DVD's and USB content.
These blinks [flashes] are fault indication (Error Codes).From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it.This will make repair easy.These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times.Count it carefully.If you wish to get some details, check the site linked here.It has details about blinking codes, and fault locating, to many popular brand TVs and other devices.Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given
Feb 13, 2014 | Philips 32PF5321D 32 in. LCD Television
Screen blank
These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/
Nov 30, 2013 | Televison & Video
How do i get rid/ reset message xc90 "transmission service urgent" i have already taken to volvo dealer about six months ago. they could not pin point issue on diagnostic. Cheers
You first have to retrieve fault codes from your computer network then you have to diagnose the systems/circuits indicated by the fault codes to determine what the cause of the failure is, then you must repair the system/circuit at fault and then reset the computer system. If the dealer cannot do this, I don't know who can. Did they tell you what fault codes they were getting? If so, we can look up the troubleshooting charts for those codes as well as do a Technical Service Bulletin (TSB) search to see if this is a known problem with a known fix. Without the codes, your guess is as good as mine.
Sep 11, 2011 | 2004 Volvo XC90
Lg hotel tv. t.v. button are locked out, only hotel remote works
Hold down the MENU button on the remote for approx 5 seconds. Then enter 1105 this will access the hidden hotel option on the LG tv so you can change whatever you like..
Cheers LITTLE DISH FITTER
Jun 08, 2009 | Televison & Video
LG 32LX3DC 32 in .Model
Hello Dupree71
The first thing I would do as its from a HOTEL is take the LG telly out of HOTEL MODE. follow the steps below, This should allow you to change the settings on the telly and store them. So when you turn the tv back on it will not revert back to the hotel Options
TV turned on. Hold down the MENU button on the remote for approx 5 seconds then type in 1105 this will take you to the LG hidden Menu.
in this menu there will be hotel mode turn this option off.
This will allow you to save your own setting without it jumping back.
When you follow my steps and its sorted for you please leave a thumbs up for me Please
Thanks
Little Dish Fitter
May 29, 2009 | LG 32LX3DC 32 in. LCD HDTV
32lc5dc lg tv stuck in hotel mode
it is quite possible, if you bought this set from a hotel liquidation, it might still have it's lodgenet card. If it does, then it may be stuck on the channels the hotel had lined up. If there is a lodgenet card (where the cable jack is on the back) you can remove the 2 screws and just pull the card out an inch (leaving it attached to the black cable). Once that card is out, the tv should fall back to normal use. You might need to do a facotry reset to unlock TV options at that point. Only way around this would be to remove the 2 screws holding in the lodgenet card, and pulling it out of the back of the set (Don't have to pull it out all the way, just enough to disengage the data socket. Once the card is removed, you would need an actual LG remote (not the pay per view remote) and hit menu a bunch of times until it stops flashing menu on and off. Once it stops, you type in on the keypad, "98765" "ENTER". This will take you to an installer menu. Scrolling down to the highest numer there is (Should be one backwards from the "000" you start on" there is "Factory Reset" and you use the right arrow key and set it to "1" and then press enter. The TV will flicker a couple times, and then, all inputs are active.
Jan 17, 2009 | Philips RC2573 Remote Control
Stuck in hotel mode 32 lg lcd
hold down MENU button for approx 5 seconds, then enter 1105 this will bring up the hidden menu then turn off the hotel mode.
Hope this Helps
Cheers
Little Dish Fitter
Jan 16, 2009 | Philips RC2573 Remote Control
Televison & Video Logo
Computer Repairing
Computer Repairing
