Question about Homelite Mighty Lite Lawn Trimmer
String broke off into string head assembly....how do i remove string head assembly to remove string and restring?
    Problem Solver:
  • 14 Answers
How to remove a murray trimmer head
Hi Christina,here's a video showing you how to remove head and restring. How to String Murray 2500 Edge Trimmer Wead Eater Walmart wind up
Aug 27, 2016 | Murray Garden
How to restring cub cadet 173cc push mower
take off the hood remove any old string, now wind up the spring and hold it tight put the new string through the hole in the hood and into the hole in the crank wheel pull it through 6 or 8 in. slowly let the spring unwind now tie a knot in the rope and you're done
Sep 15, 2013 | Mtd 19 In. 173 CC OHV 3-In-1
Change head on trimmer
you buy spool of line and thread your self, you maybe able to buy the spool already has string on the spool, most are basic, the spool should have the direction you need to string it.unplug the trimmer, turn up side down, it have nut on it, unscrew it counter clock wise, than pull spool off restring the line for the weed eater, the string must be wound counter clock wise from the direction the weed eater or trimmer spins.
www.ask.com/mfg.name/make/model/change/head/trimmer/
Mar 21, 2013 | Troy-Bilt 25 CC Gas String Trimmer TB22EC
The string broke. It is a yard machine lawn mower
Take pull string housing off. Looks like 3 or 4 screws. Should be able to restring from under side. Either buy new string or if old string is long enough, just tie knot on the end. Good luck
Feb 03, 2013 | Garden
Removeing string head assembly
Pry the plastic cap off, then you will have access to the bolt. Other kinds have a nut that you unscrew. If you are just going to restring it, you can push in and turn the head for it to come off.
Jun 27, 2010 | Husqvarna 28cc Gas Line Trimmer
How to restring 132r trimmer
Get a gater head for your trimmer. It has 4 easy to replace strings, that when broke off you can make up a new set with a pair of side cutters, or just replace 1,2, or 3, I put one on my homelite and it's the best thing i've seen since sliced bread.
Mar 30, 2010 | Ryobi Garden
How to restring dual feed trimmer
YOU MUST REMOVE THE STRING HEAD YOU SHOULD HAVE TWO PEICES THE IUTER HOUSING YOU SHOULD CLEAN THE INNER SPOOL REMOVE ANY OLD STRING AND LOOK ON THE BOTTOM THERE SHOULD BEARROWS TO TELL YOU WHICH WAY TO WIND THE NEW STRING
Aug 16, 2009 | Homelite Garden
I have a double string trimmer I cannot figure restring
Hi
check the following links :
http://www.ehow.com/how_2241527_change-string-lawn-trimmer.html
http://www.youtube.com/watch?v=SuGfDNH6fXk
Theses are just two, there are plenty of videos out there that shows how to resting trimmers
Hope it helps
Jul 17, 2009 | Ryobi Garden
Have weedeater but no manual to read on how to restring to line
to restring it all you have to do is pop the cap of string head pull the spool out and wind your string around it in the way they say to run it.its usually on the spool wind this way with an arrow.the cap shood be pushed in and turned to unlock the cap replaces the same way
Jun 10, 2009 | Troy Garden
Remove head to restring
you need to locate the black knob at the trimmer head and turn it coun ter clockwise and remove it to access your string spool you may have to chase the knob with pliers because some are more than hand tight
follow arrow on the spool for line winding direction
May 26, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Homelite Mighty Lite Lawn Trimmer  Logo
263 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
