Question about Home
Washerless faucet leaks - Home
  • 22 Answers
Turn water off, dismantle retainer remove and replace cartridge or remove rubber valve rubber with head of small common nail,pull out springs and get replacements at hardware store for specific application, or for a quick fix, strech springs slightlyand reinstall.
Posted on Sep 11, 2010
Dripping water unless I totally shut off cold water line.
If you will make contact with George at M-One-Specialites he can track that down for you and help you get that fixed.
He has a very extensive list of repair parts for faucets.
Rod
US Parts Center
Jan 29, 2013 | Kohler K-12265-4-CP Fairfax Widespread...
Tip
Diagram-Type Faucets
DIAPHRAGM-TYPE FAUCETS
  • The diaphragm faucet is washerless but is similar to washer-type faucets. A rubber diaphragm between the stem and seat creates a straight-down, frictionless close. As with washer-type faucets, diaphragm faucets have two handles.
  • Remove the stem by following the steps outlined for washer-type faucets. Instead of a washer on the end of the stem, you'll find a swiveling disc. If the rubber diaphragm doesn't come out with the stem, it is still inside the faucet.
  • If the diaphragm didn't come out with the stem, use pliers to peel it from inside the faucet and pull it out. Install a new diaphragm around the swiveling disc, then replace the stem in the faucet.
  • If the faucet is leaking around the stem, replace the stem's O-ring before reinstalling the stem.
on Jan 16, 2010 | Plumbing
Tip
WASHERLESS FAUCETS A leak in a washerless faucet usually indicates that the...
WASHERLESS FAUCETS
  • A leak in a washerless faucet usually indicates that the working parts need replacing. Often, prepackaged repair kits are available. Kits may contain all the necessary parts, or may include only the specific parts that need replacing. Follow the instructions for installing the replacement parts. Washerless faucets on tubs and showers are repaired in the same way as those on sink and washbasins.
How to fix a leaky Moen faucet that leaks at the spout ,which is separate from the handle?
These faucets can leak in three different places:
  1. Internally at the valve seat
    You'll see water dripping from the spout. This means the rubber washer is worn or damaged. To replace the washer, remove the decorative cap from the handle. Remove the retaining screw and pull off the handle. Remove the decorative cover, called an escutcheon, if there is one. Unscrew the packing nut counterclockwise. Unscrew the valve stem and remove it. Remove the screw that holds the rubber washer in place. Because these washers come in many shapes and sizes, you'll want to take the old one to the hardware store and buy an exact replacement. Be sure to buy two washers so you'll have one for the other valve. Replace the washer and reassemble the faucet.
  2. Around the handle
    If you see water coming from below the handle, the packing nut is leaking. Older faucets have a string-like graphite packing material wrapped around the stem. Newer faucets use an O-ring. First try tightening the packing nut clockwise... about one-half turn. If this doesn't stop the leak, remove the packing nut and replace the packing or O-ring; then reassemble the faucet. If the valve is using the graphite packing material, it might be a clue that you should shop for a new faucet.
  3. Between a pivoting spout and the body
    The spout might be held in place with a packing nut, similar to the faucet stem, or it might have a nut at the top of the spout. In either case, remove the spout and replace the packing material or the O-ring seal. Then reassemble the faucet.
Single lever faucets also are known as "washerless" faucets. They are easier to repair than compression faucets after you determine what type of faucet you have. There are three types of washerless faucets: ball, ceramic disk and cartridge.
Leaks are evident in two places... dripping from the spout and seeping from around the spout where it joins the body of the faucet.
Leaks from the spout indicate that the ball, disk or cartridge is leaking. To repair, turn off the water to the faucet, then remove the handle. The handles on ball-type faucets are held in place with a setscrew that requires an Allen wrench to loosen. Ceramic disk and cartridge-type handles usually are held in place by a screw hidden beneath a cap.
On ball and ceramic disk-type faucets, remove the ball or disk and replace the seals. You can buy replacement kits for these faucets at the hardware store or home center.
On cartridge-type faucets, remove the spout and pull out the retainer clip that holds the cartridge in place. To remove the cartridge, pull on the cartridge stem with a twisting motion. If it resists, install the handle so you can a better grip on the cartridge to pull it out. Take the cartridge to the hardware store or home center and purchase an exact replacement kit.
Reassemble the faucet according to directions.
Leaks at the spout-to-body joint indicate an O-ring failure. Disassemble the faucet as described above. Remove the spout sleeve and replace the O-rings. It's a good idea to replace these seals if you have the faucet disassembled for repair of the ball, disk or cartridge.
Sep 10, 2011 | Moen Plumbing
Hi. We have a Danze "UPC" single-handle shower faucet. Our shower head is dripping, and when I removed the faucet cover plate, and screwed in (what I assume are) the cutoff values on the left...
It's likely a cartridge faucet and that cartridge usually pulls straight out, and is replaced as a unit. you're close to the finish line, but may have more work to get that cartridge out. some of them have special pullers.
Mar 19, 2017 | Home
Dripping facet
If a faucet is leaking the necessary repair will be either:
1. For a ceramic or washerless faucet, replace the cartridge.
2. For a typical old fashioned faucet, open the faucet, replace the washer (and packing if it has any) and verify that the faucet seat has not eroded.
The newer washerless faucets cannot be repaired except by replacing the cartridge. Cartridges for most common faucets are available at most home improvement stores or plumbing supply houses.
It sounds a lot more difficult than it really is, just shut off the water (usually a shut off valve under the sink). After the water is off, remove the handle and any chrome protective covering. Depending on the faucet type, it may be a little difficult to remove the cartridge since they are often covered with mineral build-up or corroded into place.
Once you remove the old cartridge the new one usually goes into place easily.
NOTE!!!
For single handle faucets, make sure you put it in the right way, some of them will put the hot to the wrong side if you put them together backward.
Mar 13, 2011 | Home
Bathroom sink faucet,(washerless) has a drip when closed. what part do I need to fix this. Gerry
http://www.housetask.com/Leaky_Faucet_Repair.htm
a repair kit/cassette
most decent plumbing centres will be able to match up the old cassette
Oct 21, 2009 | Plumbing
Dripping faucet
Take a cloth and lay over the top of the stem so as not to damage it. With pliers, grasp the top of the stem and turn it a quarter turn counter clockwise. The stem should lift right out.
Mar 14, 2009 | Kohler Model 102704A: Fort® Centerset...
Home Logo
56 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
