Question about Reddy Heater-70,000 BTU Kerosene w/T'stat
Reddy Heater 70 runs until the heat is adequate in the garage, turns off, but fails to turn on when it becomes cold again
  • 232 Answers
2 guesses. 1. the thermostat is bad. 2. temperature sensor is bad.
These can be tested with a multimeter. Remove the components, put in warm environment, the move to the fridge. See if the continuity changes as the temp changes.
Posted on Sep 11, 2010
When i cut on heat run about 45 cut off smoke blue?
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
Jan 03, 2011 | All-Pro Kerosene Garage Shop Heaters - All...
I have the thermostat set for 70 degrees on the white rodgers programmable thermostat. The heat runs until the room is 70 degrees, but then the heat stops and the room cools off and the heater doesn't kick...
Based on your explanation this is an erratic operation of the thermostat, first thing that you need to check is the wiring make sure that all the wires are proper looped on the under terminals then reset the thermostat if the problem still persist I think you need to replace the thermostat. If you need further support call the homeowner techline 18002842925.
Jan 03, 2010 | White Rodgers White-Rodgers 1F85RF-275...
After 10 minutes of running in uninsulated garage air becomes dif
I need more details... what is it doing, what is your supply, etc....and why do you think it is the very unlikely improper air gas mixture?
David Lawrence the Propane Fuel Dude
Dec 08, 2009 | Reddy Heater RLP100 Portable Forced Air...
Reddy Heater 70 (Kerosene) won't start
In the same temperature range that is giving you trouble, run an ext cord (110v) from a known good household circuit and plug the heater into the cord. If the heater runs OK, then the inverter is your problem.
Jan 05, 2009 | Reddy Heater-30-55,000 BTU Variable
Motor fails to start when cold
have you checked the bearings? oiling the motor with wd-40 creates a gummy mess that binds the motor. the lubricants in wd-40 are solvent based. once this "vehicle" dries up what's left is a silicone product that dries out. use a dependable light machine oil like 3 in 1 oil or a sewing machine oil
Dec 28, 2007 | Reddy R60A Utility Heater
Reddy Heater-70,000 BTU Kerosene w/T'stat Logo
Top Reddy Heating & Cooling Experts
Mack Baxter
paulcarew
Richard Marsh
Richard Marsh
Level 1 Expert
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
