Question about Vacuums
My windtunnel vacumn U5464-900 has lost suction in the hose. It is not clogged. What may the prob b?
  • 1,040 Answers
The beater bar belt more than likely needs replaced. When they get stretched out they no longer work properly.
Jim
Posted on Sep 09, 2010
  • Jim Parker
    Jim Parker Sep 13, 2010
    Did this solve the problem?
    Jim
Why would a Hoover Windtunnel have no suction?
It could be clogged at the head or throat, or you might have a hole in the hose. Unplug the hose; if you're getting suction where the hose plugs in then the problem is in the hose or the head. If you're not getting suction where the hose plugs in then the problem is in the body, probably the throat. If the problem is in the hose or head, detach the hose from the head and check for suction at the end of the hose. If there's not suction there, then you've got a clog or a hole. If there is suction there, then you've got a clog in then head.
May 20, 2014 | Vacuums
How do I switch the vacuum from floor to accessory suction
It automatically switches over when you disconnect the hose from the power nozzle. No suction it getting to the power nozzle, so the suction is only through the attachments. If there is no suction through the hose, check for clogs in the hose and in the tank where the hose plugs in. Also, check the screen at the bottom of the tank. If there is a clog in the hose or tank, then there also will be no suction to the power nozzle.
Remove all clogs and you should get suction.
Dec 19, 2010 | Hoover U5721-900 WindTunnel Upright Vacuum
Hoover Bagless WindTunnel vacuum cleaner.
very easy. you have clog. take the brush off look where the hole is thats where the clog is. it might be in there you might have to take the housing off of the motor
May 08, 2009 | Hoover U5753-900 WindTunnel Bagless...
Hoover windtinnel suction problem
the intake hos at the bottom might be clogged.first take all the filters out and disconnect the hos completely from the vacuum,then check and see if you have suction.the intake hose is the clear looking one at the bottom that wrapps itself up from the base to the backside of the upright.you can use a coat hanger to push out the clog if there is one just bend the tip till its rounded.work it down into the intake hose from the back.after removing the hose and the filters you should have suction.just make sure all the filters get cleaned .you can blow out the hose with a garden hose
Apr 02, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
No sunction from my Hooveer windtunnel vacuum
disconnect the hose from the intake hose on the back its the clear looking hose at the bottom on the back.yes you should feel suction where the bag gets connected the clog is at the bottom.but clean the filters first.your long hose i would take it outside and blow it out with a garden hose.on the bottom where the intake hose is ,take a coat hanger and bend the tip till its rounded so you don't puncture a hole in the hose.just work it down into the tube and se if you can push the clog out the bottom ,you can put your hand over the intake hose where it connects to the long hoseand see if you have suction there,if not then the clog is in your intake hose.if you do then the clog is either in the long hose or the filters
Mar 17, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
No suction or very little
Make sure you have a good bag installed in the vacuum and the door is properly in place. Remove the attachment hose from the bag chamber and turn the machine on. You should have good suction coming from the hose inlet. If you don't you have a problem in the bag chamber. Bad bag, door is not on correct, door is defective, dirty secondary filter.
Connect the hose back to the machine and pull the other end out from the bottom, and turn the machine on. You should have good suction there. If you don't you have a clog or hole in the attachment hose and it needs to be unclogged or relplaced.
Reconnect the to the bottom. Flip the mahine upside down. Take the screws out of the bottom plate and remove. Remove the brushroller and belt. Turn the machine on and you should have suction at the inlet coming off the brushhousing. It you don't, then you have a clog in the nozzle hose and it needs to be removed. It will probably be more accessable from the bottom side since that is the way that it entered.
Sometimes a suction problem can be confused with an brush problem. The belts on that machine should be replaced every 6 to 8 months because they will strentch and wear. This is an inexpensive maitainance that will dramatically improve its function. Part Numbers are 38528-035 and 38528-034
Nov 21, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Getting no suction
Check the hose for a clog, when suction is low, you will usually find a clog in the hose or in the dirt inlet by the brush roll. If this is less then a year old, then it is still in warranty, if you can't figure it out, then take it and proof of purchase to a warranty repair shop.
Mar 21, 2008 | Hoover 5416-900 WindTunnel Bagged Upright...
Hoover Windtunnel
Either the hose has a clog, or the inlet down by the belt is clogged. Is there suction at the end of the hose, if not then it is clogged. If there is suction, then it has to be clogged down below by the brush roll, check that inlet. There also is a filter at the bottom where the dirt cup (and bag) is, check it also.
Dec 28, 2007 | Vacuums
Wind tunnel hoover
Do you have suction at the hose end, if you do then it may be clogged at the inlet by the brush roll. Is the filter cartridge clean? If it is clogged and air can't pass thru it, then you will have no or low suction. Might also check the belt to make sure it is turning.
Nov 30, 2007 | Hoover U5753-900 WindTunnel Bagless...
Hoover Windtunnel
Mine does the same thing. There is no suction. I found that there is a door that opens when you tilt the handle in the down possition. I think there should be a spring in place so it can open. Until I find a replacement spring I have to open the door manually throught the opening under the light.
Oct 15, 2006 | Hoover U6630-900 WindTunnel Bagless...
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
